Alf27
Posts posted by Alf27
If any one is on the Narrowboatworld web team please can you check the "contact us" tab, as I have tried to comment on topics a couple of times recently but the link does not open. Thanks
How long is a piece of string ? So to answer your question, how long per day do you intend to cruise, will you be stopping & looking around the places you pass through, will you cruise even in heavy rain or wind, will you be ice breaking during the winter ?????
So it will take as long (or short) as you want to make it !
If anyone is in the area of Audlem this Thursday, full details - http://www.audlem.org/newsroom/headlines/give-crt-your-views.html
Go on, try it yourself, you never know you may be a natural !
- 1
26 minutes ago, Cheshire cat said:
I visited my prop last night only to find it was clear. It is easy enough to reach from the counter. The counter is low compared with some other boats. Unfortunately the fact it was clear means the minor vibration I have must be caused by something else. Perhaps I have tweaked one of the blades slightly although there was no obvious damage.
Once found that a new vibration was caused by an engine mounting coming loose causing the prop coupling to rattle
Park Farm Moorings, about a mile Barbridge side of Stanthorne Lock on the offside, contact Peter Oakes on Facebook - https://www.facebook.com/peter.oakes.90?fref=hovercard
Even in wide locks boats can get jammed by fenders if sharing with another boat, seen it & only just managed to avoid them getting serious damage !
On 3/27/2017 at 23:36, luggsy said:
Yes 12v, but on a boat with normal charging systems sometimes running up to 14.8 or 15volts they may not take the higher voltage, ideally look for bulbs with a voltage range of 5 to 30 volts to guard against premature failure.
Looking at it from another angle, if you reduce the voltage, will the light get dimmer ?
Many years ago saw a sign on the Thames above Newbridge " Mooring £25 per night" at the bottom of the sign had been written in felt tip "IOU £50" !
Try www.fortimber.demon.co.uk - Richard Potter in Nantwich good range of products.
Weed used to talk to the Flower Pot Men !
Blimey, excellent!!
Wot he said, well done !
Now getting to the serious point, did the volocky on Hatton say anything to you about dropping paddles ??
Getting coat !!
Has the stoppage been lifted ? Nothing on Stoppages saying still closed. Had e-mail regarding closure, but nothing regarding repairs completed.
Thanks
Make a seat out of foam & leatherette, shaped to fit the space between the handrail & cabin slide, removeable & comfort. Other than that a step by the doors to heave yourself up ! Much safer.
I have heard of fuel being stolen by removing the air vent & inserting a syphon pipe & replacing the vent fitting.
As above, posted whilst slowly typing !
Saw "Big Al" tied up on the Llangollen last year, at the smallholding on the offside of the canal just north of where the Nantwich Road crosses the canal about a Mile East of Wrenbury (Br 15 I think) Did not see anyone with it tho.
Hope you reported/complained about this to the local waterways office.
Also there is a house with it's own offside mooring in Middlewich between Bridges 168 (Wardle canal) & 169 which was advertising short term moorings last summer, give him a call on 01606 27zero1four8
117p/l (Flat rate no split)
Report this supplier to HMRC as that is not legal !
Similar pegs on the Tardebigge flight. Have used them when bow hauling a Hotel boat butty.
it would be interesting to come up with a source for those.
Type in Wylex plug in mcb into e-bay eg - http://www.ebay.co.uk/itm/wylex-plug-in-MCBs-Job-Lot-/141550350025?pt=UK_BOI_CircuitBreakers_RL&hash=item20f50eeec9
https://www.google.co.uk/?gws_rd=ssl#q=50cm+gas+cookerstart there !! ??
Narrowboatworld
in General Boating
http://www.narrowboatworld.com/
