davidandheather
Posts posted by davidandheather
Out of interest, run the bow thruster a few times to gve a realistic discharge then measure the voltage at the bow thruster batteries when they are on charge.
Chris
HI
I gave the bow thruster a good discharge a then tested the volts at the battery end while charging i was getting 14.05 volts the cable size is 90mm2 over 60 foot
David
We have a LEC 12v fridge been as good as gold the past 4 year
David
Seems the only option to me - ( front batteries / very thick cables to charge )
What size ( mm2) cables are they ( or diameter if you can't remember) ?
Nick
I did not build the boat we had it done for us so not sure of the size but they were very big from what i can remember, they looked like big armor cables i will have a look at the weekend.
David
Yes but...
if the batteries are at the back near the alternator, and the bow thruster is at the, err... bow (!), I assume it takes quite a current ( 100 amps ?) so you would have to run even bigger cables to it to minimise the volt drop, wouldn't you ?
Whats the optimum answer for those with a bow thruster ?
Nick
Our bow thruster batteries are at the front of the boat and are charged by the 45 amp starter alternator via very thick cables.
We have never yet had a problem using this system in 4 years not that we use the bow thruster much.
David
I don't hear very good things about the 3 coverage ?
Hi Mark
We have a 3 network modem seem to work ok all over the midlands, 10 times better than the vodaphone one we had before
Cheers David
From a previous posting I did a fag packet estimate of the monthly cost of living aboard, taking into account the following
mooring fees
licence
insurance
heating & cooking
diesel
repainting every 2 years
saving for maintenance
I came up with about 600 English pounds, not including food or beer (which would double that).
Is this way off the mark?
Does anyone have an idea of their annual costs?
Hi
Bet thats not far of the mark depending on your mooring costs
David
This has been done to death on several occaisions.
Put "tug stle narrow boat" into the search option and have a look at the thread started by davidandheather.
That was a very informative thread which flushed out some good opinions from some acknowledged experts (and others).
It will occupy you for hours. Happy reading and welcome.
And we still not got a tug never will at this rate just keep the one we got
David
We are sitting in Debdale Marina waiting to go into the paint dock next week, so I will be able to give the answer in about 6 week. One thing I can say it will not be th cheapest estimate you will get on the system
Well you can be sure of one thing Dave will do a 1st class job
David
What some people will do to save a penny or two!
Cheaper to get your water out of the tap me thinks why take a chance with death
David
Found this on the web http://www.leptospirosis.org/
Filtration - does not work!
Leptospira are incredibly small - they can pass through the pores in water filters, even those that claim to remove bacteria. They will pass easily through filters with a pore size of more than 0.2 micron, including membrane and charcoal types. High-pressure laboratory filters with a pore size of less than 0.1 micron will block them, but the typical hand-held water filters used by hikers, pool filters and the fitted cannisters used in some domestic kitchen applicanes are useless at removing leptospires - they are often used to separate leptospires from other bacteria when preparing samples for research, as the leptospires pass through but other bacteria don't!
UV sterilisers
These are also very effective against leptospira (and most other pathogens), and can be bought on all scales. Permanent systems for processing flowing water in a domestic house are available, but can be expensive and use electricity. Portable devices for camping and backpacking are also available, resembling a small flashlight or pen, and these can be used to sterilise a single cup of water - but need batteries. The advantage of using UV is that there are no chemicals involved, and the electricity required is less than for boiling the same volume. It does require the sample to be transparent though, so can't be used on things like milk
Cheers David
As we are in the Midlands but in a marina we dont get to see coal boats (and TBH think it would annoy the marina owner if we brought from them..Shame oh for a bit of bank!)
We too have problems finding coal suppliers...think your best bet is in Rugby from Crick.....sometimes the farm shop next to the marina sells it but unless anyone tells me otherwise fraid its a drive out!!
Cheers
Gareth
(and if anyone knows of anywhere around Market Harborough...
The garden shop near the marina in Crick always have house coal and some boiler nuts. if you go to the garage in
Welford they have a good range, maybe expensive phunicite at 11 quid a bag
David
Hi
ABNB have a 40 foot mooring at Crick Wharf they had a sign out when we past last week
Crick Wharf
West Haddon Road
Crick
Northants
NN6 7XT
Tel: 01788 822 115
Cheers David
Hi
Any decent machine shop will make you on one them in know time
David
Hi
What you need to do is find a friend with a working boat load it up with the crap and hide it in the long grass on the Leicester section of the GU no one will ever know
David
Hi
We had a problem with our Mastervolt inverter it was running on low volts and all the problem was a loose connection on the isolator switch maybe a good idea to check all the connections
David
Hi Ours has done the same this weekend and i can not see how it works
David
Just found this
http://www.thetford-europe.com/web/show/id=91559/langid=42
David
Our Thetford CS-200 loo seems to have stopped displaying a red light when the cassette is near full.
No disasters yet, but I'd like to avoid one.
The manual does not say how it works, but I suspect some kind of magnet on a float inside the removable cassette, which activates a reed switch inside the toilet base.
There is power to the loo, as the electric flush works fine.
Best guess is the magnetically (?) operated switch has failed, or a bulb has. (I don't think it's a problem with the cassette, as we have two, and neither seems to produce a "full" warning.)
Has anyone experienced this, and how was it fixed, please.
(Suggestions that we need a dipstick for the loo, as we currently have for diesel and water tanks have so far been ignored! )
David
Saw this at Crick show...http://www.hybrid-marine.co.uk/index.html
Any opinions ???
I will make the link work
Yes, after they went onto float (still putting 6 amps in), I just switchd both of them off and back on again. I guess this is the right time to do it?
So can someone with a Victron (or other charger without adaptive charging) tell us what sort of charge is taking place when their charger goes onto float?
If you're on shore power I suppose it doesn't really matter if you've got adaptive charging or not since the charger stays on and you've got as much time as you want to charge - the issue really only arises when you're running the charger from a generator.
Hi our Mastervolt charges at around 1 amp in float seems to cut in and out not a clue if its adaptive or not
David
Well we are already at Crick waiting for the show and 'Banter' to start!
NB 'Alnwick' is tied up near Bridge No. 13, in the same spot as we have occupied for the last two years. Because of our deep draught we usually start out tying up some three or four feet from the edge of the canal but by placing weights on the mooring lines, every time a boat passes the mud and silt on the bottom is gently re-distributed so that we gradually edge in closer to the bank.
When we first moored here in 2006, we thought that being near a bridge with limited visibility, would encourage passing boats to slow right down - we were wrong! Only competent steerers pass us slowly the others seem quite content to bounce off the bridge, bounce off us or cause our mooring pins to be pulled out of the ground. The weights on the mooring lines seem to help by reducing the shock on the pins so, hopefully, we shall not have to re-position them quite so often this year!
Jane and I look forward to meeting those of you who come to Crick this year.
Hi
I did wonder what the weights were for when we passed your boat on Sunday afternoon without hitting the bridge or you . You were sitting on the bridge taking the world in
Cheers David
Hi
The height issue is a + point for me as they are in a locker on the stern in a semi trad
My 90amp alternator has no problems charging them up as you take no more out of them than ordinary batteries normally around 120 amps a night they are fully charged after a couple of hours running the engine.
Cheers David
Hi we have Fiamm 2 volt wet traction batteries total amps 800 now in there 3rd year been ok so far.
Only thing i can say is you need to keep them topped up as the use a fair amount of water as they should according to the spec sheet. Also they take up less floor space than a load of car type batteries on the down side they are dam expensive but should have a lot longer life if looked after properly
You pays yer cash and takes your choice i know what i would buy
David
H
a bit of white grease on the pivots would be good
David
Hurricane Heater
in Boat Equipment
