Posts posted by Derek head
good morning ,i have a 48 foot narrowboat would a petter av2 be enough power on a river like the thames
yes im putting it in my boat? , the other one stashed in the corner is seized , both barrels have about 2" of solid rust in them , gearboxes and clutch are good on them as are the heads and starter motor , i am keeping the in injector pumps and injectors as spares and pos a few other little bits , do you need any bits then
finally got mine going CV VIXEN HDW mk1
CV vixen
- 2
35 minutes ago, Fitter kieron said:
Hi Derick. I've been looking out for a HDW manual for 8-9 years now whilst running / owning my engine with no luck. I do have figures for head nut torque, bump clearance and valve clearances if you need these. I would like to know a bit more about setting up / balancing the injection system myself as I think one of my cylinders is working slightly harder ( exhaust is slightly hotter to touch on one side ).
i have this send your email adress and ill send you a scanned copy
- 2
On 02/01/2020 at 19:11, Cheekychappy said:
THank you all for your advice, I visited the boat today and took the injectors out and did a compression test, I got 200 ibs foot and 220 ibs foot so happy with them. I set up to do a fuel flow test and found the throttle linkage solid, by disconnting one at a time the problem was that the fuel pumps were solid, I feed them off with WD 40 and worked the springs up and down till loose, all good so far. I balanced the fuel quantity but found the diesel that came out the injectors was as white as milk, the spray pattern was not that good either. I checked all lines from the fuel filter to the pumps and the fuel looked clear. When I undid the fuel line from pump to the injector fuel was white, this was the same both with both pumps. I am putting 2 and 2 together and linking water contamination plus initially sized pumps equals contaminated fuel. My manual recommends sending the fuel pumps to a specialist, can anyone point me in the right direction
Hi I noticed you stated " my manual recommends sending" I have been searching for a manual for my hdw and cant find one the hdw and had are the same except for the cooling so I'm asking where did you get your manual from please derek
petter av2
in Vintage Engine Forum
i want to cruise mainly on the canals but its nessasary to to go on the thames and a few other rivers for connections
