starman
Posts posted by starman
Recently fitted a Seaflo domestic water pump, the system seems to operate well with no leaks but after taps have been run for a longish time the pump runs on and on and on before switching off. There’s an accumulator in the system set at 19psi
The spec says the pump has a shut off pressure of 60psi - could the need to build pressure up to what seems pretty high be the cause? -
2 minutes ago, nicknorman said:
Most likely the flickering ones use resistors to limit the current, not electronics. The former are typically specced for 12v, the latter usually something like 9 - 30v. You need the latter type so that the voltage fluctuations are controlled by the electronics.
That sounds a pretty convincing explanation to this electrical numpty - is there any visual difference; no markings on the bulbs.
Some but not all the boat leds flicker when the water pump runs. Indeed on one circuit one light flickers and the other doesn’t.
Most are the old school switched central dome light with down lighters in the galley. All the wiring is new and oversized for its job. No dimmers etc.
Could it be bulbs? The flickerers all the tower type, the ok ones flat circular with an attached connector. These came from Bedazzled, the others I have no idea.
9 minutes ago, Tracy D'arth said:
Are they all doing it? If it has been damp, the thermocouples can get damp in the magnesium oxide powder insulation in the coaxial copper "wire". This reduces the current available to hold in the solenoid in the gas taps.
They can be dried in an oven@200 d degrees. but they will have to be removed to do it.
Yes all doing it - but can I light the oven good question!
Just started using our lpg hob after being out of use for three plus years during refit.
The gas works fine but we have to hold any hot plate control knob down for 30+ seconds or the FFD cuts in and the gas goes out. Hold long enough and all’s fine.
Anyone got any clues - fast running out of matches and patience. -
The crane guy gave me a pretty full explanation of the size needed and price. Basically they charge £1100 just for the crane to leave the yard. Plus the cost of a slinger/signaller person.
Other crane firms are at least 20 miles away so I guess it’s bite the bullet time.
At least the other end is a lot cheaper! -
3 minutes ago, PD1964 said:
Where are you in the country?
last time I had a 100T crane in to lift a widebeam, they charged £1200 plus Vat. Luckily the owner was willing to pay that.
I’m in Suffolk and it’s £1450 ex-VAT. It’s a local outfit - only about five miles away.
I might query the need for a 100 tonner. The guy has looked at the site but I wasn’t there - maybe he’s taken a very pessimistic view on the boat weight. -
27 minutes ago, George and Dragon said:
Why do you need 100 tonne crane? Your boat will be <20tonnes.
That’s what the crane people specced after a site visit. The boat is quite heavy c. 25 tons. The same firm offloaded using smaller crane and said it was near the limit.
The technicalities I don’t know but it doesn’t need long extended jib stuff. -
I need to get my 60ft nb craned from hard standing at a farm onto a truck for transport to canals.
I’m told I need a 100 tonne crane. I’ve been given a price by the local crane hire people but it strikes me as a bit steep.
Can anyone give me a ballpark figure for what I ought to expect. It’s a straightforward site - lorry can sit alongside boat and crane along there too. -
Thanks all - we’ve had a look at Calcutt(a) and the dog voted with his feet: the wooden staging was fine but he wouldn’t even step on the metal stuff. Very scenic and quiet and space for dog walking.
If the dog is happy Starwoman is happy and if she’s happy I’m happy so Calcutt it is.
- 1
Thanks all - we’ve had a look at Calcutt and the dog voted with his feet: the wooden staging was fine but he wouldn’t even step on the metal stuff. Very scenic and quiet and space for dog walking.
We want to make ours the main boat bed. We’ve got the usual three foam mattress pieces but thinking about a ‘topper’ that can be fitted with a bottom sheet and rolled up into the bed box so making the bed is quicker.
Memory foam seems the obvious stuff but I don’t really like it - what do others use? -
11 minutes ago, Richard T said:
Assuming your boats name indicates where you live whats wrong with mooring on the Soar? Sileby allow work on boats, not certain about Leicester Marina. Then there is Meadow farm at Barrow where liveaboards are allowed and work is done on boats. There are also other smaller set ups like MGM at Thurmastoon and Boons at Mountsorrel. The Soar is a great river - it does flood but so what!!
Good thought ... except we live in Suffolk😏
(Debdale is about as close as you can get to us on the canals.)
Thinking about a mooring here - first on the diy jetties then on the main ones.
What do people think of the place? Friendly?
And how dog friendly? Are the jetties metal gridding - that’s always bad news for a K9. -
Thanks for all the info. Our other thought was Debdale on the Leicester GU. A useful bit closer home and diy pontoon area. I’ll start a new strand about that one.
Thinking of mooring here but - big question - are the jetties dog friendly? Some places seem to have metal gridding - non slip for people; awful for dogs.
And what’s the unofficial line there on DIY? Not angle grinding and welding stuff but some banging and power sawing inside. -
I’m looking at the surface mounted Sequoia set up as I have a steel kelson under my floor right where I want to put a table leg base! Anyone tried it?
On 19/08/2021 at 19:09, David Mack said:
Is that the Midland Chandlers version of the Epping?
How much do they want for it?
It was £250 and understandably sold pretty quickly. (But I didn’t buy it.)
Any more news on this issue? We have friends planning to do the Leicester Ring in mid July. I couldn’t find any info on the CRT website but maybe I was looking in the wrong place.
12 hours ago, Tracy D'arth said:
I have not seen any with any appreciable corrosion. They do burn or at least melt down to the water line when set on fire though unfortunately.
Yes they do and this is what happened to one at Braunston
Not by me - just seen it in one of my Facebook groups. As it’s a private group I can’t forward a link or any photos. It’s not a marine unit, sitting in a frame with a radiator so a genset or similar. This is the ad wording:
“Lister JP3
Working order, fuel in frame
Viewings welcome can be seen working, loading available”
It’s £1200 and in Woodbridge Suffolk.
If anyone’s interested let me know and I’ll pass on your details. -
On 11/04/2021 at 23:10, Tam & Di said:
I too just watched on catch-up, but perhaps it was a different version as I certainly did hear said as Murflynn reported that the canals fell into disrepair after commercial use dried up, and only the intervention of CRT allowed the canals to be brought back from a state of dereliction, all achieved since 2012.
I did keep watching, but unfortunately Countryfile seems to be rather a non-programme and I can't imagine who it is aimed at. I was absolutely aghast at the section following the canal snippet which was about milk cows which apparently never saw the outside world or grass at any point in their lives.
I didn't have great expectations, but I did expect something with rather more thought behind it.
Tam
Just watched it on iPlayer and, like you, aghast at the news that the canals were in disrepair until CRT took them over and even more so about the poor cows who live in a cow factory being looked after by a woman with a voice like a banshee. And then a few minutes later the same programme saying how good our standards were compared with countries who we were about to sign trade deals with.
12 minutes ago, David Mack said:
No I mean cut a hole in each side hatch door and fit an appropriately sized window frame in the hole. As is often done for front doors, although the windows will probably be smaller.
Sorry misunderstood. I guess what you’re suggesting is what I was wanting to do. Maybe it is as simple as the way you put it but I’d be interested to get first hand experiences.
Is my cold water pressure too high?
Good thought but on my Surecal the PRV is 4 bar which is c. 60psi.
