Everything posted by pedroinlondon
Releasing air lock via the first fuel filter
pedroinlondon replied to pedroinlondon's topic in Boat Building & Maintenance
Great. I'll have to feel my way to it, if it's even lower than the fuel pump. Access it terrible on these boats, but with that photo it should be ok. Thanks a lot Tony- 9 replies
- fuel filter
- air lock
(and 1 more)
Tagged with:
Thanks Alan! Ala- 9 replies
- fuel filter
- air lock
(and 1 more)
Tagged with:
Good morning Tony Here are the two photos I have. I can take more this afternoon when I return to the boat. Thanks On a separate thread, Peugeot 106 said: It’s Lister Petter LPW 4 cylinder 40 bhp build 48 (marine build) built in 2007 also known as Canal Star or Alpha. All spares Manuals etc available from Richard at MES Midlands or Sleeman Hawker Dorset and others. Manuals and Parts List also available online FOC On a separate thread, Peugeot 106 said: ''It’s Lister Petter LPW 4 cylinder 40 bhp build 48 (marine build) built in 2007 also known as Canal Star or Alpha. All spares Manuals etc available from Richard at MES Midlands or Sleeman Hawker Dorset and others. Manuals and Parts List also available online FOC''- 9 replies
- fuel filter
- air lock
(and 1 more)
Tagged with:
Hi I need to fit a new tank, and by watching a few videos and talking to fellow boaters, I know that some important precautions need to be taken to avoid a massive air lock in the engine. I will use the existing "fuel to engine" and "return to tank" hoses, and am under the impression that a good way to avoid the air lock issue would be to: 1. Isolate the fuel filter. 2. Fit the hoses to the new tank. 3. Undo a bit the bolt on the fuel filter that releases the air. 4. Turn the ingition (without starting the engine) to "suck the fuel" out of the new tank into the hoses (and filter). 5. Repeat the process until no air comes out. 6. Start the engine. I learnt about steps 3. to 6. from the video below, which has a different type of filter, and it's a tutorial on how to release the air out after running out of fuel. That is not my case, so hopefully I won't need to continue the process on the injectors, only at the fuel pump. Please let me know what you think about this. The relevant part starts at around the end of the first minute. The attached photos are of the existing fuel filter in my engine. The engine is a Lister Petter PW4A48, but I'm not sure that's relevant for this matter. Many thanks! Many thanks!
- 9 replies
- fuel filter
- air lock
(and 1 more)
Tagged with:
How to chose a new starter battery?
And also "plastic shell, which is rust-proof" You can't go wrong with rust-proof plastic 😬 Thanks!! -
I undestand. Those are for the "standard posts" which are smooth and unthreaded. To avoid them and use cables with ring terminals I need a battery with threaded posts, or am I missing an alternative? Sorry Tracy,which connectors are you referring to? Some kind of adapter from standard to threaded posts? Thanks These? https://www.amazon.co.uk/QAQGEAR-Terminal-Compatible-243407F000-243407F001/dp/B09HGM7755/ref=asc_df_B09HGM7755/?tag=googshopuk-21&linkCode=df0&hvadid=641694953744&hvpos=&hvnetw=g&hvrand=17341636290188347663&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9046035&hvtargid=pla-1719653223826&psc=1&mcid=16818ffc281c3b4aae07173f68977dec -
I'm trying to find a starter battery of 700CCA or above with nut terminals but cannot... I can only find with I think it's called "standard posts" which are smooth and unthreaded. Can anyone confirm that the BBS rules require that the batteries are threaded and adaptors are not allowed, or was I wrongly advised? Example: https://www.tayna.co.uk/car-batteries/yuasa/ybx5110/ -
I'm planning on having solar panels charging the starter and leisure batts separately, as in my previous boat. I think it works better that way. I will have a dedicated solar panel and controller charging this battery, so it should be ok. On my previous boat I had that and the cheapo starter battery supplied by Collingwood lasted nearly 8 years. Thanks for the advice on the type of battery. Access to this one is very easy and the leisure bank will be easy also. -
Thanks Tony All three batteries will be removed, so no much problem in fitting a new one in this space, regardeless of the terminal position. As for charging it, I'll do that soon. These boats were on shore power all the time while on commission, but probably not after losing their jobs at sea. -
Thanks! That's the info I needed the most. Thanks Tony and Black Rose. For now I need to know what battery to purchase, I'll deal with the switches, charging options and regulation requirements next. -
Hello gentleman Indeed the battery bank must have been used for the lights and other instruments around the boat while in service, as there were no other batteries or battery holders anywhere on the boat. No labels on the cables neither. This was the setup, until we connected the Halfords "emergency" battery to get the engine started. Three Lucas 60ah batteries in parallel with some cables cut. A bit of a mess... -
Hi I have recently bought a boat with a 40HP Lister-Petter fitted, and the starter batteries left are no longer charging (Yes, plural batteries. There were three in paralel, I suppose for extra reliability, being a lifeboat) Anyway, as they are no longer useable, I bought a cheapo from Halfords which started the engine with great difficulty, so I want to get a new one. Before I get another not-great one, is there a rule for matching the horse power of an engine (or is it the stater motor that matters?) to a suitable starter battery? I'm guessing larger engines will require more amps shoved up their bums in a short amount of time, but is there a rule as such, or just more is always better? And appologies for question n.2, which might be even sillier: is there also a reccomended upper limit for the amperage discharge at all? Should you absolutely not go over a certain amount? Thanks
They would be doing the maintenance very regularly while the boat was on the oil rig at the ready, but it could be that it never got to move from storage somehwere, or that it was decommissioned soon after, in which cases no one would have bothered.
Thanks a lot Peugeot. I need the drawings asap for a tank change, and maintenance will follow later. This is an ex lifeboat and the fuel filler needs to be outside like a regular canal boat, and a few other things like a breather pipe and fuel return hose, whatever that may be. I'll take the opportunity also to remove the ginomormous diesel tank and fit a 45L. I'll probably post a new post on that one tomorrow... As for the oil change and maintenance in these past 17 years... not sure it happened. Thanks Tony
Thanks a lot. I got a manual from https://www.winget.co.uk/wp-content/uploads/2020/12/LISTER-PETTER-LPW-LPWS-OPS-MANUAL.pdf The pictures are insanely bad I should be able to find better ones now with the full reference. Thanks a lot everyone. I think I'll be able to find my way around the engine somewhat...
Hi. I have recently bought a boat with the pictured Lister Petter 40HP. I understand it is not possible to determine the Lister Petter model from the serial number alone, so any tips on what this is would be very welcomed. Ideally I would like to identify the type so I could get a full manual and drawings, if any are available on the light or dark webs. Under Type it has "L4-186GB", but google had nothing to say about that. Thanks
BSS compliance - breather pipes meeting BS7840 specification
pedroinlondon replied to pedroinlondon's topic in Boat Equipment
Thanks Bee. I know about the hose now, and will have to decide on the best type of vent for my purposes. I don't know yet if it will be fitted horizontally or not. -
Great. Thanks for that. -
Thanks David These lifeboats are enclosed, and do go under water completely when dropped from an height. No holes anywhere! -
Hi all I've bought a decommissioned enclosed life boat, which I'm told will require a few changes and additions to be compliant with the canal world/BSS exam. The changes I am aware of are "fuel pipe change", "external fuel tank filler" and "breather pipes" to meet BS7840 specification. The fuel pipe change and filler I think I understand. These enclosed life boat tanks are in the cabin and an external filling hole needs to be fitted, and the fuel hose must be compliant to the BS spec above. But what are breather pipes, and how does one fit them and to what? Tips with photos would be appreciated. Thanks a lot.
Simple boat sale documents and procedures
pedroinlondon replied to pedroinlondon's topic in New to Boating?
So please read this version. I took it from the RYA template. I'm sure they meant "Transferee" and not "Transferor" the second time. https://www.rya.org.uk/sitecollectiondocuments/legal/Web Documents/Legal Leaflets/Members Advice/Bill of Sale/BILL OF SALE.pdf Many thanks for all your help. I ended up learning stuff about banking I had no idea about.- 47 replies
- selling boat
- buying boat
(and 2 more)
Tagged with:
I feel like I'm buying a small or medium sized country rather than selling a boat with all this paper and banking stuff I wonder is there would be this much fuss if I tried to sell Cyprus or even Belgium to an American tourist...- 47 replies
- selling boat
- buying boat
(and 2 more)
Tagged with:
Indeed. I just realised that in the UK, unlike in other countries, the Banks are responsible to cover for most frauds. I suppose if their customers make it too easy then they would not have to. We're meeting for the bank transfer but the clerks are not allowed to witness signatures and we don't know anyone else in the area. Being London one can't just know of random doors or even walk in a shop and ask for a signature and address- 47 replies
- selling boat
- buying boat
(and 2 more)
Tagged with:
I won't include the getting the boat over. As that will be a favour it will not be mentioned in the contract after all.- 47 replies
- selling boat
- buying boat
(and 2 more)
Tagged with:
