Bit of both Mike. Im just wondering why if you can moor the boat, as a leisure say, why you can't live on it? What difference it makes? Is it down to infrastructure ie, bins elsans etc ?? If so where is it written? Also if that is the case then won't that lighten the load from the other area your living in, surely it gets balanced out?
Times have changed since the Planning regs have been written and other peoples views on weather you are an eye soar or not should not really come into it seeing though there is massive problems with our economy and wellbeing. Which is rapidly getting worse. People get made homeless due to ruthless evictions, which only causes more problems, so its only shifting the problem and not solving it.
I know of a section in oxford where you used to be able to live on board but now every time someone moves off it gets auctioned off as a ''Leisure Only''. So that has nothing to do with Planning regs. If it was then live a boards would'nt still be there.
Isn't it time to look at the bigger picture and stop being so blinkered?
I know this is a big debate across the board but really.. times are getting harder and harder for everyone. things need to loosen up not get tighter. There isn't room for it.
