Daltonn
Posts posted by Daltonn
If you're looking for a great choice, look no further, JOHNSON PUMPS will be an ideal marine toilet for your boat. Easy install and it works great, once I got the kinks worked out. Make sure your wiring is good, any drop in voltage will reduce its ability to pump to the required height.
Like Meguiar's, Star Brite is also a popular boat wash brand. It works effectively on both interior and exterior surfaces, including vinyl. Decks, hulls, fittings, and chromes shall be left spotless with just one application.
Meguiar's wash is the friendliest boat wash that I've used. It works well without stripping away the boat’s nutrients and wax protection. I don’t need to go through the hassle of buffing and waxing since it does that in just one easy step.
Checking your boat’s engine oil should be done 3 or 4 times every year. This frequency is enough to ensure that the engine can perform efficiently and your boat runs smoothly. Ensure that the lug nuts are tightened and the spare tire for the trailer is inflated, the trailer should be assembled properly. It’s advisable to use stainless snap shackles rather than ratchet straps. Don’t forget to check the coupler as well. It should be locked down to the hitch ball. Make sure that there’s no spill on the master cylinder cap seal and brake fluid.
A totally new concept in Fire Extinguishers
in General Boating
The United States Coast Guard maintains a meticulous set of regulations regarding boat fire extinguisher requirements. The requirement for fire extinguishers on a boat is contingent on the vessel's size. As a general rule, larger boats mandate a higher number of fire suppression systems compared to smaller boats. Therefore, a 30-foot yacht will necessitate more fire extinguishers than a 20-foot boat.
