BODs SR2
Posts posted by BODs SR2
15 hours ago, The Ents said:
Hi Bod'sSR2,
Stop worrying, I think if I were you I would stay with the warning light!
Mike on Balthazar.
I’m just envious of Robbie Cumming’s gauge for his SR2 on Canal Boat Diaries.
At the moment I have a pressure switch connected to an LED. I'd like to fit a gauge. Can anyone detail what i need and what pressure to expect. Cheers.
On 22/09/2023 at 11:03, dmr said:
Its hard to answer that as different boats appear to consume anodes at very different rates.
Do you know when it was last replaced?
Been on about 8 years
Thanks I just meant using Bitumen. I’ve used intertuf 16 in the past but the shiny new sheen doesn’t seem to last very long.
Anyone got a preferred traditional blacking paint.
On 04/09/2023 at 11:53, BODs SR2 said:
Thanks peeps. Will give it a go.
The Milton liquid worked a treat. I put it in before refilling the tank so it condensed around the outlet. Next time I’ll fill half way before adding so it gets mixed in better.
- 1
Unfortunately my fresh water has developed an unpleasant odour. Can anyone recommend a cleaning substance/method to sterilise it all. Thanks
Did both. Thanks Tony I’ll get one.
Thanks bizzard.
Had a hell of a job freeing the drain plug. Only just managed to release it lord knows what I’d have done otherwise. -
Thanks as ever Tony.
regardsrichard.
Apparently how these detectors work is they reflect against a different substrate so bare the metal on the outside and as soon as the wave hits paint rust etc it will reflect back.
Installed on of these in a small wet room which included a shower. Been using the area for 3-4 years infrequently. Decided to check underneath and to my horror found evidence of a substantial leak. After a refit it still leaked around the toilet area. Eventually found the join between the back and basin has no gasket and leaked through. See photo.
I’ll opt for trying ones off Amazon for now. Keep you posted.
I can imagine you get what you pay for. Getting the professionals in is £250+ so something to play with there. If I calibrate on a known then get down to the bare metal it should give me an idea if further investigations are needed. Also it’s there to use again. From my experience with surveyors they have an agenda and are reluctant to work with you and spend time on any concerns you might have.
Could anyone recommend one of these for diy use. Got a 1976 hull and although I’ve had a professional survey done I would like to check out a few specific areas next time it’s out the water for blacking.
On 02/01/2023 at 18:25, Mike Tee said:
Extremely helpful, highly recommended- but good as they are, as with anything boat related, it won’t be cheap!
Thanks Mike
Looking to replace my small multi fuel stove with a diesel stove ie. Refleks. I’m based in West Lancashire on the L&L. Does anyone have a contact to have this done please.
Looking at the fuel side does anyone have the spec for the supply pipe and what kind of filter is best. Thanks.
19 minutes ago, MtB said:
I'd have preferred the Mellor one as it comes with two x 24mm flexible exhaust tubes already welded on, saving two mechanical joints in the exhaust, internally.
Are flexible exhausts a potential source of leaking?
7 minutes ago, Tony Brooks said:
So in a confined space like a boat's hull exhaust fumes can/will build up and eventually kill you. Mainly by CO but could also drown you in CO2. It might also be hard to install the heater high enough in the hull to let condensation drain fro the exhaust outlet in the hull so a special exhaust is needed. You don't want condensation running back into the combustion chamber.
Thanks. What are the special features of a marine exhaust. Sorry just trying to grasp it all.
Window seals
Will do thanks
I guess it all needs to be done while I’m at it. Been relying on sealant for too long.
Thanks. It’s a dart line boat.
I’ll bear that in mind thanks.
