Hi All,
I've done a bit of searching and I know there's a few similar threads to this, but I can't quite find an answer to this, although I'm sure its not the first time it's happened.
I've just bought my boat, theres been a lot of "CSI" style working out why stuff is where it is, or hooked up like that, etc, etc.
I purchased a 2nd hand morco d61b with flue which I was assured worked. It was installed at the marina I'm in, by competent and qualified (and very good blokes) engineers.
The gas supply was uprated from 1/4" to 3/8" as previously the only gas supply was to a 2 burner hob. The gas supply is now 3/8" up to the morco, then the previously fitted 1/4" to the hob and a SMEV oven.
The water supply is via a shurco pump which is not brand new but is now working consistently. At the hot tap in the sink, I can measure a flow rate of 5l/min through the boiler.
So, the 2nd hand boiler was fitted, the pilot light worked fine, but the gas field would not light. We replaced the diaphragm in the morco as there had been a small leak, and checked the little pin could move freely. Still the same problem.
We decided that there must be a problem with the boiler so I bought a new one, fitted it, same problem.
I reckon it has to be either low gas, low water or both. (or if I'm very unlucky and the new boiler is faulty)
I think I should:
1: get the yard to measure the gas flow.
If thats low maybe try a new regulator. if not:
2: try a new pump. If that doesnt work:
3: try a new pump and a new regulator, in case its a combination of both.
I'd really appreciate it if anyone can let me know if I'm going down the right route in my diagnosis, or missing anything obvious.
Thanks in advance,
Cheers,
Ben
