Posts posted by Tuttifruity
Hi everyone,
does anyone know if Tinsley Locks on the Sheffield/Tinsley canal have been repaired yet? They were supposed to finish on the 4th, then the 5th, but I haven’t seen an update saying the locks are ok now. I need to be at Thorne by Monday, so looking dodgey
Help! I’m having trouble getting started with my Barrus Shire engine, when turning the key the engine didn’t turn, there wasn’t a click or anything. I knew the starter battery was very old so replaced that, and cleaned any connections I could see back to bright metal. I tapped the side of the starter with a hammer. Still nothing, so thought must be the solenoid/starter motor. How hard is that to get at! I scrunched down and also tried dangling upside down to get a look. I can see the side of the starter, but felt around it and couldn’t find the solenoid, but did find a thin red spade connector unattached to anything. Again I felt around but couldn’t find anything it could attach to.
Can anyone offer any advice? It would be much appreciated 😒
Thanks for this, I’ll give them a call 🙂
Cheers, will do. I had the boat booked into Castleford a few years back, but on route the boat broke down and the marina that took it in for repairs cost so much I couldn’t afford to get the boat blacked!
I walked past a couple of weeks ago, and I’m glad to hear that you’re still trading and best wishes for the future
Hello everyone,
I’ve returned to my boat in Sheffield after a long illness and COVID restrictions and she desperately needs blacking. When walking the dog along the canal I saw that Finesse boating is all closed up and no new boats, so I presume they’re not trading or have moved. It would be handy if we could use their slip way to take boats out of the water for maintenance without having to go all the way to Stanniland Marina. Perhaps Victoria Quays management could rent it and make a few bob? What do you all think?
Thanks everyone. We’re away from the boat at present due to imminent arrival of grand baby so will get details when back
The electrics on our boat look like spaghetti junction, and we don’t understand why when we’re plugged into the landline, the sockets only work when the inverter is switched on. Is this normal?
The other problem we had was when we changed a standard 12v ceiling light fitting with what looked like a very similar one, the bulb only lasted a couple of days. The wiring on the new one was a lot thinner than the old wiring coming out of the ceiling. Do we need to put thicker wire in? All advice would be greatly received
At last got some photos and thanks to Peter for coming down to see the boat, and he agrees I’ve been ripped off. I’ve included one photo of the stern gland, and I got a tight hold of the propeller through the weed hatch and it was rock solid, no play whatsoever. There’s also a photo of the fabricated support brackets that the Boatyard did.
Great! We’ll get to the boat about 3pm, and we’re moored just outside the swing bridge. We haven’t painted the name on yet, but it’s a dark blue boat with an orange life buoy on the front, and I’m Chris. Look forward to seeing you Pete
That’s really kind of you, we’re in Victoria Quays, and we’re going to the boat tomorrow for the weekend. Someone was parked up in our mooring last time we were there, so we’re hoping to move it back. Hopefully nothing will drop off or the water won’t stop coming in when I turn the engine on!
When the boat overheated, there were a lot of blue fumes in the engine bay so the chap checked the valve clearances as the engine does clatter, but he said he couldn’t adjust them anymore, the engine is very worn. He tied the boat up and had it running in gear for a while to test if the water went down again, maybe he stood there for 5 hours? ? the yard charges £40 an hour, and with us leaving the boat with them for a week, im not sure how long he spent on it, but it does seem excessive, 19 hours.
i went on a RCR course last year and learnt the basics, I’ve changed the oil, fuel and air filters, and know how to change the belts, but yes I definitely need to learn more. ?
- 1
Unfortunately, he was the engineer who the River and Canal Rescue sent
Sorry for late reply, I’ve been away. I put the antifreeze in separately, should I have mixed it with water first? I looked at the invoice again and they have done other things, I didn’t know the pipes had no support brackets as I didn’t know they needed any ?. The pipe to the expansion tank looked ok to me but I’m a relatively new to understanding boats. One thing I didn’t mention was when we were driving past Tully’s boatyard in Rotherham, all the nuts fell off the stuff box. Fortunately Tully’s had a slip way and I managed to reverse the back end onto it so we didn’t sink, and the Canal and River rescue bloke put it back together. From there we managed to get back to our mooring. The other thing is the boatyard put in lots of water but no antifreeze so I’m going to have to drain the damn thing again to get some in! ☹️
Hmmm, this has got me thinking about my latest probs with my stern tube and propshaft. The boatyard that was sorting out overheating and leaking water said that both of these needed replacing, but they are only 2 years old and the engine was realigned at the same time. We had a large volume of thick polythene wrapped around the propeller and also hit a submerged tree before we arrived at our mooring. I wonder if this would cause damage to the stern tube and propshaft?
Thanks everyone for your advice. Sorry I didn’t get photos and we’re away from the boat now for 2 weeks so I’ll get some then. They didn’t take the boat out of the water in the end because I asked him if we could black it at the same time if they did. They did change a couple of hoses and secured them better,but what you said, Neil, sounds like the answer, an airlock in the system. When we set off, the oil had recently been changed and I did add some water and antifreeze, but the boat has stood since January. When we occasionally ran it for a couple of hours tied up, it didn’t take much grease to stop a slight drip, but on route I did notice I was having to add a lot more. On the invoice they have charged for repacking, and the oil light doesn’t come on anymore ?
When I’m back at the boat I’ll grab hold of the propeller as you suggest Iain to see if there’s any play.
One of the lads next to our mooring whose gone tootling for a while knows a good mechanic, so we’ll grab him when he’s back.
Hi everyone, we recently set off from our long term mooring in Sheffield, heading for the booked dry dock to black the boat’s bum and some other jobs, and a bit of a relaxing cruise for a few days there and back. It was not to be, we were at the beginning of the Keaby when the boat started to overheat and the oil light came on. The engineer who came out kept pouring water in but it kept disappearing. Long story short, he thought there might be a leak from the skin tank and it also needed a new oil switch. We managed to limp to his boat yard where it stayed till he came back from his hols. There wasn’t a leak from the skin tank and a new oil switch was fitted, but he said the boat needed a new stern tube and prop shaft as the water poured in when the engine had been running. We hadn’t had any problems with this before hand, and both these items had been replaced only 2 years earlier along with 4 new engine bolts. We haven’t done a lot of miles since and the work was done by a highly recommended chap. Can anyone suggest what’s happened? ps we spent a fortune at the boat yard for the repairs and can’t afford to black the boat now ☹️
Thanks everyone, I'm changing the connection with another and tightened up the boats socket with some washers as it was a bit wobbly. It's peeing down now and I'm going out for the night so will connect up in the morning ?
Hi everyone, I'm not very good with electrics and we've been stationary for a while in Sheffield using the onshore power. Unfortunately the cables stopped working and the batteries went flat, and when I looked at the galvanic isolator connection, the neutral socket has melted a fair bit. What s wrong with it? Help! ?
Phew! Thanks Sam. One day I’ll be an expert in all things boaty, it just might take a while!
Hi everyone, I checked the air filter on my Yanmar engine and found in the bottom of the screw off plastic base, about a tablespoon of a black liquid. As I’m new to servicing a boat engine, what could this be?? It’s probably nearly 2 years since the filter was changed
Hurray! Arrived at the lovely Victoria Quays about 3pm. Nearly didn’t set off this morning as it was howling a gale at Eastwood but once we tested the run to Rotherham lock it wasn’t so bad.
thanks so much for everyone’s help, and thanks to Dave and Nigel who helped us up Tinsley Locks, what stars!
- 4
Hurray! Have spoken to Dave and he’s hoping to get us down the locks on Wednesday morning depending on the river levels so fingers crossed again!
Tinsley Locks
in Waterways News & Press
I tried phoning the lock keeper today but the number I have didn’t ring out. I tried several times and checked the number on line.
do you ring 07710 175488 to book?
