Bee
Days Won
25
Posts posted by Bee
If you are absolutely certain that the shaft is spinning at the same speed as normal and not just slowly rotating then the problem is not the gearbox (or the coupling becoming loose) which only really leaves the prop. The prop being loose on the shaft is extremely unlikely so something like weed or maybe leaves is pretty much all that is left. It only takes a bit of weed or something to mess up the science of propellers, I spend a lot of time on weedy canals pulling strands and lumps off the prop in summer.
The temp gauge on Bee started reading hot a while ago, turned out to be some awful DIY connections at the back of the gauge. Note to self - do it properly next time.
Seems to be 4 - 5 lived in motorhomes within a dogwalk of here now, No doubt there are some sort of rules and regs being broken and they are "getting away with it". "It" being council tax and all the other things that ccers are "getting away with". What is it that gets boat owners so upset about people buying boats to live on? Those boats are still floating around the system somewhere whether there is someone on board or not. Why should a boatowner have a mooring? We only have a winter mooring and nobody turns a hair that we are entirely without a mooring for the summer and we might end up in Holland, France or Belgium for the winter. There are more insufferable rules about how long you can stop for on CRT waters now and the more expensive it gets the more those who can pay hate those who can't and the more those who can pay demand more rules to keep the rest in line. If you encourage authoritarian organisations they just get worse until there is no pleasure left in anything. The boater with a battered Springer is not the enemy, leave him alone.
- 1
Magnetman has it about right, it is Dutch, there are umpteen types of Dutch boats built to suit the networks of small canals, very occasionally you will find one that will fit UK narrow canals. Some are very simple flat bottomed and flat sided punts, some are more boat shaped ≥ Kagenaar werkboot platbodem bierboot — Platbodems — Marktplaats If you dig around the various Dutch sites there are all sorts under Schuit, Westlander Kagenaar etc. and I for one cannot tell the difference between most of them
It is just a narrowboat but styled to look a bit different, I quite like them but others don't.
Must say that the stern of that boat is very much prettier than the vast majority of "Cruiser sterns" which are full of right angles. The fore end needs a bit of adjusting with a sledge hammer though
Yes, I think so, it looks as though there is plenty of packing still in there. Ideally it shouldn't need to be tightened very much, overtightening can cause the packing to wear the shaft, sounds unlikely but it really will, the shaft on my boat is a second hand one with some quite deep grooves but they miss all the vital bits. One cause of drips is a misaligned engine, this will cause a shaft to run in an oval or something that is not a true circle, this means that the packing, which is quite hard stuff, cannot press equally all round the shaft so it drips.
4 minutes ago, Jen-in-Wellies said:
Have you tried spraying some Easy Start in to the television gubbins?
Better known as "Start you bastard"
- 1
I can understand the reluctance to try and start old engines - I would not know how to try and start some ancient lump that needed blowlamping, cartridges or starting with petrol but in that case the broker should get in touch with the owner. I'm not keen on brokers anyway, in my opinion they don't do much and are responsible for putting up boat prices by operating virtual cartels. As for non refundable deposits - stuff that.
Water tanks, Our tank is about 200litres, not much by modern standards but we manage to make it do a week or so, if things get critical there is always bottled water. On a small boat it is difficult to fit a bigger tank, the UK canal system is well served with water points and running out of water is unlikely unless you are iced in or trapped because of unexpected stoppages or breakdowns. It is always possible on a narrowboat to fit a roof tank - they used to be pretty much standard on Wyvern Shipping boats.
To be honest I would not be very happy with it. About 5 pics up from the bottom there looks to be a slight weep from the seam that joins the bottom to the side. I would also expect to see some numbers chalked on the side as well by the surveyor indicating the thickness. To my eye it looks as though a good clout from a hammer on to a centre punch could go through some of those pits. Also unless there is something odd going on I can see no reason why the bottom plate should be any different. I am surprised that a boat from 2007 is showing such pitting and also that it appears that it was pitted last time it was docked and painted and a few years younger. If all steel boats had this sort of life expectancy then I reckon plywood could see a resurgence in popularity. Sorry to be a doom merchant but hopefully the next boat will be better. Good Luck.
The hull of Bee is painted in Jotumastic to a few inches above the waterline, to make a nice neat job of it the hull above the waterline is painted in bitumastic. The bitumastic has flaked off the jotul and it now looks awful so I guess that painting over Jotul means making sure that it is given a good roughening so ordinary paint has a decent key.
The prop has to work hard to stop the boat, if you are doing, say, 3mph the prop is having to go against a flow of at least 3 mph and possibly more as the water accelerates along the swim. One of my old boats used to go and stop quite well but if I engaged reverse from approx 3mph it would smoke black until the boat lost its speed and then it would go backwards. There is a lot of variables and stuff in props / boats / hull shape. When Bee enters a lock she is already in reverse on tickover as the boat goes through the gates ( unless we have to tie on the RHS and then its all ropes flying everywhere and panic as she will not lie alongside a right hand wall - prop walk)
Looking at your photo you have not got any room to get a bigger dia. prop and it looks as though your prop is about the right size anyway (not very scientific I know) If you had a 2:1 ratio gearbox that would make a big difference, you would get about 20 - 30% more rpm at the prop for the same engine speed. (no I haven't worked that out, it just feels about right)
When you engage reverse does the shaft actually rotate? If it only slowly rotates then gradually picks up speed then its a gearbox problem. If it takes a little while for the boat to respond when spinning normally then they do indeed all do that, its asking a lot for a prop to actually grab enough water to stop 10 tons or more of boat
Fuel polishing is just filtering, nothing wrong with that but the real problem is the layer of water at the bottom of the tank compete with rust, bacterial sludge and general muck, that layer of water is seldom sharply defined, it goes through a dull orange colour through to proper diesel over another inch or two and cleaning it is really difficult. You really need to pump the best fuel out into a plastic barrel then get an arm into the tank, clean it and put the good fuel back. Its mucky, difficult and needs a removable plate on the tank to get into it. quite honestly a removable stainless steel tank is a better bet than the usual integral tank in the counter. There is much about narrow boats that could be improved. (our boat is not much better but at least I can remove a plate every spring, shine a torch into it and check the whole horrible thing)
This is a boring answer but it works in wide locks. Narrow ones are different. One line from the bow to a bollard controlled by the crew. One line from the stern to a bollard controlled by the steerer. Leave the centreline alone, the boat will surge to and fro unless you keep it Really Tight. The boat will surge unless it is roped to the land in some way. Single handed? Just take it really steady.
I have 2 of these or similar cheap things that were a waste of money, 2 cheap electric ones that sort of worked briefly and one of those gizmos that run of an electric drill that will 'empty a fish pond in a couple of minutes'. The last one wouldn't suck more than a teaspoonfull of diesel from my fuel tank. I now have a cheap 12v electric one from E Bay that is mostly used by thieves to empty your diesel tank and I use it to suck water out of the fuel tank if any should collect in a corner, I should think it would be ok with warm oil.
The firmest foam we could find came from a supplier on an industrial estate - so more choice and info. than just a retail outlet. Its a blue high density stuff 3" thick and OK but it is not so great if the bed/seat base is slats of 2" x 1" spaced 2" apart. You need wider slats or less gap or thicker foam but you can end up with a 'Princess and the pea' situation with seat cushions a foot thick.
- 1
Yeah, black is not a good sign. To get it running take the filter off, fill it full with clean fuel, screw it back on, try to start the engine, If no luck try again but loosen a pipe to an injector and see if anything comes out, it really ought to. If it does fire up then run it for a good 10 minutes and check for leaks around everything you have touched. After that you can drain the fuel tank, clean it and refill with nice new fuel ........
Well it seems to be entirely the fault of the continuous cruiser. If only they moved every two days / weekend / 10 days / fortnight or whatever then licence and mooring fees would be a lot less. It is simply untrue. Who, then, do we blame for NHS waiting lists for example? a few years ago everybody was jumping up and down over mythical foreigners coming to Britain on holiday and getting their broken hips etc fixed on the NHS, all nonsense but a lot of people were convinced. Why is my library short of everything? people bringing books back late? Hardly makes a measurable difference. Potholes - Foreign lorries 'cos everybody knows they're overloaded. The reason that the UK canals are almost certainly the most expensive to use in the world is the same reason that HS2 will not be done. Partly Brexit, partly covid, partly Tory dogma that taxing people is wicked and spending enough on the assets and services that the country needs, water, sewage, health, social housing, welfare and much much more has to be paid for by the user. Canals are right down the bottom of that list but somehow its the fault of sections of the boat owning people. You can certainly fool most of the people most of the time.
- 1
I used to work with a Gordon Bennett. Grumpy old git, no sense of humour at all, daren't tease him about his name.
Woolhampton!!!! I've got a dent from going out of that place. But seriously there is not a lot that you can do, you can point the boat into the current but on canals there is not enough room to do that very effectively. if you have a bow thruster that will help a lot but all you can do is watch for water entering the canal and steer into it a bit, you might just end up where you wanted to be or you might not. Those slab sides on a narrow boat really catch the current.
I agree with the above. After seeing more than enough rust over the years I think a properly dry bilge is a Very Good Thing, that join between the bottom and the side and a few centimetres up the side can be vulnerable to damp and rust. Surveyors will test for thickness all over the side plating and look for pits but there can be bad things happening inside the hull too.
Well that was a shock
in General Boating
Bloody wildlife! Over the years I've had hibernating bees, one rat that lived (briefly) in the insulation around the oven, a hornets nest whilst building Bee, a moorhen that the cat dragged in and several mice. We have rescued a young hare from the K&A that jumped straight back in again, used the boat to drive a deer to a bit of bank that it could climb up and also a grass snake or two. We also woke up one morning to see the underneath of a red squirrel that was sitting on the roof above the bed doing something with its nuts.
