Alakefic
Posts posted by Alakefic
Thanks Tony
6 minutes ago, blackrose said:
How does one change a battery without actually disconnecting it?
Obviously meant charge ,
Hi
it’s a small smart charger 240v which will run happily off my genset or the hook up point, the battery’s are 1.5 M from the point inside the boat where I can pick up the pos and Neg, both cables are 16 mm tri rated .
Hi All
is there any problem with changing my 3 batteries without disconnecting them?
and is it possible to charge from a neg and pos point inside the control panel?
from inside the boatthanks
Alakefic
Ha I get it! You mean we’d be a pain in the a**e. However, prejudice aside, the question was what problems might we face but thank you for you response
Hi Alan, Mrs Alakefic here. No not only the K&A but for various reasons, we’d like to do that one in the early stage of our new venture. Understand it’s busy but as I say, we’ve got time on our side, so wondered if anyone had any input on potential problems. Cheers
Hi all
could do with any advice.
not new to boating but new to the idea of Liveaboard
we are considering buying a 70’ wide beam and have all the time in the world to cruise her. We would like to navigate the Kennet and Avon and, on paper, all looks good with the lock sizes etc but do any of you good folk see things differently?
Hi Blackrose ,
Thanks for youre advice .
All the slippers, outlet,and air vents are all plenty high enough, the draft is still around 2ft 9in/10
So i really don't have much option to ballast and extend the draft.
Meant scuppers....
3 hours ago, blackrose said:
In general I'd agree with what others have said, if the amount of ballast removed is approximately equal to the amount of steel overplating added and the overplating was uniform on both sides. However, it would be very easy to remove too much ballast without realising and make the boat too tender & unstable and a visual check alone will be very unreliable, so you should do a calculation too.
On most canals you shouldn't have to worry too much, but the situation could change if the boat is ever taken onto rivers with a decent current, small waves or the wash from other boats. Even high winds might make it unstable if you've removed too much ballast.
With all the ballast removed , the bow is still higher that the stern, but i being a shallow v hull it has increased the wobble....😂
Yeah seen that earlier ...vents are fine.
Thanks
Hi all,
Quick question, I have an overplated 30 foot V HULLED NB,
6mm bottom and 4mm sides up to gunnels It has a 3foot draft so is sitting to low , I have taken all the ballast out, about 700kg and now sits 3inches higher, is it ok to run with no ballast?
Hi Mark
Thanks for the info.
Just signed up.
thanks Tony much appreciated.
nigel
Hi Guys
I have a P2r gearbox that requires overhauling and bearing replacement, im having difficulty in finding the split sleeve astern clutch bush, there are no dimensions of this in the parts manual but have measured myself as follows: ID 1. 5/16 OD1. 7/16 Length 2. 3/16
Any ideas where I can get one or possibly manufactured would be appreciated.
cheers
Nigel
NB Alakefic.
Electrics. Where to start.
in Boat Equipment
Have a look and have a read of Tony’s electrical course……..
it’s all there , that’s how I did mine
