Hi All,
Please can I ask your advice on achieving a roasting hot shower all year round using an LPG instant water heater?
My boyfriend and live all year round on our 55ft Narrow boat. We used to have an instant Rinnai which did the job very well. Although the heater flames would cut in and out with the pressure dropping before the pump cycles, the heater managed to warm the water sufficiently to produce a wonderfully hot shower all year round.
Unfortunately the Rinnai packed up and I bought a second hand Morco D61b water heater for £150 to replace it..... However it is awful and won’t heat the water anywhere near high enough. It appears to be much more sensitive to our low water pressure and even when the flames are on full blast it just won’t produce hot water, only warmish water.
I am now on the hunt for something better but:
* The Rinnai instant heaters are not being made anymore and I can’t find one anywhere.
* I began to consider buying a brand new Morco to replace my second hand one (in case there is a problem with it) but have now read that the Morco can only heat the water 25 degrees above the original water temperature. This is absolutely no good considering the water in my tank is now about 4 degrees!
* I have heard that the Paloma's are good but can't seem to find one for sale...
Please can I ask what LBG instant water heater and pumps you you would recommend? I am happy to buy a new heater and pump (if necessary) so long as it will provide the hot showers I miss so much!
Thank you :-)
