Tony
Thanks very much for the swift reply,
I have the whale pump on the bench for testing ,and I know that switching the the white and Brown over works OK
To add to the puzzle I have a Seaflo auto 750 ,which I connected with the WHITE going to the MANUAL, switch
The BROWN going to the AUTO terminal ,as per WHALE wiring diagram it works good , unlike the WHALE 650 ,unless I swap the wires over like you suggested
The 3 way switch I have p/n 10296-12 quite common on e bay
one more bit of info , the previous new WHALE auto 650 I had ,I was wired like you suggested
it lasted 3months and died ,pumping only rain water ,Hull is grp no leaks, Coincidence ? maybe
Have contacted WHALE info and awaiting their reply ,which I will share with you and all
Brian F
