Andy The Truck
Posts posted by Andy The Truck
37 minutes ago, mrsmelly said:
AAhhhhh from Guzz then. Quick quiz question for you. What was the first ship to go into the ooge Frigate complex in the Dockyard? I was on it listening to the band of The Royal Marines as we went in.
Oh I thought you were going to say you was there when the Royal William yard opened 😂🤣😅. No idea mate but it wasn’t me playing as you went past.. that was another Tuba player ... Gulpers mate 👍👍
2 minutes ago, Andy The Truck said:Oh I thought you were going to say you was there when the Royal William yard opened 😂🤣😅. No idea mate but it wasn’t me playing as you went past.. that was another Tuba player ... Gulpers mate 👍👍
I didn’t know Nelson ... but my oppo did 😉
Just now, Tracy D'arth said:
My small experiences with AS2 engines were that they were easy starters, slow to rev but solid. Incredibly noisy though with a definite roar from the fan/flywheel.
Very much like their cars .. except the noise .. very quite hence the motto for AS “As quite as the Sphinx “..
5 minutes ago, spud said:
I missed that bit, but yeah seen it now. Hopefully pine will find the right owner
Well I shall make enquires with the brooker and do a little more research . I only asked the question about length reduction as it’s never been a issue for me in the past .... unfortunately 😏☹️
23 minutes ago, spud said:
if this is severner pine then cutting it down for your convenience would be a crime against its history
That’s the one.. as for crime.. plenty perpetrated against the people of this country every day my friend .. but if you go back on the thread you will noticed that fate has now been circumvented .
17 minutes ago, mrsmelly said:If you dropped an Atomic bomb on Leeds, it would do 50 pence worth of damage. Much like Essex realy
Indeed .. but I’m not from Essex .. only have to live here.. so not that fussed about Atomic bombs.. and as I lived 4 miles from Devonport Dockyard as a child the threat of imminent nuclear annihilation holds no new fear for me 💥
Just now, nicknorman said:
Not really relevant to your question but I feel obliged to point out that Liverpool by boat is fantastic! Free mooring in the docks for a week, with power etc. Leeds less fantastic, admittedly.
Maybe as a trucker running out of the docks at Liverpool I only ever saw the worst side of the city.🤔
5 minutes ago, enigmatic said:
Full recommended dimension list is here: https://canalrivertrust.org.uk/media/original/32433-waterway-dimensions.pdf
The funny thing is it's the last 1'6 that's most likely to restrict you in the South, but most of it is officially OK.
You've definitely got leeway where you can place a boat diagonally (although sometimes less than you might think: the Huddersfield Broad is roughly the same length as my boat with fenders down, but angling a boat diagonally away from gates you need to operate and towards ladders you need to climb is fiddly, not helped by leaky top gates making waterfalls over your boat). With narrow canals, some locks have a bit more room to spare than others, and you'll always need to be wary of the possibility of getting the skeg caught on the cill when going down, and prepared to refill the lock and retreat if it does.
Shortening a hull is possible (more usually people cut up boats to make them longer!) but wouldn't be cheap.
All helpful stuff .. thanks
8 minutes ago, David Mack said:
A 71ft 6 in boat will happily do the whole of the K&A, and I have done so. That said there are some locks where you will need to take care - to get past the bottom gates you will need one gate open and one closed, and to shuffle the bow (if descending) or stern (if ascending) across to open/close the gate. Also be aware of projecting walkways on the uphill side of some bottom gates when ascending - don't get the tiller caught underneath. All this means you can't share locks with another 71ft 6in boat, but as long as the other boat is no longer than about 70 you can do it - the shorter boat has to enter last going up and leave first going down.
Anything over 57ft 6ins/60ft/62ft long is going to be unable to pass through locks on the Leeds & Liverpool east of Wigan, and some of the Yorkshire waterways, but you will have few problems elsewhere on the connected system.
Just what i wanted to hear David, Thank you.. As i suspected The 70MAX was more a guideline than a rule 😉 Not a problem with ever going to Leeds or Liverpool... I've been ... they are dumps
OK... Well I can return the industrial size angle grinder to its box... not required... Thanks
9 minutes ago, Tracy D'arth said:
Many old working boats are 72 feet, they managed.
Have you measured it? Accuracy was never a strong point with canal boats. It may be shorter than you think without fenders and with the rudder over.
A heck of a job to shorten a boat, which bit would you cut out or off?
A lot would depend on what the boat is, modern or old rivetted? Steel or iron?
There are dimensions published for all the waterways but some are known to be inaccurate and pessimistic. Where would you wish to cruise and moor? You are aware of the severe restrictions on CCing are you not?
Not measured the boat yet, only just seen it up for sale and the brooker isn,t in until tomorrow ..
I'd probably take out 18 inch's between the cabin and the front hold if possible Looking at the pictures its either a unfinished project or a not very well done self fit out in which case easier to strip out and start again and if its out the water and having a major refit just as well do all the work then and there..
South and Midlands initial areas of interest for me .
Have done the research into CC yes.
14 minutes ago, Alan de Enfield said:Is this by any change a 'vintage boat' ?
Living with, and caring for, a Vintage boat is very different to living with a 'modern' boat.
Edit to add - an old thread about the AS engines :
Funny you should say that... another brooker i talked to said that old boats are somewhat of a acquired taste.. As i own a 1926 Armstrong Siddeley Van, A 1935 Austin 7 and a Mule i think i fit into the Acquired taste category. but thanks for the AS engine link .
Hoping for some initial thoughts and advice.
I,m looking at getting into a CC life. I've had experience with coastal/tidal river boats but not inland craft. I've lived off grid before so the practicality's of day to day life on board doesn't worry me that much.
I've found a NB which interests me for various reasons , one of which is the engine ( Armstrong Siddeley ) as i own a Armstrong vintage car as well so a nice connection .
Boat i feel would need a complete strip out inside and total paint job outside , All of which is fine and have the money to do all of this..
But one question bothers me at the start is the length of the vessel ..71.6x6.10.
Please bear with me and cut me some slack here but questions are
1- Would 71.6 restrict me a lot on some of the Southern and midlands sections.. I've noticed that for example the K&A between Bath and Reading says 70max....absolutely no way to squeeze in at at a angle with a NB on a Wide canal ? Forgive me asking but like some road bridges the MAX HIGHT sign does give you a bit of leeway on trucks (30 years of driving trucks has proven this to me )
2- IF 71.6 restricts travel and the boat was having a lot of work done anyway is it worth / possible to cut and shut it down to 70 ? if done professionally would this cause problems ?
Other questions will undoubtedly arise but if travel is a deal breaker want to know before i bother to go view the boat
Thanks in advance
New Boater, Old Boat, Too long ?
in New to Boating?
I just like interesting projects 👍
