Big Chris
Posts posted by Big Chris
17 hours ago, Tony Brooks said:
A newish boater may get tiller vibrations by trying to go too fast for the canal depth and profile o try throttling back a little.
Tony, Thankyou, I have owned this boat for 12 years and am quite experienced. I acknowledge the relationship of
speed and depth of water. I have checked all the basics re condition of the prop, fouling, and shaft wear. This is an ongoing issue.
5 hours ago, Peugeot 106 said:You can go round a marina trying various tiller/rudders at rest but it is difficult to feel anything. In terms of simplicity trying my method of altering the weight is easiest with lead to try first. My tiller was hollow. The only hollow one i’ve ever seen. The cup on the skeg is an easy refurbish if you have a decent welder and the boat is out of the water. Replacing the top bearing will need the tiller rudder post separating.( Big hammer, puller and blow torch). Once you get into stern gear if you think the prop is in the wrong place you may need to shorten the prop shaft or get a longer one. This isn’t too expensive but if you have to take the shaft out the boat you will have to be out of the water. I do most of the work myself but am aware that if you have to lift out and pay somebody else that the pennies soon add up
In my case we fitted a new engine and I have no idea if it vibrated with the original engine though I was told it did. We also altered the pitch on the propellor.
I’m not sure about altering the rudder. The speeds are so slow and the arrangement so crude that I doubt it would make much difference. It’s not a racing yacht and I doubt that the builders pore over rudder designs.
MtB’s plan is definitely best as a first step before trying anything to get a feel but beware of taking advice off“knowledgeable” people. I was pissed off when I refurbished the cup on advice and it made no difference even though the boat was already out for blacking.
it could be a damaged skeg/ rudder but i’m not sure how that would make it vibrate though I would expect it to feel different
I am pushing the tiller weight theory hard as it was simple, quick and cheap to diagnose but only as it was definitely my problem and solved it but recognise that what worked for me may not be your problem. You could quickly try it and eliminate this as a cause of your problem
you have my sympathies as ours is very pleasant now and it’s not as simple to solve as I at first thought like everything else on these boats!
In the first instance suggest you hitch a ride on a few similar boats as suggested. Maybe hang around a lock with your thumb out
Meanwhile steer with your hips/tummy where possible!
Let us know how you get on.
good Luck
Many thanks
I read somewhere that trimming around 30mm from the rear of my rudder blade may reduce tiller vibration. Any advice would be welcome.
Thank you all for your help..
Are the town centre moorings in Banbury restricted due to the extension of the shopping centre?
Many thanks
Are there restrictions within the BSS regarding the height above floor level for 240 volt socket positioning ?
Tony, many thanks.
I confirm the thruster is electric. It has misbehaved almost from new and now has become a pain. I will investigate the items raised. Excessive use is not my main problem as I only use it for up to ten seconds at a time.
Should I decide to replace it, could I fit another make of motor directly to the drive shaft or has the whole lot to be replaced?
I have never been entirely happy with this thruster.
Regards
Chris
I'm not interested in the BSS. I want to know about BCS bow thrusters please.
- 1
Has anyone encountered issues with BCS bow thrusters which either keep cutting out or stay on.
Vibrating tiller
Checked all those.
I've had the boat from new.
