Smigger
Everything posted by Smigger
  1. Ayupnar. Can anyone point me in the right direction for larger pulleys for a lister ts2 as mine is hardly spining the alternator please. I’m in Stoke On Trent. Many thanks Paul
  2. Smigger
    TS2
    Thanks for the reply. I'll go and have a looksee and report back. Cheers Smigg
  3. Smigger
    TS2
    Afternoon all. Bit of a problem this morning, dropped down to one cylinder, After fafing around the injector pump body has turned !! So with a spanner and set of mole grips holding the body still. So has any one come across this before and does it mean a reconditioned set is on the horizon. Many thanks Paul
  4. So I'm helping this morning,lol. So if I draw it off square using small ratchet straps it should come off to be supported by a sling
  5. He just cant get the gearbox away from the engine ?
  6. He's got someone to do the job he just can't get the gearbox off the bolts it only moves roughly quarter of an inch back ??
  7. He dropped the oil and refilled with with correct ep 90. But still no reverse lol
  8. Prop is well back 2 inch or more.mainly sticking on the right looking down with the prop behind you
  9. This is a cry of help for a stranded fellow boater. His reverse no longer operates. He is trying to take off the gearbox,8 nuts have been taken off and the gearbox it moves about a quarter of an inch then refuses to move any more !!! Is anyone wiser than he is andoing could help him please
  10. Thanks for the info. I just knew that the return was smaller diameter. Cheers Paul
  11. Hello again.Could anyone help im fitting new fuel tank.I'm replacing old rubber fuel pipes.The fuel pipe in is in 10mm,what should the return be 6,8 or 9mm. Thanks Paul
  12. Thank you Tony that's a great help.I'll be on it shortly and any problems I'll report back. Thanks again Paul
  13. Thanks for the information I'll look first thing. Not sure how to take the rev counter of the alternator either,hopefully receive my manual tomorrow Richard. Thanks Paul
  14. Hello everyone,I would like to fit a oil pressure gauge and rev counter to my Lister Ts2.Has anyone done this or now's of a way to fit these if possible. Thanks Paul
