florencethedog
Everything posted by florencethedog
  1. Good thinking, I’ll check it before I recommission it lol thanks
  2. It is confirmed as a pump out tank and I’ve ordered the brass fittings and pipes to replace what’s in pictures above now my next question if I put a manual pump out toilet in, would it pump too the tank which is 3m away with a 0.5m rise or do I require a electric pump type one thanks
  3. Hi guy’s As the title says, we are after a decent new sofa bed that will fit through either set of doors on our narrow boat. cheers stav
  4. Hi guy’s As the title says, we are after a decent new sofa bed that will fit through either set of doors on our narrow boat. cheers stav
  5. I’m there tomorrow, so will get a few pics were would I get the brass fittings from so I can at least stop the water getting in cheers
  6. There is a thick grey/brownish sludge in it but no smell. could it be use as a pump out tank or would it be totally different fittings to the shell cheers
  7. It’s got two big fuel tanks in engine bay that are shot but look original with the brass filler cap? boat was built in 1974 and the tank has a hatch on the top where the step would sit? cheers
  8. Hi all, i,ve completely striped my old boat out. As you go in through the doors you now step on to a full width steel tank with a large pipe running into it on one side and two smaller ones other side plus a pipe connection point on the upper face of it. Would this be a pump out tank? the holes above on the shell it’s self are just taped over so the pipes aren’t connected too anything and leaking water. cheers
  9. Hi all, is there a tow path between ferrybridge power station and the junction of the new canal cheers
  10. As you said the helpful person was wrong, had a full survey done and no major problems cheers stav
  11. Cheers, We have just put the boat in the water and the cap went after afew miles and compared too the other cap this one looks new. I await an expert to guide me lol Thanks stav
  12. Hi guys, im after the best place to get some replacement header tank rubber caps for our 1.5 bmc and is there anywhere I could get a full set of hoses for the old girl well just for spares. cheers stav
  13. hi, a marina resident expressed their concern cheers
  14. Hi guys, me and my family are new to narrowboats.we have bought a boat with a replated hull but have been told the rest is in a bad way (abovethe waterline)We had no survey done as we thought it would be good to go. Can there be much wrong with the rest of the steel work? Cheers
