bottle
Days Won
2
Posts posted by bottle
Simple answer yes.
Something to do with diodes and things, hopefully the experts will be along soon.
For good advice, lots of info and aerials etc.
no connection other than a satisfied customer/
Also if you have an android phone look for "UK aerial alignment" on Play Store.
It will give location/direction of transmitters, strength and whether horizontal or vertical orientation
An amplifier will only 'boost' what is available, if nothing available it will boost nothing, if crap is available it will boost crap.
If getting break up, check what is between the aerial and the transmitter, trees, especially wet ones, will block the signal.
Hight of aerial can also have an effect but sometimes not in the way expected, have had it where by lowering the aerial it has picked up a cleaner signal.
Also check all connections are clean and good.
ps. I also have a log periodic aerial but sometimes it is just impossible to get a signal, depends on location.
The one and only way to be sure of counting the amperes in and the amperes out is an ampere hour meter and this important point the measurement must be at the batteries. ie, a shunt as the last connection to the batteries. (Usually the negative)
My previous MPPT controller counted the amperes but only those going to the batteries not those leaving.
If for instance I had a 5amp load and the solar was putting out 10 amps then the batteries were only getting 5 amps, the other 5 were supplying the load
Even then, as mentioned you need to put back more than you take out.
just someone trying to decide how much I am using and how many batteries I need to make my life comfortable.
It is not so much how many batteries (amp.hr capacity) you need but how much capability, the charging system has of replacing your usage.
Then a decision on the size of the bank can be made, it would obviously be not a good idea (cost) to have a 1000 amp.hr bank and only use 50 amp.hrs. but when you get to 100 amp.hr battery bank with 50 amp.hr usage then although possible, it would 'work' the battery hard.
Increasing the battery bank to 200 amp.hr and still using 50 amp.hrs the batteries would 'work' less hard and also be maintained at higher SOC.
Instead of battery bank down down to 50% SOC then the larger battery bank would be 75% SOC so being kept at a higher SOC which batteries like.
You would still be using 50 amp.hrs and have to put back more because of charging losses.
Thanks for all the good replies didnt think id get such replies. I am new to tge boating scene so please forgive any questions i have asked that are not up to your standards. The pics i posted where the only ones i had when i go today ill take some more. I would definatley say it is a mud hopper. Thanks again.
It's not about standard of questions, it is about standards of answers.
Many have answered your questions and some have been a bit blunt as will be mine.
You have ignored good advice, the boat yard.
Sorry to say you have gone ass about face to this.
I really do want all the warnings about what you may find, a metal boat with concrete ballast that could/maybe actually a concrete bottomed boat because all the metal has rusted away.
Good luck and prove us wrong.
ps. keep asking questions, we can and do help, many new and old boaters
Boats have got thicker as time has moved forward, if the thickness now, is the same or as near as dam it to the original then no problem with the boat.
One proviso the insurance company may be a bit 'jumpy' and demand surveys on the thinner ones and probably much explaining about it being original will be required.
There were 'Lost' notices on the Gloucester, Sharpness a few yeras ago, I wonder if it is the same tortoise.
I would explain the reasoning behind keeping one bank and not two.
Take a bucket of water and you need to use half that bucket
Now take two buckets of water and use the same amount of water, that means each bucket is three quarters full, instead of one being half full.
Batteries like to be full and if you empty them less and refill them fully they will last longer (life)
The above, that know, could described it better and more technically but I understand it this way.
A semi chined hull, ("V" shaped) Replated to surveyors specification in 2010. Blacked 2013.
Due a blacking and with that hull shape, there is usually a premium in cost and not all yards/marinas can do it.
All you need to know and more: http://www.aerialsandtv.com/
No connection, other satisfied customer.
As long as it's naked - I'm in
Richard
You or the photographer?
Using canalplanac: plan a journey, left hand column selection.
Using default settings.
This is a trip of 105 miles, ¼ furlongs and 121 locks from Napton Junction to Napton Junction.
This will take 60 hours and 21 minutes which is 8 days, 4 hours and 21 minutes at 7 hours per day.
It is 7 hours a day for eight and a half days.
A weeks hire, you would be working hard and have to keep going virtually non-stop.
In theory it could be done but probably travelling for at least ten hours per day, with no hold ups, delays, breakdowns etc.
(all settings travelling times first day, last day etc. can be 'tuned' in canaplan) have a look.
Your holiday/workout.
Roger!
Would that be the cabin boy?
Hillmorton wharf, behind the Hungry Horse (pub) on the road to Crick.
May have space.
One of my links was not welded, only found out the other day when the front button was not hanging properly.
Pressure and flow
Just thought this may help as well.
for availability there are other similar available.
Can I pose a question 2 13kg proper sold as such refillable gas bottles fitted & connected to a remote filler by the company selling the bottles who have the proper certification ( in this case a Camping Car ) You connect to the GPL pump in the same manner as a GPL fueled vehicle, the bottle cuts off the fill at the required 80%.Is it illegal to carry out this task in the UK, the reason for my question is I planned to visit the UK using my camper, but if I cannot get GPL/LPG I guess the trip is off I have filled in France, Spain,Portugal, Italy; Croatia, Slovakia, Greece, Turkey, Morocco, without any problems am I going to be shot down by the country of my birth.
It is not illegal but some garages/supermarkets do not understand the difference between purpose designed refillable bottle systems and just 'ordinary' gas bottles and have put a ban on 'gas bottles' the poor attendants only see bottles and do not understand the difference.
See post #16 and for more info try one of the Motor-home sites/forums, do a search as it comes up quite often.
http://forums.motorhomefacts.com/index.php
http://forums.outandaboutlive.co.uk/forums/Motorhomes/5/
http://www.motorhomefun.co.uk/forum/
You may have to register but not to search and look.
But that's still running the big engine. Does not provide an auxiliary. I have no problem going slowly
Lynch motors are belt driven afaik
Would need a plummer block each side of the pulley I expect
A Lynch motor is an electric motor that can drive a belt/pulley
The generator will not mechanically drive the boat via a belt ( the bearings etc. would probably not take the load.) it will need an electric motor, the generator could be anywhere in the boat.
I think Loddon's idea of a trolling valve is worth a look.
Refilling will be a problem.
Refilling opportunities are getting less and many garages are not stocking as there is a reduced demand, less vehicles running on gas.
Many Motor-homes have a purposely designed systems using bottles and some/most garages and supermarkets will not let them refill.
Those with purpose built under-hung tanks are usually OK but even them some stations are 'awkward'
Well it's been two days since the original post, signed off one minute later and not been heard of since.
i think this thread can die in peace.
I'm out
Whilst September can be a good month for weather, it is possible that the Severn could be 'in flood'.
So a contingency plan will be required.
Battery conundrum
Technical answer from WotEver, me being a simple soul would say think of a bucket and water.
When the bucket is new it can be filled to the top but as it ages, gunge etc. collects in the bottom, the bucket can be filled to the top still but does not have the same capacity.
The bucket is full but...
The Smartgauge will still tell you the
bucketbattery is full but it does not know how much gunge is in the bottom.The Smartgauge will still tell you a true usage of the the available capacity.
When you notice that the batteries do not last as long and you are charging them more often (same usage) then it is a good indicator that the batteries are on there way out.
