Posts posted by Russ9294
Because your on 3G and I found in some places you can only receive 4G this only Happened ones
I’m on 3 network had a problem most of the time we’ll last 3 years but under Mobil date I turn my phone onto 3G only I have no problem now with the internet now I can make phone calls most of the time I think 3/4 G are looking for best signal
but remember to switch back to 4G when you go out
On 02/01/2021 at 23:14, dmr said:
Three have always had a good network and the best prices, but I think because of this they have always run their network at or just over capacity. They are still the only one to offer proper unlimited broadband. Since the plague set in internet usage has doubled so I assume Three are now a tad overloaded. Some days here it just stops dead for an hour or two.
..............Dave
I have 3 network I run on just 3G turned 4G off it’s a lot faster because 3 & 4 are not both looking for the best signal
Thank you very much I will try that
I'm after picking your brain setting up Victron BMV-700 it asked amp hours my batteries are AH115 each X4 do I put in 115 or 460 because I have 4 batteries Thank you for helping
Alarm setting I have my low voltage power setting at 11.4 is this ok 115ah batteries x4
Best
leisure battery I have AH 115 is it best to have high Amp hour like 200 a/h
On 09/10/2019 at 18:47, The Dreamer said:
Evening all,
We are planing to set out as continuous cruisers, from March. The expectation is to cruise all summer, work all winter, with the aim of doing the whole network in three years. Will probably take winter moorings, either CRT or in a marina in the depths of the cold, and obviously will slow right down for the rest of the period we are working. However we need to keep a car both for work, but also to keep in touch with aging and sick relatives. Really don’t want to leapfrog a car all the way from a Brum to Bath, and back (for example), and am happy for one of us to take the train to pick it up when we need it. My question is, is there anyone else who does this, and if so, what parking arrangements do you have?
I piggy back a smart car ? with folding bike very easy to park no problem yet 3 years on the boat and I drive back home that is 4/5 hours away
Thank you
Hi I am able to remove the glass in my potholes 13.5” i’m trying to find a way of storing them by fixing them to the wall beneath the porthole I’m trying to find fixings to hold them there does anybody have any ideas
Thanks
Thanks
I’m looking for wooden to match the rest of the boat
On 13/03/2018 at 22:32, Traveller said:
My hatches slide on an inverted L topped with a flat brass runner. In this country it rains now and again () and water runs down the flat surface of the runner under the hatch and in to the cabin. Any suggestions on how to fix this? Had thought of cutting a strategically placed slot in the brass runner.
Thanks
Colin
I have the same problem so I’ve drilled 8mm hole in the brass runner and countsunk it it works very well
Yes
Thank you I have rang and found them very helpful going to Sign up today
Hello can anbody recommend boat Mail I’m thinking about joining them
thank you
Iv google the broker very good report I've had sea boats before so just founding out if it's the same
Thank you I will talk with the surveyor about what you said
I've had the engine running & next week taking the canal boat for a small run just to check the temperature and everything else is okay
Thank you very much I will have a good think about it
Thank you I never thought of it like that it's nice to have an honest answer
Hob Extractor fan
Hi did you put inline fuse from light to fan
