Everything posted by Gavin Brunton
Engine Bleeding poss tank leak
Gavin Brunton replied to Gavin Brunton's topic in Boat Building & Maintenance
Anyone know what the BSS numbers are I'm looking for? -
So After a few hours getting dirty Ive fixed it. The compression joint at the difficult to reach tank outlet was undone. Also discovered that RCR hasn't changed my secondary fuel filter was leaking in the fuel line between the second filter and lift pump. It was cracked a little near the compression. Ive cut two small pieces of 8mm copper and joined them with a piece of halfords 5/16 rubber fuel line. Is there and Safety issues with not using copper all the way though so close to the engine? I also added a cheap laser squezey priming pump to make leading the engine 100 times easier and it let me discover and leaks. For the record this is the second time RCR broke my boat and I've had to fix it. The first time I was told I needed an additional 4 hours work at 40 quid a pop. I bleed the engine in 10 mins and got it started after discovering they had left several compressions undone. FYI my heater has never been a problem. It just needs electricity from my alternator. -
Yes It was working -
The Hurricane heater has its own pick up separate from the engine and they are lower in the tank than the engine ones which was a mistake on my part. I had a service from RCR and They left me with a no functioning engine. I cant wait until next thursday for them to return. I am annoyed but I want to focus on fixing my engine as it Snowing and I need power for my heater to keep warm. Ive sucked on the return feed and it makes a slurping sound as well! Starnge for them both to do that? -
Hi all, Im trying to bleed my engine the thing is Ive just put 30l into the tank ,which wasn't empty as my diesel heater was working before, and when I suck on the pipe that goes between the tank and the Primary fuel filter I am hearing a slurping noise like when you get to the end of a soft drink with a straw. i can get fuel if i suck hard enough but as soon as i stop sucking and form a seal with my mouth the fuel returns to the tank. My questions are; - Surely over 30l would be enough to reach my fuel pick ups? - Normally fuel pickups inside the tank stainless? Could the pick up inside of been corroded and has holes in it? -is it common for the tanks to rot and leak the fuel inside the boat somewhere? Is the Tank double skinned and is leaking into the second cavity?
Motorised valve could work yes would I just need one on the flow pipe? Also in the gravity feed system I was going to have a large cast iron rad on a thermostatic valve and small rad in the bathroom with a normal valve so the back boiler has flow when the trv turns off . would trv impede the thermo syohon?
Hi all wanted some advice on my heating. I have a hurricane boiler in my engine bay feeding rads on both sides of my boat. On the port side in the middle of the boat I have my stove fitted with a water jacket and the pipe work jumps to 28mm and a gravity feed system feeds the furthest radiator at the bow of the boat port side. This means that when the hurricane isn't on and I'm just using the stove that my bedroom at the bow of the boat is still staying warm. I was planing to have s couple manual vales to isolate the stove and its gravity feed system when the hurricane is off to ensure the gravity feed functions properly. Then I thought could I put an automatic bypass valve on the hot pipe just before the stove so that if the hurricane came on it would automatically open the loop to the last rad? If the hurricane is off the the pressure drops on one side of the auto bypass valve and it isolates the gravity feed loop and stove. Would this work?
Angles of pipes in Gravity feed system.
Well thanks all you've got me started tonight and I'm feeling confident now I have had some sound advice. I have an other question about puting an automatic bypass valve in my system so I'm going to start another thread Cheers all -
Hi I've been looking through previous posts for information on the angles of gravity feed pipes and have as yet only found one suggestion of 5cm rise per 100cm. Im using 28mm copper and feeding a large cast iron radiator 4m from the stove. Also I was planing to enter the rad at the top on the side nearest the stove and exit on the bottom also nearest the stove. Is this the correct way to do it? If my pipe was slightly steeper should this eork? I'd 10cm per 100cm?
Hi I'm planing to move my stove any help on disc robing the process and materials needed would be much appreciated.
replacing engine mounts on beta marine engine
OK so its a beta 55 on a cruiser stern 50x10. thats as much as i know -
Any experience with a Alde LPG Combi Boiler?
This is exactly the scenario i envisage Thanks for the input. -
The stove would stay in and I would try and use it as much as possible but I regularly work 18 hour days and and get home in the small hours of the morning so I was hoping for a solution that could come on in the morning when i get out of bed and i could connect to something like a hive so I could turn it on just before i get home. Having a hot shower is important to me when i get home. Ive just done the Maths and two hours a day would cost 50 quid a month with the Alde and a 19kg bottle would last 23 days. If i got a hurricane its 45 a month. -
Ive read nothing but bad things about diesel heaters on forums apart from the Huricane which is expensive. Has anyone got a positive sorry about them? What would the cost pre hour of a diesal heater be? -
the 3020 Combi boiler http://www.alde.co.uk/itemdetails.php?itemId=1 -
Hi i am looking to get a LPG Combi Boiler fitted to my 50x10' canal boat. I currently have a stove with a back boiler a colorifer and three small radiators but i work very irregular hours and would like a slightly more convenient option with a thermostat. I was looking at the Alde as i like the idea that its cleaner burning than a Diesel heater, quieter and more reliable. Has anyone got any first hand experience with the Alde? How does it hold up is it efficent?
I'm trying to keep costs down so it seems 64a twin and earth is this cheapest option. Just out of interest has anyone ever considered a dc-dc voltage booster. They are pretty cheap on ebay
Each core 64a twin and earth has 7 strands is this ok?
Hi I am installing a 12v fridge on my girlfriends boat and wanted to know if 10mm 64a twin and earth from b&q would be suitable . We need about 10m of cable and the fridge is 70w so 5.83amps at startup. I have read a few posts with complicated formulas but surely if the cable is rated at 10.97 times the rated amperage than this would be suitable
