Capnbob
Posts posted by Capnbob
15 minutes ago, David Mack said:
Well it hasn't broken off leaving the threaded part behind, so it must have been unscrewed, even if it was then left loose in the top of the dolly.
Yup. Not that anyone would admit it, but I can't come up with any other explanation.
Has it been pinched my someone trying to steal your fuel?
Interesting question. Not theft, because the filler cap isn't locked. It just popped off when knocked by a rope, which clearly wouldn't happen if it was fitted securely. Our best bet is that the marina where we refuelled an hour previously released it to bleed the air out when filling, and then failed to replace it correctly. Nothing else makes sense.
Thought so. Thanks everyone.
For reasons I cannot fathom the plug which should be fitted to the top of the stern dolly (see pic0) has gone missing. I'm wondering if it's just a plug (seems unlikely) or more likely that it has some function,like air inlet valve to the diesel tank below.
Boat is a 2003 Liverpool Boats 58' semi-trad.
Would be very grateful for advice on:
what is it?
how worried should I be that it's missing?
where do I get a replacement?
Many thanks...
For anyone looking who stumbles over this, I solved the problem by cutting 40cm off the pound shop spring (also available in Toolstation), connecting it to a drill (on screwdriver setting), and using it to bore into and through the (very solid) blockage. Worked a charm, even round the bend.
19 minutes ago, Jen-in-Wellies said:
Link to the destruction manual for Rule bilge pumps. As others have said, where the cables go in to the pump body is a sealing grommet, not a waterproof connector. If you manage to pull it out, you've broken it! Connection will have been made by the installer somewhere along the wires, hopefully above bilge water level, but you never know.
You can remove the pump body from the base by pressing the tabs each side. This will let you clear any blockage, or gunk that is jamming the impeller. If that doesn't fix it, then it is time for a new one.
Jen
Yep, that's what I was expecting, but couldn't find a definitive source to confirm, so thanks for that. Agreed it should be removable from a connector upstream, but as far as I can tell the cabling just disappears into the loom. Maybe it's just buried under a lot of insulating tape, so I'll work on that next. Thanks for all the replies folks.
Point taken, but I'd still like to check for simple things like a blocked impeller first.
Pump stopped working, and became submerged, so trying to remove it for a fix. Problem is removing the rubber electric connector/grommet. Tried pulling hard, but it's resisting, and I'm anxious not to damage a connector which - by definition - has to stay water tight when reassembled. Grateful for any tips (even if just to say the brute force method has worked for you). Thanks.
Well, thanks people... Really helpful.
Putting it all together it seems I've got the wrong device, or maybe not, but given what I have got then the best move forward is to also fit either a nasa bm2 (thus doubling the cost of battery monitoring) OR a cheapo ammeter (which is much more appealing), and use the latter to know when to stop charging, and the Smartgauge for all other monitoring, especially to know when to start charging.
Is that a reasonable summary?
If so, can anyone point me to a wiring diagram to tell me how to connect up a cheap ebay ammeter?
Fitted a new set of 3 batteries, cruised for 4 hours and moored. Should be 100% charge assuming the "fully charged ex factory" claim is correct.
Four days later (during which time I operated very little electrics) fitted a Smartgauge. This initialises itself to a default 75% SOC until it learns more accuracy over time, but I overrode this and set it manually to a nominal 93%.
According to the manual it will learn accuracy over the first few charge/discharge cycles, but the manual presumes I've got an accurate SOC charge meter connected to guide that process - but of course I haven't (which is why I bought the Smartgauge in the first place).
I've only got the engine for charging at the moment, so my instinct is to wait until the SG drops below, say, 90% and run the engine until the SG says 100% (and then another, what, half-hour?) Then repeat...
Does that sound like a reasonable plan?
Well, I left the engine bay open for 3 hours to disperse the hydrogen, and nothing's been connected since. And, to be fair, it was the charger that claimed to be fit and forget, not the batteries.
The grenade reference is a bit terrifying, insn't it? Battery was warm mercifully, not untouchable, so I hope that means some tolerance left. Not that it matters, I'll be binning them soon. I have a part delivery from Tayna now, just waiting for battery 3 which, apparently, DHL lost in transit. Just hope all the cables swap smoothly over from old to new.
BTW, vaseline or not on the terminals?
Checking the others isn't easy. They are sealed, and also pigs to get at - tucked right in under the steel deck with little clearance at the top of the high sided box for wielding spanners.
Thanks for the advice folks.
Came back to the boat in the marina after three days away and discovered that the "fit and forget" (Numax/Electroquest) battery charger is going full belt, fan on, with a smell of cooking coming from the engine bay where the batteries are. Switched it off immediately, opened up the engine bay and the middle of 3 (ancient, Numax 110Ah) very warm to the touch.
I know these batteries are shot, and replacements are ordered, but they won't arrive before I have to move the boat tomorrow. So what should I do?
risk running with the batteries as they are?
disconnect just the dodgy one?
disconnect all for the run (and will the alternator mind that)?Any timely advice would be welcome.
To be fair I didn't ask about the croc clips - I already know about that. Agree with your general point that assuming ignorance is a good fail safe...
I was hoping that siting the charger in the utility room would be a goer, because opening the engine cover to check the charging LEDs would be a pain. I also get voltage drop, so if 25mm2 cable would be ok over a run of about 2.5m then I'm very happy to go with that.
Perfect reply, all I needed, many thanks Alan.
Bought the 30a Fairstone/Electroquest ABC-1230D charger, now need to wire it up to the 3 x 110Ah batteries sitting on the swim at the rearmost point of the engine bay.
The 240v end is fine, but worried about the 12v end -
1. Should I take it right back to the battery terminals, or will it be OK to connect to the bus in the electrics cupboard in the cabin?
2. If I do go right to the batteries, can I leave the charger in the engine bay, or fit much longer cables to reach inside the cabin?
3. Advice seems to be to throw away the croc clips (fine), and fit a fuse to the +ve, but not sure what type or capacity.
Help much appreciated...
3 minutes ago, Floating Male said:
Despite all of the generalisations about 'cheep Chinese' the issue is more about knowing what you are getting.
Perfect summary of my own views and experience, and why I posted the original enquiry. I saved £750 a few years back buying cheap Chinese solar tubes in the face of everyone on the relevant forum telling me they'd be rubbish - they've actually performed impeccably.
If I had got 4 or 5 "well we've had one for years and it's been great" replies I'd have taken the chance, but just one "I took one like that apart and it was rubbish inside" is enough for a rethink.
2 hours ago, Jess-- said:
on some similar (20A) chargers we had supplied with some other chinese equipment...
Now, that's the sort of personal experience I was hoping for. Thanks for that. Back to Plan A then.
6 minutes ago, Rickent said:
They are cheap for a reason.
Yes, but the reason could simply be that they are mass produced in factories run by robots supervised by highly skilled but very cheap human workforce, compared with other makes which rely on less automation and more expensive labour. It doesn't necessarily mean they are inferior.
I'm sure I read a thread some time back talking about the pros and cons of buying cheap chinese chargers, but blowed if I can find it now, so am asking direct.
After a swift look around at options I keep finding variants of this one on ebay for £70 or less.
Very cheap, and of course received wisdom is that, being cheap and chinese, it will soon fail, possibly disastrously, and possibly damage the batteries by not actually performing to spec.
OR... I've actually had a lot of very good stuff from China recently, and I have to wonder how bad this can be. Clearly if it IS as good as the spec says - and clearly it's been intelligently specced - it could be a very good budget charger for a boat. What does anyone else think - worth a punt...? Alternative views would be very welcome (especially from anyone with actual experience).
7 hours ago, forsberg said:
Did we get a reply on if its an inverter or inverter/charger?
If that's a comment related to the OP - which puts it firmly in the minority - then it's a simple 1500w chinese inverter.
All the rest is fascinating, but a bit dense in the context of the original question. (Apart from the, er, banter of course, which is just fascinating).
22 hours ago, Mike the Boilerman said:
I'm not sure why you think information in old threads goes 'out of date'
Well, one example, my sense is that once upon a time Smartguage (SG) was all the rage, but then it changed hands and Merlin sold them poorly calibrated, and that got reported in one or two threads, but the originals are still there saying SG is the bee's knees.
It's a fundamental weakness of a forum-based knowledge bank, like this is. Frequently needed information is generally MUCH better dealt with by a Wiki, which provides a single, easily accessed, easily updated page per topic. Forum threads on the other hand start on topic, then tend to drift into communal rows (sorry, "exchanges of views").... as this one nearly did. Also with a Wiki things like "tail current", and "SOC" (which are meaningless to the newbie, but understandably offered as helpful shorthand by those who know what they are talking about) can easily be explained in context.
Nobody chooses to ignore the invaluable advice of the manual, or the gigabytes of advice buried in forums, but to most newcomers identifying the real-world meaning from the mountain of words is an uphill struggle.
Anyway... in the light of the generous advice offered to my original post, I think I'm going to get a decent mains charger, and learn how to:
"use an ammeter and a voltmeter to establish state of charge, especially when charging" (?);
hunt down the meaning of "tail current" which I gather is vitally important;
calibrate a smartguage and interpret its misleading advice.Although I know the answers to all these are almost certainly buried somewhere within the forums, I'd be grateful for any pointers or summaries...
14 hours ago, Tony Brooks said:
If you can be bothered to learn a but about batteries and charging then a digital ammeter and voltmeter is more than adequate for battery monitoring but if you can't then a Smartguage and ammeter is the best you can do.
Very happy to learn, Tony. I have a feeling this was summarised somewhere, but can't track the process down now.
This is all proving a great summary of 12v (and 240v) systems, and much food for thought. Thank you...
Stern dolly - centre plug missing, help appreciated
Posted · Edited by Capnbob
To complete the story for anyone who turns this thread up on a search, I did eventually track down the right item. It's a 1/2" BSP fuel tank vent, like this:
https://shop.chastheboat.co.uk/products/fuel-tank-vent-1-2-bsp-male-brass?keyword=Fuel Tank Vent
