Bargebuilder
Posts posted by Bargebuilder
  1. 6 hours ago, blackrose said:
    I had a Dometic 3 way fridge on my boat connected to gas until quite recently. It passed 4 separate BSS inspections over the years with different inspectors.
    As usual on this forum most of the doomsters & gloomsters are people who have no firsthand experience that are just repeating things they may have heard.
    But yours was an appliance installed before any change of regulations and as such would be exempt.
    Will the BSS pass a piece of equipment that it's own manufacturer recommends should not be used on a boat?
    My last BSS inspector refused to pass my boat because it's carbon monoxide detector didn't have a yacht symbol embossed on the back: he insisted that only CO detectors specifically recommended for use on boats were acceptable. I argued that the detector didn't know where it was and CO was the same wherever it was detected, but he refused to issue my certificate until I sent him a photo of a new detector with the symbol visible on it. I thought he might be wrong, but complied with his request.
  2. 16 minutes ago, MtB said:
    Thanks!
    I see my post was confusing. By writing "just as you have done", I meant just as you have just changed my mind for me with your informed opinion as a user and owner:"
    And yes I'll keep a weather eye open for a Classic 30 and probably buy one. Is "Classic" a brand name?
    I understand Classic to be the brand. I have seen one other like mine but a handful of aft cockpit versions that are 26 feet long. Mine is a 1984, so I assume that they are all of a similar vintage. Alas, the manufacturer has disappeared and I don't know any more about them. Mine has a Vetus 20hp which is a Mitsubishi, but that is much younger than the boat. It's the weed hatch which sets them apart from the majority of GRP cruisers, but it's certainly handy.
    They are tough little things. The picture is of us doing a short coastal hop. Any self respecting narrowboat wouldn't contemplate such conditions, but a GRP cruiser, with a brave skipper just might!
  3. 7 minutes ago, cuthound said:
    Possibly yes, but given that until the mid 90's the vast majority of boats that had fridges were of the 3 way type, running on gas, there were very few incidents (none that I recall) of boats exploding because the fridge pilot light ignited gas which had accumulated in the bilge.
    However the point I was trying to make is that the manufacturers don't recommend fitting 3 way fridges into boats, because they have no control over the type of boat, so give blanket no fit advice.
    These fridges need to be kept level plus or minus a few degrees, and a typical narrowboat will be more stable than a motorhome when both are underway.
    The angle of the fridge is important to its operation, but I suspect it's the gas aspect that the BSS are concerned about.
    Did the old fridges have flame failure devices? If not, an extinguished pilot light could allow quite an accumulation of gas in a bilge.
    The BSS inspector would fail a gas system thats bubble detector bubbled the equivalent of the gas consumed by a fridge flame.
  4. Just now, magnetman said:
    Yes, as I said, one of the techniques for retaining full control is to keep way when it's windy. It's not difficult; try it.
    3 minutes ago, magnetman said:
    This is where the confusion lies.
    No bias against GRP.
    Implication being GRP cruisers handle poorly in windy conditions.
    It handled very competently last summer when we cruised from Sharpness to Portishead under the Severn Bridge in 12mph head winds.
  5. 1 minute ago, MtB said:
    I'm perfectly capable of changing my opinion 180 degrees in a heartbeat when presented with information showing I'm wrong. Just as you have done in the thread since I posted that.
    Hence my question, but your response leads me now to doubt that you have one.
    I am not aware of changing my opinion at all: with an understanding of the characteristics of one's cruiser and a little practice, GRPs are easy to handle in all conditions, that I've experienced anyway.
    If you have a genuine interest rather than just trying to goad a response, my cruiser is a 'Classic 30' centre cockpit. Similar to a 'Viking' but with an inboard engine.
    I hope you have changed your opinion and perhaps one day try cruising in one.
  6. 4 minutes ago, MtB said:
    May I enquire exactly what GRP you have please?
    I quite fancy getting one the same, given all the good stuff you've written about it.
    Thanks!
    Since you wrote this about GRP cruisers earlier in this thread, I don't think I'll bother humoring you:
    "Price. Nothing else, if you are canal cruising. Bloody cold in winter, hard to fit good heating into."
  7. My mains fridge, when I first turn it on, drops from 21-23⁰C to it's working 4⁰C in about 15 minutes. I have a digital thermostat to control it so I can watch the temperature drop as I sit drinking tea.
    Is it possible that your unit needs re-gassing?
  8. 6 minutes ago, magnetman said:
    A boat which can't be controlled during windy conditions is badly designed if it is intended to be used on waterways with a speed limit.
    I have never come even close to losing control of my GRP cruiser, in any conditions. I have however seen many steel NBs get into a terrible mess. It's much more to do with the skipper than the vessel.
  9. 6 minutes ago, cuthound said:
    They allow 3 way fridges to be installed in motorhomes which I would have thought would move around far more than a typical narrowboat.
    Is the reason not because of the little gas flame? Boats do allow the accumulation of butane in the bilge, whereas it can escape from motor homes quite easily.
  10. 30 minutes ago, Alan de Enfield said:
    My GRP cruiser weighed in at 11 tonnes on its last lift out. (The engines are about 500kg each)
    At 5-6 knts there is barely a ripple behind her - very aquadynamically shaped - no great pile of water being pushed up by a blunt bow.
    To make a slightly fairer comparison, I was only refering to GRPs with a beam of 6'10", hence the 2 tonne figure; possibly almost 3t for ones with an inboard diesel.
    Moored boats surge backwards and forwards because passing boats move a volume of water out of the way as they pass. A GRP cruiser will move up to 3 cubic metres of water, a NB up to 18m³ and a broad-beam maybe 25m³ or more.
    Those narrowboaters who accuse GRP cruisers of passing slightly faster than a narrowboat might at tick-over, should first look at their own moored boat to see if it is actually moving any more than it would if a slower NB went past; it probably isn't.
    GRP cruisers often travel at the full 4mph allowed, because they can without being a nuisance; they do so without causing a wash damaging to the bank and they certainly shouldn't move a properly moored 18 tonne narrowboat. Of course they would if they passed at 6mph!
    One thing is for certain, an 18 tonne narrowboat passing a moored GRP cruiser at 3mph will cause more surging movement than would a 3 tonne GRP cruiser passing an 18 tonne NB at 4mph.
    It is much safer for all parties if a GRP cruiser doesn't slow down too much in windy conditions, because that's how they retain control.
  11. 35 minutes ago, cuthound said:
    The main advantage of a GRP boat over a steel narrowboat on a canal is the ability to charge past moored boat leaving a huge wash and not get shouted at... :)
    It's certainly true to say that a grp only displaces 2 tonnes of water as it passes moored boats, whereas a large steel NB may displace 18 tonnes of water. It is therefore true that one can pass a moored boat in a grp cruiser faster than can a heavy NB without causing any surging, forwards and backwards of that moored boat.
    Yet another reason why grp cruisers are not only better in many ways for their owners, but also potentially for other boat owners.
  12. As you continue on down the Nene it isn't much better in places. The problem there is blanket weed/algae streaming out in 20 foot long cords that are impossible to avoid and wrap around the propeller tightly, eventually covering it entirely and resulting in zero thrust. A burst of astern has no effect whatsoever, so regular visits to the weed hatch are unavoidable.
    That was mid June, so they may have cleared it, or it might be even worse now.
  13. 4 minutes ago, Blaster said:
    I started this topic asking recommendations for a 12v fridge. I also explained why I stay away from 240v fridge running 24/7.
    Just buy a  230v fridge and an 800w quasi inverter dedicated to it, plus a 12v thermostat and relay. The combined cost will be a fraction of the cost of a Shoreline 12v fridge, will be, in my experience more reliable and long lasting, and will also consume fewer Ahs over a 24hr period.
    Yes, I have done both and couldn't have been more disappointed with the Shoreline product.
  14. 3 minutes ago, Tony Brooks said:
    In my view, the difference in electrical consumption between a 12V fridge and a quality mains fridge plus quality inverter is likely to be marginal and not worth worrying about.
    I agree, but if every Ah is critical, such as over a period of gloomy midwinter days where you are reliant on PV, just wire up a dedicated inverter to only come on when the fridge calls for cooling. Doing it that way, there is no quiescent current loss to worry about.
    You may have a big inverter to power other boat items and if it's quiescent demands are tolerable, then just use that as previously suggested.
    If Amp hours are in very short supply and you are only using 'mains' for a TV and a phone charger, then just use a tiny inverter for those items to minimise the quiescence current loss and have a dedicated inverter for the fridge. I did this in order to avoid using a generator, preferring instead to rely 100% on solar power.
  15. 2 hours ago, Jen-in-Wellies said:
    They do seem to be able to regularly pick up job lots of second hand panels that have been replaced on commercial solar farms, or buildings. These look very good value and will still have decades of useful life in them.
    I bought from Bimble 4 such used panels and they were in immaculate condition and have worked faultlessly  and to specification for the last 9 years. I also bought from them the charge controller, but bought the cable, MC4s, isolators etc from eBay. It's a simple diy electrical job, but worth the few pounds to buy the correct MC4 cable crimpers.
  16. 16 minutes ago, pete.i said:
    Having owned both, 2 narrowboats and a GRP cruiser, I prefered the cruiser although all the disadvantages posted applied. It was nimbler, it was nicer to sit in and drive and the cabin was better although smaller than both my narrowboats. I wasn't a live aboard and I don't think I would have considered living on my cruiser. The cruiser was a lot cheaper to buy than both my narrowboats. As for windy conditions, I had problems with windy conditions with all my boats. If the wind took the cruiser when trying to moor up it was much easier to control than both my narrowboats as it was very much lighter.
    I 100% agree.
  17. 15 minutes ago, BEngo said:
    Most items can be removed from the prop with a combination of a sharpened  boat hook and some practice.
    I'd check that this is possible before buying a grp without a hatch: with an aft cabin, there is no safe way to hang over the side anywhere near to the propeller to give a suitable angle of attack with a boat hook or similar. The only option for using a boat hook would be to use it from ashore and we have travelled many a river where shore access is impossible.
    In the Nene this year we went through a stretch that was covered in thick blanket weed. After a few hundred yards the propeller had been turned into a green blanket weed football, with only the very tips of the blades visible. Even with a weed hatch and a very sharp serrated knife, it was a real struggle to clear the prop.
    If you are river cruising for holidays and leisure and like to venture into easturies and the sea , a big GRP works quite well but they are not cheap.
    GRPs are certainly not best for winter cruising due to their often wonderfully large windows and lack of insulation, but it's inaccurate to say that they are difficult to heat, because usually the cabin volume is small and low output heaters cope very well indeed. I have a Taylors diesel heater with a 2kw output and zero 12v requirement, plus a Chinese Eberspacher knock-off that can almost instantly produce 2-5kw, and we are never cold.
    37 minutes ago, blackrose said:
     it's not much fun being blown all over the river or canal on a gusty day in light GRP boat that won't hold its position in the water.
    Dare I suggest that you don't regularly cruise in a grp cruiser. We have covered nearly 600 miles this summer alone, including on days with high winds, when we've hardly seen steel narrowboats moving at all. Yes, they are light weight, but they also usually have a 'v' shaped hull profile and a shallow full length keel, which actually grips the water surprisingly well. There is, as with all boat types, a technique for close quarters boat handling, but it's easy to pick up and losing control in windy conditions has never been a problem for us; ever! In addition, the power to weight ratio is usually much higher than with a steel NB and a GRP is much nimbler and able to change orientation and speed quickly in order to avoid a collision that would be impossible to avoid in a 70' long 18 tonne NB.
  19. 45 minutes ago, peterboat said:
    Unless Shoreline have upped the quality from 10 years ago I would not buy one. Also they were all the wrong way around, freezer on top?
    You may find that the cheaper made fridge freezers with the freezer part on top only have one compressor and one evaporator that is in the freezer part. The freezer thermostat should keep that compartment somewhere near to -18⁰c, and the freezer supplies cold air to the larder section via a vent in its base. The thermostat in the bottom larder section, if it has one, operates a damper in the vent that controls how much cold air is allowed to escape from the freezer to the larder section below.
    If Shoreline use such a system it doesn't surprise me. I had a Shoreline 12v fridge for four years; first the thermostat packed up, then the whole thing went the same way. Mine, at least, was vastly overpriced rubbish and I wouldn't ever have another one.
