Keith M
Posts posted by Keith M
It depend who supplies it
To date and I am going back many years I have not had 1 failure
1 Failure and that is the profit gone
Keith
Then you'll be fine.
Are you tracing voltage spikes, or wondering what kind of inverter you have?
Richard
Richard
I will mainly be looking at hopefully a nice sine wave on the outputs of generators
But it would be good to show what sine and Modified sine wave look like
By the way hope you have a good time at IWA event
Keith
Sorry I did mean to generate a multi quote
Keith
Yes of course its possible, its what oscilloscopes do. However due to mains voltages, I think this one falls into "if you have to ask how to, you shouldn't be doing it".
The last time I had to use an oscilloscope was back in the late 70's and we always used a divider circuit
Technology has advanced so much this is the reason for the question
Keith
Interesting. Yes, that's what oscilloscopes are for - have you got much experience of using one?
Richard
As you can see in post ten it is along time since I had to use a scope
But back in the 70's I use one most days
Keith
I need to look at the voltage and wave form at the same time
As the title says
Can you buy an oscilloscope that can be directly connected to say an output of a generator or an inverter
Many thanks in advance of the answers
Keith
If you look at the Blue Seas version of the Maxi Fuse hold they also have employ screws for retaining cable lugs and terminals.
Keith
Following on from my 20a Sterling charger thread:
I need to install a fuse on the DC cable between the charger and the batteries. 25 or 30a maybe? I've looked around, most of the spade type fuse holders seem to have quite spindly wire tails, despite being rated to 30a. There doesn't seem much point in running 6mm wire, which I've already done, then interrupting it with something thinner.
Can anyone recommend a fuse and holder that would be suitable? Ideally something not too bulky, as things are a bit tight where I plan to install it.
Thanks.
Hello Gareth
I will suggest a Maxi Fuse and holder for your installation
Keith
not normally
Keith
I am often in Yelvertoft
Keith
Yes I have to agreed
But if the system has a good design and is well executed there is no problem
If it can work well within a hire boat surely there is no cause for concern in the hands of a private boater
Surely the same applies to a set of batteries going down?
Keith
I believe there have been some staff changes within the BSS office this may be the reason?
Keith
I have worked for more than 30 years with Inland water ways craft electrical systems
For the last 15 years I have not designed or installed a system which incorporates a DC fridge
Spending nearly £1200 on two DC items will almost cover the cost of an Inverter or Inverter / Charger then there is the DC cable to consider normally 10 mm2 not cheap
Always an AC fridge
Keith
2
I would say that is a silly price
Mastervolt has 1500 watt inverters for around £ 630 inc vat mark
Keith
Remember this may be the way in which the examiners have been trained?
Keith
When did they demand this? I bought a consumer unit from Hinckley a couple of weeks ago because Nuneaton had no stock. As I'm not a 'qualified' electrician I didn't benefit from the electrician discount but they still sold it to me at catalogue price.
Some weeks ago now 10 or more weeks ago
Keith
IIRC the catalogue listed a couple of options, but at my local branch they came up as out of stock with no stock at the warehouse.
I have just had a quick look on the screwfix web site well over 95% are now metal
This has only changed within the last week or two.
Keith
If it genuinely related to an RCD, I thought they were not even a mandatory requirement of the BSS.
I thought their use was "strongly advised" or similar - nothing more.
"Flamingo" has fairly recently passed a BSS, and has an RCD unit that is fairly elderly, and in a plastic box.
However one thing has now fallen into place in my mind that I did not understand until now. I recently tried to buy a small unit with RCD and Circuit Breakers in, similar to what "Flamingo" currently has, but found everything on sale, certainly in places like Screwfix, is now in massive great steel boxes, really far too big and clumsy to put in a narrow boat. I guess the above explanation says why this is......
Screwfix will still supply plastic enclosure containing RCD and MCB's
As an add on we have a new branch of screwfix in Hinckley before I could purchase any electrical installation items I had prove that I was a qualified electrician
Keith
Is Sherborne wharf not closed for redevelopment
But I think they are close by not sure where
Keith
Thanks Keith, I had a feeling ours was steel but maybe not.
It would all depend on supply the prop shaft to the boat builder
Prop nuts are normally brass
Keys can either be steel or brass
keith
Exactly the point I was trying to make but using humour!
Sorry very tied
Still recovering from Crick
Keith
Best to choose a surveyor who is on good terms with the builder.
This way you will ensure there are very few 'problems' during the build...
I would use a surveyor who is not known to the builder
This should keep the surveyor and the builder on there toes
Keith
Surely a boat builder that builds fully fitted boats would have all these in place already, qualified fitters that would sign their work off for the RCD.
I can see maybe employing a project manager with his team of experts if building a sailaway but not a fully fitted boat through a well established reputable boat builder.
Maybe once the OP decides on a builder the builders points and reputation can be discussed by people who have had first hand experience with the chosen builder, until then there are many different scenarios and questions that can be brought up.
During the coarse of a year I will inspect between 20 or 30 NB which all have RCD documentation stating the the electrical systems conform to the two EN ISO 10133 and 13297 in most case the vessel fail.
Some on simply things and others on major items
Such as using the hull as a conductor or not identifying which fuse is for what
Keith
Is it possible for a hand held oscilloscope to measure AC voltage directly
That is a very kind offer
If it can be found yes I would like to play
Keith
