Posts posted by pedroinlondon
Thanks a lot Alan and Tony.
I will check all that when I get back to the boat this evening.
In regard to the antifreeze question the answer is yes. I replaced the old with new about two months ago.
Hi all
Over last week's very cold spell the light on the engine temperature warning light came on, accompanied by the it's sister, the terrifying beeeeeping sound.
I switched the engine off and hoped that the complaint was about the ridiculously low temperature, but as switched it on again last night it happened again. I'm now guessing the engine is overheating and not very cold. (Sorry for not knowing much about engines by the way).
So which one is it and what are the most likely causes of this?
Thanks a lot
18 minutes ago, BEngo said:
Inline filters. Extensive filter cross references on their website. Decent prices. No connection, but I have had good and rapid service from them.
N
Thanks Bengo.
Hi
Any recommendations on service parts for the Cananline engines? I have a 52 I should service soon.
Looking for oil and air filters, mostly. The "original" Canaline parts are a bit expensive and I've seen a few on ebay but not sure...Any tried and tested sellers/links?
Thanks
Fair enough, one can have a facebook account with very little personal information.
Following a recent issue I had with my starter motor, I serched for information on facebook on canaline engines and found nowt.
It would be great to have one, as a first port of call when doubts or issues arise. Would anyone be interested in starting one? I could do it myself, of course, but it would be better that someone with at least a working knowledge of engines be the main admin.
Something like "Canaline and Isuzu boat engines" or something?
Even without knowing more about engines than how to change the oil, I already know of a couple of tips that could save Canaline boat owners a lot of money and grief, following my recent troubles.
Those could be logged in the facebook group for later ref. Of course, if they could be duplicated in this forum somewhere, possibly.
Please let me know your thoughts.
Thanks everybody. It was a perfect match and very easy to replace. Absolutely no need to tamper with anything. Canaline want £550 for it, I got it for £160 from the abovementioned ebay shop. Draw your own conclusions.
- 1
You can probably find where each wire is connected b experimentation.
You should have at least one thick wire that shows 12V when you connect a voltmeter This is the main input cable. If you touch each other cable in turn and see what happens you will know which one to connect to which terminal on the switch.
The "main input" terminal on the switch will almost certainly be a 9mm blade plus an extra 6mm terminal.
The aux (ignition on feed to instruments) will be a 6mm blade possibly twined. Just turn the switch on and touch the wires onto the 6mm blades until you find the one that puts the warning lamps on.
Turn the switch to heat and connect each wire in turn to the 9mm blade that probably become live until you find the one that feeds the heater plugs.
The last 6mm (usually) blade fees the starter motor solenoid.
Thanks Tony. I will try that if necessary.
Did you? I didn't get a notification but will look very soon. Thanks
I tried to trace it but it's in a hose like conduit. I will have to cut it open which I really want to avoid. Hopefully someone with a Canaline panel will be able to look behind it and send me a photo or tip.
You're right white is ognition and I've cconnectd that according to the manual diagram. These cables are thinner but one has a black stripe. Shame i can't post photos here. It would be more clear.
4 wires on the diagram and 5 on my boat!!
There are two wires together - white and white with black stripe) that are not mentioned in the wiring diagram. Any idea what that connects to in the ignition?
But the colours don't match (sigh)
Actually, just looked in the manual and there's a Cable colour list
Hi.
I recently destroyed my ignition and a kind soul gave me a replacement he had.
The replacement has a few initials by the different tabs (h for heat, in for ignition, etc) but the wires (photo) don't. Does anyone know the wire colour code? Thanks
Be aware that the one you've linked to doesn't specify a cross match to yours, though I've noticed the US sites seem to show the -63015 & -63016 as interchangeable.
You might have to graft the nose of the fried one onto a -63015 I suspect.
It's actually this one, which seems to be the same anyway... The ref printed on the dead alternator is a match (Mando MG117559).
You won't change the bracket on that without a full strip down I'm afraid. Not a big job and I could talk you through it bolt by bolt if need be.
Hi Sir Nibble. Are you talking about the supporting brackets? Surely not if you mention "strip down". I'll wait until it arrives, perhaps when I try to fit it in the place of the old one it will become clear.
Is the nose the part that goes inside the mother engine? I'll see if it's a good fit when it arrives.
"You might have to graft the nose of the fried one onto a -63015 I suspect."
What does that mean Richard??
These guys sell it too. I'll order on first thing tomorrow http://m.ebay.co.uk/itm/SL1325-KIOTI-DAEDONG-KUBOTA-L5740-V1902B-Starter-Motor-/371567475188?hash=item568325b9f4%3Ag%3AxNcAAOSwPc9Wu0QM&_trkparms=pageci%253A04ff11f7-737d-11e6-b861-005056bb6365%257Cparentrq%253Afaf491b61560a6a5ca28c3d4fff68912%257Ciid%253A1
I just called Canaline and they told me the starter motor for my Canaline 52 costs £552! Is this acceptable? If so is there a cheaper alternative?
Thanks Tony. I will call a recommended engineer in the morning.
Sorry guys. Been on the phone by the motor bay. Yes, starter motor not engine. May not be knackered just solenoid gone. The problem was caused by my stupid hot wirinh. Starter motor stayed on so it kapputed. Not sure about the extent of the damage until it gets looked at. In the meantime I'll get the ign replacement.
Hi. I lost my ignition key. This morning i try to "hit wire" the engine. It worked for a bit then i burnt the starter engine. Dies anyone know where i can order suitable replacements from? The ignition key hole is abiut 26mm in diameter. Thanks in advance for any links and tips
Sorry for the typos. Crap new phone
Canaline engine overheating (I think...)
in Boat Equipment
I cannot recall the ratio but it was at the recommended one on the container.
