Peter Thornton
Posts posted by Peter Thornton
Not sure how long you've been away, but be aware that a good pork pie will take a little hunting down!
2 minutes ago, Mike Hurley said:
And I'm not surprised! We are leaving today, back to our home mooring at Overwater, and will be buying a last pork pie and saying a reluctant goodbye to a wonderful small market town.
Lovely place Skipton, no restrictive mooring restrictions even near "posh" flats.
So the boat behind us has just started running his engine at 7.05am How long before it all changes?
Come on folks, have a little sense please! The same boat ( you know who you are if you're reading this!) was also running it after 8pm a couple of nights ago. I guess this is how the Saltaire restrictions started?
- 1
Good to find someone as figure obsessed as me!
You're right about the different routes and their effect on consumption. I get markedly better on the Llangollen canal than the Bridgewater.
Thanks Tony
That day may just have been today! I'll make a temporary mark with tape then monitor it over the next few days.
Hopefully we have just been getting all the air out of the system, otherwise it's back to looking for a leak!
Out of interest, what sort of oil consumption would you expect on one of these, also mpg, or whatever the equivalent is? (On a 58ft boat)
we tend to put in about a pint of oil every 100 hours or so (not all at once) and we use about 1.1 to 1.3 litres of diesel per hour working out at about 1.75 litres per mile.
I know the mpl figures are a bit meaningless as locks make a big difference but do those figures sound about right?
Thanks very much for all your help, it's much appreciated.
It's a Pat Buckle boat. Ref the engine, I think it's about the 4th engine. The first lastedcsome time I believe then there were 3 quite quickly - from Calcutta I believe. The last engine was fitted whilst still under Ownerships and is about 7-9 years old I believe.
ref the raw water cooling, happy to be corrected and in fact there are no signs of it ever being fitted.
Thanks Tony.
this is an ex Ownerships boat of 1997 vintage. I think it started off with using raw canal water to cool and then was converted whilst part of Ownerships, along with all of the other boats. (I stand to be corrected!)
I don't know if the pictures help?
interestingly, today's cruise resulted in the header tank filling right up and then dripping out. The engine was working reasonably hard in a shallowish canal (Leeds Liverpool beyond Silsden) but no signs of overheating and the gauge on its normal 80. No signs of boiling or anything like that, the level just rose to the top of the tank and then dripped. So I'm wondering if the air pockets might have been filled and this is the result? The header is filled to the Min mark, about 1/4 full.
Tony, if it's cooled directly from the skin tank then is it all one system and is the header tank effectively connected directly to the skin tank?
i feel I'm learning a lot more than I expected this week! Thanks to all the tutors ......
Cruising at the moment but it does have a skin tank and a Bowman exchanger. Not sure if it is now one sealed system, will post some pictures later.
Thanks for all your help folks, I've looked at it again this morning and I think the cap on the engine is indeed a blanking cap rather than a pressure cap. It looks just like the one in Alan's link and has a black rubber pip in the middle of it.
No surprise really I suppose as our boatyard does do a good job, it was just my ignorance that assumed it was the original pressure cap.
Still, the mystery is as to why we are topping up with water to a much greater extent than before the tank was fitted.
Thoughts:
1. Co-incidence. I don't buy that one really.
2. Leaks in the new pipe work or tank
3. Leak exposed by the fact that we now have a coolant reservoir sitting higher than previously.
4. As in 3 but now filling previously up filled air locks. In which case it will stop at some point.
I'll keep looking and report back when it's solved!
I need to have a good look at it but I think the flexible pipe is connected to the collar below rhe pressure cap.
No idea whether the coolant was drained, its possible.
Not sure of the ratings, but I'm pretty sure it's not getting hot enough to blow off. The temp gauge sticks at 80 when it's warmed up.It's about half a pint or so but the really puzzling thing is that it loses water even on days when we don't run the engine.
There are two pressure caps, the original one and one on the header tank.
Thanks Alan
Firstly, we fitted the header tank (or more accurately had it fitted by the boatyard) because we had been concerned that it was quite difficult for owners to correctly judge the proper level to top up to. One of our previous engineers had suggested that it could be overfilled with dire consequences and I felt that this could lead to underfilling. We have had a couple of unexplained overheating episodes.
The header tank has a pressure cap on it and the feed goes to the engine and to the collar below the pressure cap. So, yes, the header tank is part of the pressurised system. I've watched it whilst the engine warms up and the level gradually rises as the engine warms up.
It's all been fitted professionally and looks good. I've tried to see if there is any leak from the tank but it's difficult as the locker it's in does get damp from the rain. If we have a dry spell then I'll try again.
Finally, we are in the middle of a 5 week cruise which is why I've not consulted the boatyard that fitted it.
If it is gradually getting rid of air locks in the system then I guess it won't go on forever.
Not sure I follow that? The header tank is topped up to the mark when cold then the level rises when the engine gets warm. The level doesn't get to the overflow then settles down when cooling - but to below the original mark.
We have just had a header tank fitted to our BMC 1.8.
Before this we didn't seem to be using any water. Since fitting the tank we are losing about 1/2 pint each day. We even lose water when the boat is just on the bank without the engine running.
i can't see where the water is going.
I wonder whether we had an air lock in our skin tank and whether having a header tank higher in the system than before is gradually filling this up - in which case I guess it will eventually stop.
Any thoughts would be appreciated!
We've been here three days now, and yes it's a wonderful little town. I can't think of anywhere better on the canal system to be honest. And the butcher on the corner (opposite the church) is fantastic, pork pies and sausages like every town had years ago!
Pennine Cruisers are friendly and helpful and everyone just seems so, well, nice!
it will be difficult to leave ........
I thought it was the kids that caused all the trouble at Wigan ..........
We will be there tomorrow! Mooring in Gargrave tonight having just come off the Summit. A fantastic stretch from Burnley to Gargrave, can't believe how quiet it is, surely the best kept secret of the system?
Need to be careful in the locks though, two sinkings in the Gargrave and Bank Newton ones in the last two weeks and we came upon an ambulance at the last Gargrave lock taking a lady to hospital who had slipped and broken her shoulder. Hasn't put us off, but you do have to keep an eye on the boats at all times if you're on the paddles.
Lit, and burning nicely!
Sitting in front of it now, on a wet night moored at Hapton on the Leeds Liverpool.
That's a real shame, we looked for him a couple of weeks ago but he wasn't there. I wonder if he knows how many of us have fond memories of him? It would be lovely if someone knew how to contact him to let him know.
On a perhaps related subject, we noticed a long line of wooden piling on the right, after Leigh. It was set back about a couple of foot from the concrete bank. Was this something to do with works to combat the subsidence?
Did it today, and Peter was there! I told him he was famous on the forum and he seemed quite surprised!
Took 6 hours with just the two of us (Peter helped us towards the end, he had been busy with a couple of boats going down)
Not too bad, but you're always aware of that looming deadline .........
Skipton
in General Boating
If you can find a butcher who makes their own pies then you've struck gold! Stick with them ..........
