Posts posted by Dinz
On a different point. Does boat have a wheelhouse or not.?
Looked at a great boat on G&S then realized would jam at first brige on K&A as was fixed, not collapsible. Just a thought is all!
- 1
if cost is issue i use gas for kettle several times a day. Grill or oven most days circa 15-25 mins + pots. Cylinder lasts circa 7-8 months. This works out about£1 a week at current prices.
Diesel at £1 /lt will go thru your engine/genset at a litre an hour. Just to put things in perspective.
Wet or Air?
If wet could be air in water pump.
This causes swift temp rise that trips on overheat.
I have a generic timer so wired an led across start switch. This gives me the fault code lights.
Are you getting any warning light flashes?
Was the previous owner a DIY expert?
- 2
During Summer personally I set off about 5am. Sun is up and have 4-5 hrs cruise with little to no 'traffic'.
Come 11-12 others are finally on the move & usually have pick of moorings [CM's permitting.]
Eastwood along long pound lovely.
- 1
Get my iced tea from Long Island.
Just broke my Keter after 6 years.
Mind you had a GS850 on it at the time and was braying the rear shaft wth a lump hammer.
Buying another.
On 19/06/2020 at 08:46, WotEver said:
If you're fitting 4 then I'd consider wiring them in two parallel series pairs. If that sounds complicated, it's not Basically, two panels in series, plus another pair in series, then parallel the two pairs. That way, if one panel is in shade you only lower half of the output instead of the whole thing, and the voltage is still high enough for the MPPT to achieve a decent output. It's always worth arranging the wiring such that you can experiment in the future - do they work better all in series, all in parallel etc.
Wot Wotever says.^
4 hours ago, Tim Lewis said:
The lock keepers at Devizes use a quad bike!
Even Vincent's did 'em.
Takes me back.
Re-building motor so no bits available.
3 hours ago, Jim Batty said:
Hi Dave
We're in West Mills, outside Newbury on the K&A. On a nice winter mooring with all the luxuries, like ... water on tap ... and shore power.
Not far. If you go the Victron way & have issues PM me & I can lend you interface if needed.
- 1
Hi Jim.
Where is your location?
I have the interface module and a PC with the software.
Dave
Ref the holes.
A boat went under at Crofton a few years ago when levels dropped.
Upon refloating was found that the hull had several holes in above the waterline.
It appeared to be the hull had been drilled for skin fittings and then the interior was laid out differently and had skin fittings put on the other side.
The interior was lined and the unused holes were forgotten about.
Boat several years later listed in a low pound . The rest is........
[ref the late Dave & Sheba of NB Summer]
Well its the way I understand/explain it is all. When cold the old knackered oil can be really thick at air temp. Like treacle.
When warm it flows nice and easy.
No doubt someone more technical will come along and argue it?
Reread OP.
Yep oil has gone gloopy.
Change.
Now it is colder the oil has 'thickened up' and as such makes it harder to pull start.
As soon as it starts the oil level appears to drop as it isn't returning to the sump quick enough until it warms up thus causing oil level switch to trigger.
After a couple of runs oil is thinning down with warmth and then the Genny continues to run.
- 1
Also.
Starts, runs, stops.
Does oil light flicker?
Change the oil. Check the level.
Really common as the air temp drops.
Strangely I have an EU20i that charged but motor blown.
Wot you want for yours? PM me.
You back in the area?
When are you due through Dave?
Alternator?
24v webasto - eberspacher
in Boat Equipment
https://www.butlertechnik.com/marine-heater-kits-c55
https://www.webastomarine.co.uk/products/thermo-pro-90-vehicle-kit?variant=42253652558009
1minute on google!
