tove Posted March 31, 2014 Report Share Posted March 31, 2014 Has anyone out there any experience of using a yagi antenna/aerial to get a better phone signal? Better still in a position to say how it would compare to using a high gain whip. Input very much appreciated! Link to comment Share on other sites More sharing options...
MikeV Posted March 31, 2014 Report Share Posted March 31, 2014 I did use one for a while but TBH it was a bit fiddly to align with the nearest phone mast. I used to use it with a data card inside the laptop and about 5 metres of cable out of the window. I only bothered to get it out of the cupboard if the mag-mount aerial I usually used failed to get a reliable signal. Since I've switched to a MiFi I've had so few places where signal strength on '3' has been an issue that I sold it on eBay. I guess if you're in a fixed location and your signal strength is very marginal it would make a difference. You don't say if this is for voice or data. If data, don't assume a better signal will get you a greater data speed. I find they are rarely related. I've had places where the signal strength was quite weak but had excellent data connection and visa versa. Link to comment Share on other sites More sharing options...
Chalky Posted March 31, 2014 Report Share Posted March 31, 2014 You don't say if this is for voice or data. If data, don't assume a better signal will get you a greater data speed. I find they are rarely related. I've had places where the signal strength was quite weak but had excellent data connection and visa versa. I did a lot of testing on this a few years ago. Exactly what we found - there is no connection between signal strength and connection speed. Link to comment Share on other sites More sharing options...
tove Posted April 3, 2014 Author Report Share Posted April 3, 2014 Thanks very much for the feedback. One of the problems is technology is changing so fast at the moment it's really hard to know which way to go... Link to comment Share on other sites More sharing options...
