I have a 600w Sterling inverter/charger combo. I've never used the charger before because I used to continuously cruise. However, now I'm in a marina I'd like the charger to charge the batteries off the shore line. Problem is, it doesn't seem to be doing anything. It appears to be wired correctly as per the instructions I have. It only has one switch, On/Off and two lights, Inverter and AC Power. When the switch is on, the red light comes on. When Off, no lights are on. Here's a diagram of the wiring:
The inverter has the 12v + - going to/from the batteries. There is also a 'Mains' cable coming in from the fuse box. This makes sense because the power comes in from the shore line (via the switch), into the fuse box then out to the inverter which should charge the batteries, right? So, is it a) wired wrong or broken?
