Hi All,
Recently my year 2000 Beta BV1505 has been reluctant to start from cold after giving 15 seconds of glow plug heating, the battery seems ok with good cranking speed.
The resistance of each plug is 1.2 ohms which I believe is ok?
The voltage measured at the battery drops from 12.7v to 12.1v whilst powering the glow plugs.
The voltage measured at the glow plug rail is 8v with a current flow of 24A.
The +ve supply comes off the battery connection at the starter through a multi-plug, 40A inline fuse, through the ignition switch, back through the multi-plug to the glow plug heater rail a run of around 5M all in 2.5mm cable.
This cable size seems very small, to the point where a 5M run at 30A will drop the calculated voltage by over 2V, in my case nearer 4V?
Does anyone have any ideas on increasing the voltage and therefore current flow to the plugs? I could increase the cable size to reduce the volt drop but I guess Beta have limited the current for a reason? But it seems I have lost a couple more volts than I should have.
Any ideas would be great thanks
