Hi. I'm trying to troubleshoot a problem with the alternator on my narrowboat
When the engine is idling the voltage at the alternator is low, around 12.5 - 12.7. Afaik it should be something like 13.8 - 14.2. Is this right?
Does anyone have a list of things to check to start narrowing this down? I'm not quite sure how the to check for a slipping belt but suspect that's worth a look.
Let me know what info would be useful. I'm not sure what the alternator is but will check.
Thanks
Will
edit - sorry, realised in my sleepy haze that I might not have been that clear about something. To start with, I'm only assuming that the alternator should be charging properly at idle. At higher rpm, the voltage goes up to around 13.9, and the batteries charge. I've just been told that I should not need to do this
