BigRoj
Posts posted by BigRoj
I suspect it means they're crap!
Had the same problem with a Moorhen a couple of years ago, stopped us going out for a month!!!
Unfortunately, they just disappeared (the eggs that is ) so I never got to see the chicks. Shame.
Steethay Wharf on the Coventry canal near Lichfield have 2 day boats. We hired both a couple of years ago for a party of 20 people. You can go as far as Fradley Junction (but not through locks) or down to Alrewas/Tamworth. Lovely stretch of canal, a few good pubs for lunch too.
It was £100 per boat when we did it, but maybe more now.
In all honesty Laural, you may be better off considering a new outboard with a decent 12v output to keep your batteries topped up. For the price of a decent Generator (Honda etc) you could be looking at a good S/H outboard with a 15-20A output. This would reduce the need for you to use and cart about a genny as cruising would keep the batteries charged. Another idea may be to connect a cheap solar panel to the batteries (a 5W Maplins unit for example) to keep the batteries charged whilst the boat isn't being used, then when you need the boat at least you will have starting power (and more) for the outboard.
I have done this for 5 years, often taking a B&Q genny with me, but never needing to use it.
What you could do to bypass that page is go to the log-on bit, do your signing in, but just before you press enter, go to your browsers bookmark tab and do a "bookmark this page" thing, then when you want to come onto CWF again just go to bookmarks, click CWF and you should go straight to the log-in page.
Took longer to type in than it does to do it!!!!!
Well done, there's no feeling quite like it is there? (with your clothes on, obviously)
I bet time will drag between now and the end of May!!
To comply with current regulations I'm told I must have a room sealed gas water heater fitted; if I fit one at all on my new N/b. That seems to limit the fitting to a Morco F-11E , cost with flue £535, that's without any inverter cost
Warning
This water heater was designed for domestic properties and requires 230v to operate. Therefore an inverter must be installed. Some chandlers are selling these water heaters without advising customers that they need to have an inverter.
My Question
The piezo ignitioned Morco D61B , cost with flue £234, can still be installed if it is replacing a similar unit in an older boat.
I logically think if this D61B unit is unsafe to install in a new boat then it must also be unsafe to install in an older boat. Or is it only people in older boats who are allowed to be endangered
I must obviously be wrong. Therefore can someone tell me why the piezo ignitioned lower price unit is ok for use in older boats but not for new boats? The regulations seem to be just adding unnecessary costs of approx £300, when building my new boat.
I believe it's to do with the fact that boats built since the RCD became effective must comply as such. Boats built before the RCD came into being are governed by the BSS as regards the fitting of gas appliances, that is, if a non room-sealed gas water heater was fitted originally then it can be replaced like for like as long as it complies with the BSS regulations. Special care must be exercised on a petrol fueled boat.
Rob at the BSS office will be able to shed more light on this.
I bought 3 of these, at £100 when they first came out 5 years ago, £50 3 years ago, and £35 2 years ago. The £35 one is still sealed in the box. The other 2 do sterling service powering, variously, a cement mixer, 1200W Bosch drill (although it does trip out now and again), angle grinder, polisher, sanders, and power for the 1220 charger on the boat and the main electrics.
The cheapest was bought as a source of spares for when the other 2 packed in. As yet they haven't!!!
If it's a fiesta based van engine, it should rev 'til the govenor cuts in, which will be just under 5000 as long as no-one has mucked about with the stop screw. If it's a marinised version with the heavier flywheel, then 4000 should be your limit unless you have any documentation to show otherwise.
If it's a Turbo version, then things alter again!! But 4000 would still be the safe maximum that it will run at.
As I said, it was just a guess. After all, I am just a mere Mechanical Engineer, what would I know?
This is a guess, but I would imagine that when the lock is full, and the single gate is opened, all the water of the previous pound is up against the end gates. If it was a single, there would be a lot of strain/pressure on that gate. However, a double gate is wedged in a V shape, and is thus more able to accept this pressure, and make it more water-tight than a single gate would. The only time all the previous pounds water pressure is on the single gate is when a boat is exiting the bottom gates. (which is why you should keep the gates closed to conserve water)
I suspect also that double gates will be used where there is a long pound and a deep lock.
Possibly.
Hello Tony, being brave then eh?
From Meadow Lane Lock, onwards on the Trent, your stopping points will be:
Holme Lock (Very deep, 13 ft normal) moor upstream, pontoon at lock exit.
Stoke Lock, pontoon upstream, alighting point downstream lock exit.
Gunthorpe Lock, Pontoon 200m upstream, mooring on upstream lock wall.
Hazelford lock, mooring upstream and downstream of lock, probably the prettiest lock on the Trent
Farndon, mooring near the marina and the pub.
Newark Dyke section, mooring opposite the castle and through the bridge down to the pontoon, also at the Kings marina, but there's a fee I believe.
Nether lock, mooring below near railway bridge
Private pontoon mooring available at the Muskham Ferry pub, by appointment I think.
Cromwell lock, mooring above on pontoon and topside lock wall.
Then make sure your bladder and anything else is empty once through Cromwell and onto the tidal stuff, the next stop you could make for, ahem, 'comfort breaks' is quite probably the staging at High Marnham power station (disused)
There's a pontoon at Dunham,
Torksey next, pontoon below the lock
Gainsborough, pontoon
West Stockwith lock, but I would think you'd have to pen through to moor up.
Finally to Keadby and through to the Keadby canal and there's mooring through the swing bridge.
At this time of year, and being solo, it may not be a good time to do Trent falls and on to Goole or Selby or York. Be far better off going through Keadby and onto the South Yorks navigations and Aire and Calder, if only so you can stop where you like when necessary! (Also, you have to pay to go through the lock at Goole)
Good luck, the Lock-keepers will advise you whats what once you get to Cromwell, but you are advised to phone Cromwell 24 hours before you go through, just so they know you're coming and can 'book' you in.
............................what i was saying was why does it take an old deep cumbersome working boat to do this job as implied
Simply because they can!!!
Surely, isn't it better that these boats are used for for a job like this than just being left to rot? Or, heaven forbid, altered beyond recognition so that their original purpose is all but forgotten?
I might be missing something here, but why would you want to plug it into a modified (from an inverter) 240v socket when the original voltage is 12v to begin with?
Personally, if you want to power some 12v equipment, then using power direct from the battery would be more efficient, even when on a mains hook-up.
I know where you're coming from with this though, you've got something that looks handy and it would be a crime not to use it. Whereas in fact it would be a crime TO use it, specifically on a boat.
With 12va per output, that's only 1 amp at 12 volt. You would have to use the outputs in parallel to get a decent va rating. And then it needs rectifying to get 12vdc, so there's going to be losses there too.
For the boat, it's probably not going to be worth it.
Sorry.
As I'm sure you'll do exactly as you please Mav, and probably end up with a 72 footer in the end, think on this:
Are we here for a good time or a long time?
BTW, what is it with Dawncraft? Loads of people swear by them, but I can't quite see the attraction. (This is the polite/diplomatic version
TBH Andy, I'd be inclined to do away with the Gennys battery and charger and run cables straight from the main engine starter battery. If it's an inbuilt unit as you say and not likely to be shifted, it will add to it's starting reliability and take away the uncertainty of the gennys own charger.
Sometime I see them mooring up three abreast even when there's plenty of space to moor and no obvious demand for visitor moorings.
What's that all about then?
I suspect it's the same mentality that some caravanners have with these so-called 'club' rallies. All that's missing with the Nb lot is a flagpole with a pennant hanging limply from it. In other words, a lack of individuality!
(Mind you, at least caravanners do it in a field in the middle of nowhere, and only block the roadway going to and from their Jamboree)
Bloody irritating, one or two interesting bits but not really up to the previous series' standard.
As for that Welsh sort and her proper/put on accent.........................
Hello Dick, like any other insurance, you will only find out how good it is when you come to claim, but if the relevant authorities recognise it then it must be ok!
Does sound a good price though, does it cover you for excursions into the sea/tidal bits? Some companies exclude tidal or only allow a set number of days per year on tidal water and then only as transit journeys from one inland river to another.
Castle Park moorings in the centre of Leicester are delightful, and as secure as any other locked mooring. We had 3 nights there (a 2 + 1 night before anybody shout 48 hour) and apart from some gay pirates in an Inflatable dinghy at 1am one night (which was both entertaining and surreal) we had a very pleasant stay. No facilities though. Unless al fresco behind the bushes is your thing.
[The HBF enters. Hands BigRoj his coat, and leaves]
And he wasn't even in the virtual Pub, either!!!
The 'net, when it works. I strongly object to paying around three and a 'alf 'nicker for old news from a magazine, 50p for a bunch of daily lies, and £1.50 for a weekend load of filth and lies.
The 'net WILL give you the information you seek, it's a question of finding it. And along the way you will almost certainly find out something you didn't know, even if it's only that Bones has a column in a magazine!!!
Good one, although how do i explain to Mrs G that im of to work on a haemorrhoid?
Thats an easy one, just tell the good lady you have 'Piles of work to do'.
My pass has been signed for the 24th
I'm coming on my own
As Mrs. Mole is working on Tuesday 25th, she really doesn't fancy the trip, or more particularly the drive back.
Poor deluded soul seems to think I might drive home the same night, but that's never going to happen
I may have to kip in the car and be away by 06:30, but that's not a problem.
See you there
Nice one!! Got your Pink Ticket
What a waste.
in Boat Equipment
It always amazed me when I had to visit the local caravan/motorhome showrooms (ie, Brownhills & Lowdham Leisureworld) that they had these TV/DVD combos which ran off 12v at only £400, what's more it was a CRT TV too, so heavyish.
The price sticker was liberally sprinkled with the words "Only" and "Just" and "Bargain price of".
AND people paid it!!!
Go to most Supermarkets and you will find a DVD player for about £15, and a 15"LCD TV for around £120-150, both of which generally have 12v mains adaptors!!!
Silly!
