Posts posted by vulpyfox
I've had great results with a stephill (honda engined) 1.5kw inverter generator
picked it up used for £100
also is your gen burning oil (blue/grey smoke from exhaust) if so may just need piston rings and/or a barrel.
I already have an Osprey 2 on PAYG for £20 which gives 15GB a month which is usually ok though I'm careful with what data I use and usually end the month with data to spare. The signal is stronger than the Kite from EE which is what I used to use. I get decent 4G with it on the roof inside the well deck. Connecting to the signal inside is strong enough to use at the other end of my boat with an iPad. iPhone not quite so good. Battery claim of 6hrs seems accurate. You can connect 6 devices. I use a 3 meter micro-USB poked through the top of the door to charge if it needs it when using. Over!
I also pop mine on the side window (Inside) when using it, receives great signal, I think its about 15 devices max, there are plenty of tweeky options in the main menu
mines for 25gb over two devices (the router and the phone) comes to about £36 a month this inc the Osprey 2 and mobile phone bill too, they piggybacked the deal onto my existing phone contract.
I'm using two breakers on mine, one on the + in of the panels and one on the + output of the controller, not much else needed really
These also act as isolators at the push of a button ^.^
My nature walk around Area 51 didn't go that well either.....
Step on some bug eyed aliens?
My motto is "take only photographs and leave only footprints".
Footprints don't do well on rare plants.......
wow its pushing my 50ft side on! have lost a terracotta planter but managed to salvage my resin fox as he floated down the canal lol
live for the moment huh?
I'm using a bank of semi traction 225ah batteries, having very good results with these beasts!
Had some Lion sealed calcium 110ah ones before, they failed far too quick
I have no idea how they can knock them out so cheap but they do the job
These are good too! you can just plug them into the 12v sockets when and where you need them without any mods, they also support 1A and 2A output
There isn't a biological definition of "Breed" because a breed is man-made label defined by certain breed-specific traits which are refined through selective breeding. To understand what a crossbreed crossed with another similar crossbreed would produce, it would depend on the gene progeny of the many various traits. So its not easily defined. Its fair to say that a cross x cross will produce a much larger variety of offspring than a purebreed x purebreed.
Do a bit of googling on: subspecies; race; strain to see how these are defined biologically
I guess pure breed would define as WOLF
she still has it, one of her favourite toys
Poor boy, a speedy recovery!
Sockets, MOLE GRIPS, Adjustable spanner, spanner set and screwdrivers are a good start!
cordless drill (fair to good brands on all tools or your just cheating yourself)
Sealer gun and silicone, matches, blowtorch, decent torch and/or lantern, hurricane lamp
electricians knife, shrink wrap, gas or mains solder iron and MULTIMETER, Electricians tape, wago snap connectors and so on!
I don't Really mind one way or the other, if I'm not bothering anyone and they are not bothering me all is good, I'm easy going.....its just the ITS MY cANAL mentality of some! ( careful use of caps used here
Already done and ready to fit
Thanks all for the help, have ordered a few from RLWP ^.^
@ LC : thanks i have sent a PM to them, will try the marina also but doubtful they will have any
@Bizzard : I don't have a matching bolt or drill bits small enough to suit, might have to be a backup plan if I cant source one though
Hi all, tipsy seems to have snapped her "injector bleed off" banjo bolt
I have retrieved the bolt head, thread and washers, but for now I'm stuck where I am
part number looks to be 601-36100 and it's for a lister TS2
can anyone help point me in a good supplier who could help (fast) as I need to be moving on VERY soon
I'm in the berkhampshire area at the moment.
I have found this site to start with http://www.sleeman-hawken.co.uk/suppliers/lister-petter/stock-list-p9.html
waiting hopefully someone knows someplace I could drive to in my area
or online parts shop that posts fast!
even a good used one will do!!!!!
many thanks
vulpyfox
looking great!!!!!!
Great Post ^.^
so when will they also ban the use of diesel backup generators in hospitals etc...... where does one draw the line...
Hopefully as most of our diesels give us electricity, heat and propulsion they will give us a bit of a break.
Which Generator?
in Boat Equipment
Posted · Edited by vulpyfox
Ah pity, I rebuilt one for a lot less than that, parts are a lot cheaper if you shop about, labour is the killer!
Yeah prob best to replace it and have a go at rebuilding it yourself, if only for practice
if you get it right then you have a nice shiney spare one!
