Kahana 2
Posts posted by Kahana 2
Umm not sure havent seen a skin tank set before poss not common in nz is that a keel called type set up ? The reason was I had a starter fail so I've been hand starting for last 10 yrs or so and what is didnt know was the starter was providing current through cyc1 and it has some corrosion within the cooling area thought this might help keep it from continuing to do any further damage and keep salt built up at bay.
Currently it working well thou
Hi guys
just wondering if any one has any pics or advice as to how the set up heat exchanger on a stw3 any similar pics welcomed. Still raw water cooling currently and just picked up a tube style exchanger and header tank
Cheers
Garrick
yes idles nicely just wont hold higher rpm's thanks for the pic bizzard will try this out
6 hours ago, RLWP said:
What happens with no load, will the engine rev and idle properly like that?
Yes idles nicely revs struggled to hold max rpm and drops off no smoke
Cheers guys i meant rack sorry , I'll have a look later a see if there is movement
Hi Richard
I have just had a STW3 put back together recently love the pics very handy to see, I think I have stuck rails as the engine doesn't want to hold revs and is'nt powerful enough to make way any suggestion welcomed .
Cheers
Garrick
fitting a heat exchanger to a stw3
in Lister
cheers Tony sorry should have mentioned its a sea going vessel its running a wet exhaust and has a cam driven jabsco raw water pump..
Listers aren't that common in NZ seen anything useful on you tube as yet.
Thanks sorry Umm not sure havent seen a skin tank set before poss not common in nz is that a keel called type set up ? The reason was I had a starter fail so I've been hand starting for last 10 yrs or so and what is didnt know was the starter was providing current through cyc1 and it has some corrosion within the cooling area thought this might help keep it from continuing to do any further damage and keep salt built up at bay.
