Barroca Grande 2
Posts posted by Barroca Grande 2
You will all be thrilled to know that the changeover went brilliantly. Took longer than expected as when we removed the batteries and lifted the box we saw what a pathetic attempt Brian (spit spit) had done with supporting it. As expected when I had my shunt at West Stockwith lock the box had shifted but luckily wasn't actually pressing on the pipework that went over the upstand between the engine bilge and cabin bilge. I had been very worried about this. What had happened was the piece of wood balanced on said upstand was only held inplace at the steps end and had swivelled and so the box had tilted. Anyway a lot of time was spent making a proper support under there. That took all of Sunday we managed to get the new batteries in situ but only one link made up. On Monday we got all the links made that needed changing and installed as per the properly balanced method. We managed to not need the busbars as using the new ends we could get 4 of the big cables on each main takeoff. 2 links and 2 from the isolator switches (one of these includes the Mikuni apparantly ) on the positive side that left only two little ones (Solar and smartgauge) on the negative side the 4 large were 2 links and 2 to the Victron and three little ones (Solar, smartgauge and the Mikuni) I'm afraid we had to have the negative that goes to the starter battery coming off the other battery of the bank of two (C and D) as there was no way to get 5 large cables off the same point. We made an executive decision that this one was the one least likely to affect the balance as it is the earthing one?
Today I am going back on the boat and setting off on my travels again. The boy hasn't reported any problems thsi week so here goes. Thanks for your advice. Out
Okay peeps here is my new planned set up for the batteries. I don't need to worry what is happening at the other ends of my cables as I am not messing with them at all. All I am doing is removing old leisure batteries, changing the ends/connectors of those cables that need increasing from M6's to M8's to fit on the new M8 screw down studs (himself has the equipment to do this crimps heat shrinks and whatnot). I have purchased some more new replacement 50m2 cables re new distances between the batteries, a couple of new m6/m8 terminal/connectors for the ends of the new cable going to the busbars, one each of busbars at 210Ah (and covers) which will at least save us having to change the ends of the Mikuni and Solar panel wires. whoopdedoo shame it doesn't save us having to do it with the smartgauge wires which are tiny wee and not really condusive to an M8 terminal/connector! Hopefully the new stuff will arrive before we go down to the boat.
Right better actually do some work today! Toodle pip.
1 minute ago, rusty69 said:
Also assuming you don't have a shunt based battery monitor.
Now you are just being mean ????????
1 minute ago, WotEver said:
They look just about right for a 575Ah bank assuming that you don't have a large inverter hung off them.
Cheers, Tony
Oh good. The bank is going to be 4 x 160Ah so 640Ah. The inverter is the Victron 3000 but I rarely have it on unless I need to use either the washing machine, or the oven. I mostly cook on the gas hob.
Just now, WotEver said:Actually, the SmartGauge should go directly to the battery terminals, NOT the busbars.
ok no problem will make the ends M8 as per previous plan.
Thanks Tony for your input most appreciated
Just now, rusty69 said:
Will depend on your loads.
Mikuni has a 30A fuse, Solar panels and the smartgauge. I plan on putting the Victron and links direct to the M8 bolt terminal
3 minutes ago, WotEver said:
Yes. That's why it's drawn like that
I know it's not what you want to hear...
I thought so but I got himself drawn into the argument and he insisted I ask the question So next question in case the M8 bolt is not long enough for all cables and we need a bus bar can you recommend which size I go for? I am liking the ones below but they are rated as 210A is that overkill? To be honest using a bus bar looks like it might help anyway as we were going to have to change all the ends from M6 to M8 and this saves us a job. Silver lining etc etc
http://www.12voltplanet.co.uk/4-point-negative-distribution-block-busbar.html
http://www.12voltplanet.co.uk/4-point-positive-distribution-block-busbar.html
http://www.smartgauge.co.uk/batt_con.html
So using Method 2 lBattery A will have on the positive side three large cables direct onto the M8 Bolt plus the solarpanels, mikuni and smartgauge cables either direct to M8 bolt or via a bus bar
and Battery D on the negative side has 4 large cables direct onto the M8 bolt plus the solarpanels, Mikuni and smartgauge cables either direct onto the M8 bolt or via a bus bar. Method 2 not optimum as batteries slightly unbalanced.
Now if we go for Method 4 and have effectively two pairs of battery banks. Do we then have to have all the above cables onto Batteries B+ and C- as per their diagram or can we move the smaller Solar Panels, Mikuni and smart gauge onto A+ and D-, declutterng the terminals and thereby eliminating the need for busbars?
33 minutes ago, WotEver said:Yes, everything should go on diagonally opposite corners as explained on the SmartGauge site. To facilitate this you will probably require a couple of busbars.
tittle! not what I wanted to hear.
Hi all battery afficionados I am about to take new batteries down to the boat and do the change over. I have searched the forum and found some interesting things I did not know before. Now I would like some clarification. The old set up (six batteries 110Ah) was always a bit higgeldy piggeldy as we couldn't fit all the ends onto the terminals. When I had to buy new batteries at short notice we basically had to do the same again so
Set 2 comprises 5 leisure batteries 115Ah I will label them A to E.
Positive side
Battery A currently has solar cable and one from the Isolator Switch and link to battery B
Battery B has two links A and C
Battery C has link to B and D as well as smartgauge
Battery D has link to C and E as well as one to the Isolator Switch
Battery E has link to D
Negative side
Battery E has link to D and one to Victron and one to the Mikuni
Battery D has links to E and C and one to the smartgauge
Battery C has links to B and D and one to the solar panels
Battery B has links to A and C and one to Victron
Battery A has link to B and one off to the Starter Battery
Now the 4 new batteries 160Ah have a M8 bolt type fitting so no need for the terminal clamps as used previously so we hope that it will be easier to fit more cables to a single post.
The proposed layout is going to be
Positive side
Battery A has both the Isolator cables and the link to B
Battery B has link A and C
Battery D has Link from C and solar and Mikuni and smartgauge (ie 4 one large and three small)
Negative side
Battery D has link to C and both large cables to Victron
Battery C has links to D and B
Battery A has link from B then the large one to Starter battery and the negatives to Solar Mikuni and smartgauge.
I am reasonably happy with this BUT which order should I pile the cable ends for best connection (thinking smartguage here)
(My reasoning for putting both Isolator switch connections to one and both Victron to the other is I am not 100% sure why there are two or if this is immaterial or not and if material and I put them the wrong way around it could mean that they are not going to pass through the whole bank. If you get my drift.)
I have printed off the smartgauge info linked to in a previous post about how to correctly interconnect multiple batteries but
a) this doesn't address the issue of all the other items connected to the bank. I have basically assumed that by having the charger going one way and the solar and everything else going the other way around that that is okay. Otherwise Everything would have to go onto two diagonally opposite terminals
and b ) we don't have enough extra cabling to do the fancy Methods 3 or 4.
Don't even consider a folding electric bike.
folding by all means
electric by all means
but not the two combined.
I had one and it didnt do what I wanted it to do. And as for trying to cycle it without the battery it is like cycling through treacle. My ancient cheap heavy bike was actually faster then the folding one. The problem with them is the limiter to 15mph. On cheaper ebikes they basically limit it to 15mph completely so even going downhill you have to pedal like crazy to keep up with someone on a normal bike.
Plus it says they can do up to 30miles on a single charge but they can't. I now this for a fact as it gave up on me 7 miles from home and I had to flag down a passing farmer in an landrover to take me the last 3 miles home as cycling 4 miles without power after 20 plus miles at eco level nearly killed me. I now have a very expensive ebike that you can ride like a normal bike withut the battery and if you are pedalling faster than 15mph then the electric motor simply stops assisting and you can go as fast as you dare. OH has clocked 30+mph on it going downhill, a figure I am never going to be able to achieve!
4 minutes ago, WotEver said:
We need to see if all of the battery charging outputs are wired.
In the mean time I suggest you put a jump lead from the leisure batt +ve to the engine batt +ve.
Thanks might do that if push comes to shove. We are visiting in three weeks time to put my new leisure batteries in a week before I take it over, so will see if all is resolved then. Tara ra bit.
Ah in that case it will have to wait until August. Thanks anyway.
Just for future reference, it is helpful to quote correct and complete part names / numbers - particularly when the part you 'don't quote' relates to the problem you are having.
Remove the front cover and take a pic of the 12v outputs and lets see what is connected.
I appreciate that but I am not on the boat at the moment my son is. I will be back on the boat in August and hopefully heading up to Northampton with all things ship shape and as they were before it was installed in a marina for a year. By front cover do you mean of the Victron? it is scary back there. I did however take pictures of the back of the engine panel to see if I could spot an obvious loose connection there but it all looks fine (to me)
Well I couldn't upload my videos but here are a couple of photos. One of the Victron (ignore the straps these were taking the weight of the new battery as I installed it using my feet to push it onto the swim). Two is the engine panel showing that the domestic light didn't come on and it should. three the engine running showing the domestic light does actually have a slight glow. (I think that is right obviously I took these in April and I have slept since then) shame I can't upload the videos. It would explain such a lot.
8 minutes ago, Alan de Enfield said:
Is your shoreline powered battery charger a 'proper' boat charger, or just one from Halfords (other suppliers are available)
Does the charger have twin outputs (one for the domestics and one for the starter), are they both connected ?
To avoid it happening again you can link-across using a jump-lead - but this does mean that your domestic usage will come from the domestic AND the starter battery, BUT when you charge the domestics, the starter battery will be charged as well - how confident are you in actually 'managing' your battery charge and discharges ?
It is a Victron 3kw so should be all tickety boo. However I query the 240 fuse box thingy as it doesn't seem to care whether the dial is pointing to shoreline front, shoreline back, gen, (I can't remember the names but it has three 'sources' I don't have a generator but that is one of the 'choices') as soon as I switch the victron on it lights up as polarity ok . When I am on the boat I am not attached to shore power so I switch this to off and shut the door on it and forget it even exists. But I put it to shoreline front for my son and for living purposes he has been fine. I have tried to find a loose connection regarding the new anomaly re the engine not charging the leisure as the panel lights indicated that this might be a problem. I took some videos which demonstrate the engine charging anomaly but they are too big to include here.
40 minutes ago, rusty69 said:
It depends how its connected. Some mains chargers allow charging of a starter battery in addition to the domestic.
My main solar charges the domestic batteries whilst a small (20w) panel maintains the starter battery.
If your smartgauge is connected to both batteries you should be able to determine if the starter battery is being charged
Thanks for that. I might consider the small panel. At 20w does it need a controller? I do have my original solar controller still in situ on the boat from when I had stick on panels. I could possibly use that for the starter battery. (The new solar panels have an mppt one)
My smartgauge is telling me categorically that the current solar set up is not charging the starter battery.
Bizarrely when I was there installing the replacement starter battery in April it was also telling me that the engine was not charging the leisure (I covered the solar panels over) not sure what that was about but hopefully once I am on the boat myself and moving that that will resolve itself. I never had the boat on shorepower before and it may be an anomaly with that. Any hoo recommendations for a marine electrical / Beta engineer between Uxbridge and Northampton just in case it doesn't revert to normal. I will stop hijacking this thread now. Thanks
I am not sure I have a split charge relay as the engine has two alternators?
As an aside, my son has been living on my boat in a marina for the last year. He didn't run the engine at all since he wasn't moving and I thought it was one less thing for him to worry about as we have solar panels and when he needed 240v he put the shorepower on which also charged the lbatteries. However by December the starter battery was as flat as a flat thing. Clearly solar power doesn't charge the starter battery on my boat and neither does the shorepower. Is this normal? I have now put a new starter battery on and since April run the engine once a month. I will be taking the boat back shortly and as I will be moving the boat regularly again the starter battery will get charged as normal. However should I consider getting a small solar panel just to trickle charge the starter battery when the boat is all alone over winter or is there some way to include it in with the leisure batteries and be covered by the current solar panels? Previously the starter battery always started the engine first turn of the key after laying up for three months over winter. It was 8 years old and never missed a beat, the smartgauge showed it as being fine when I left the boat in the Marina for him to move onto in August 2016
By a smidge - I meant the moored boat was pretty much the last place to moor without being on the lock landing. This was at Barton Turns. My boat was already in the lock and so the lock landing there was completely vacant (two boats worth).
In that case it was the gentleman who helped me at the lock. Seemed a nice fella.
At the next lock I could see them have a discussion and they clearly decided there was more room for her to cross my bows rather than my stern. This meant their boat had basically overtaken mine and was now blocking the narrow entrance to Tatenhill oval. If I had been the following boat I would have stayed out in the canal until the boat on the lock landing had left.
She took great exception to my comment that they were queue jumping hence why they made such a big thing of me having to negotiate my way past after I said they might as well take the lock as I wasn't in a hurry.
Sorry to hijack this topic - glad to hear that basically this is not normal boating behaviour. Certainly the first time I have witnessed it.
I have a ridiculous sense of guilt and feel as if I am doing wrong when I use a CRT working flat boat to cross when they are moored in the way on a lock landing.
I always knock on the roof of a boat and stand to the side so I don't see in when calling in to see folk. (If they have dogs I ring them instead just in case they have gone shopping and left the dogs home alone.)
I didn't get the impression they were new to boating but perhaps they were not livaboards.
He seemed a nice fella however I would gladly push her into the water if I found her being a pirate and boarding my boat without permission in the future!
I am interested in the etiquette aspect (and I am talking other boaters not police officers).
Is it normal to walk across the bows of a moored occupied boat to reach the towpath when a smidge further on there was a perfectly clear lock landing built for the purpose.
Is it normal to then walk across the bows of a boat (mine) moored on the lock landing, go past that boat into oval occupied by a vintage boat moored by the lock cottage, breast up to said moored boat and expect the boat previously on the lock landing to have to manoeuvre around you in order to enter the lock they had been setting for themselves before you turned up. AND then have the audacity to say that you had been making rather a meal of it??? IS IT ME?
The locks in question were Barton Turns followed by Tatenhill lock.
I observed the boaters following me do both of these. I thought it incredibly ignorant of them.
Morning, thanks for all the replies sent while I have been at work - hence my non appearance for a while.
All useful stuff to know - although I wish I had known I should have recharged asap after topping up. I didn't dare until I knew whether it was going to leak acid all over the place, possibly gas me while moving the boat, I would then fall overboard ... (I left the boat with the batteries at 90%)
Can you tell I am a closet whittler?
I am fairly confident that there is still a small air gap above the level on the two cells I am concerned about. However I can't confirm this as the gap between the top of the battery on the swim and the bottom of the electric cupboard and associated wires is only about 3 inches. (Certainly not high enough for me to use the special undoing battery cap tool I was given for xmas. I couldn't get it vertical so I had to use a 20p gripped with mole grippers all at arms length and with a back doing an unsupported yoga snake)
I look forward with trepidation to starting the engine on Monday.
Thanks again
Kath
Oh thank you thank you for that. Splendid I can go to sleep tonight.
Thanks for that (my baby bottle will do the same thing I hope) (Well it wont automatically stop) Clever design. Hmmm
However my real question is what is going to happen when I next run the engine with the possibly overfilled cell?
I think everything was changed over - I had a run of help on this forum back in July/august to help with this. I only use the engine for charging (and the solar panels but I am unsure of them at the moment) I will be getting the solar panels checked later this month.
Ideal Pram Hood design
in Boat Equipment
I had Kinver Canopies put a hood up on my boat for my son when he was living on the boat for a year and this August and September was the first time I have cruised with it. It does get in the way when single handing locks etc as I can no longer step up onto the roof so easily but I could sort this by finding a way to lock my hatch lid open. Then when I stand on it it wont move!
But I have loved having it. When it rains you can cruise with it up so long as you have rolled up the front 'window' (looking through when it is down and raining is impossible). And by having a useful length of string around the back hoop means you can push it down before a bridge and hoik it back up again afterwards. To facilitate this you do have to flick the press studs down each side before setting off. When you have moored up again it is a quick drop of the front and back windows, zip and push press studs back on. Excellent for drying your washing over the warm engine.
It keeps the boat a lot warmer and if you are in a poor signal area you can put your laptop on the hatch and do some work even if it is raining as I have had to do on two occasions. You can work on the engine in the warm and dry. I call it my conservatory. It is hideous but I wouldn't be without it now.
