Posts posted by Black Country Lee
Damn, foiled by a horseless carriage lol
Lee.
It's more likely they wanted to moor there lol, the amount of hire boats I've seen moored in the middle of blind bends....
Lee.
So you cant rope round them to make a button fender?
Yes, still flimsy though. Try a scooter dealer for scrap tyres (they have to pay to dispose of them so gladly give them away), they are much stronger in the sidewall.
Lee.
Soap scum + oil/fuel residue = a thick sludge that'll block any filters (if fitted) on bilges. Is there room below the shower tray/bathtub to fit a sump and pump? Or possibility of lifting said shower tray/bathtub to accommodate one?
Lee.
A rather modern boatmans cabin that would be, rather have a trad myself.
Lee.
I have a 24v Jabsco par max 4 which says 4 amps at 10psi but, given it is a 25psi pump, that doesn't appear helpful?
Have you factored in the 2.5% difference in psi? It wont be much higher but worth factoring in for wire specs even if not for fuse purposes. I'd rather over cable for 18 metres (whatever they are (almost 60 foot in my mind)) of buried cable and under compensate the fuse?!
Lee.
Just blowing the dust off myself here, it looks a comfy foredeck at least lol!
I often thought of buying a butty and a mini, drive the mini on the back
I'd rather have a working boat with a caravan on it lol.
Lee.
Thanks everyone for your time and input.
Unfortunately is does look like it's the head gasket.
I'm out in the sticks at the moment so I'll have to work my way back to civilisation where I can get transport, deliveries, etc.
Rob....
If you're anywhere near me (Dudley No.2 Coombeswood Arm (the old way to Lapal Tunnel)) I've a full tool box, a few chilled beers and enthusiusm
Well, I am leaving this in the hands of grown-ups. Richard is going out tomorrow
I thought you said grown-ups lol
Grown-ups!
I've never been so - well - honestly....
Richard
See, you made him all big-headed lol
I am a grown-up in that I am er... old.
I'm a T-shirt wearing member of that club lol. If there's anything I can do to help you know I'll be here
Lee.
I'm struggling with reception here :-(
Climb a hill lol
Hi folks, Nigel is having signal probs at the mo.
If I drove I'd head up there
Lee.
A feeling I know all to well! Can you post a pic Nigel?
If I can help in anyway just shout/pm
Lee.
<snip>.
If the head gasket is on its way out and letting gases into the system, why would it stop doing so after a few minutes?
Rob.... </snip>
If it is combustion chamber to coolant channel head gasket failure it may be stopping after a short while due to gasses clearing the coolant channel of coolant. The pressure would be enough to keep the channel full of air and not allow the regress of the coolant.
You could check this by letting it foam till it settles, switching off for 5 minutes allowing the coolant to settle back into all the cooling system chambers (don't top-up the system at all) and then restarting. If you get a fresh lot of foaming then I think you've found your culprit unfortunately.
Lee.
I'll be there, most likely on the C&RT workboat 'Stour'.
The Cat won't be there either this year, which is a shame because I like the Stourbridge Rally. We could go without the Cat, but it's not the same, and I won't be able to time myself down Delph. Although I'd probably be slower than usual now that I know there are 9 locks there and not 8.
If you need a runner at the Blowers Green/Delph 9 just shout, I'm only just up the road
Lee.
Stourbridge is definitely on. I was at the Bonded Warehouse on Weds and Colin Clements, the manager and harbourmaster, told me that 66 boats were booked in, though he thought the weather could deter some. I'm going tomorrow morning to add some roses to a panel for a customer and could well return for the evening session. I thought of taking Resolute but a swollen knee has left me hobbling and locking wouldn't help at all!!
Cheers
Dave
Again, more than willing to crew up/run locks if needed
Lee.
Is she coming all the way to you Ruthsmate?
You could make a fortune selling these to vandals.
£50 with a windlass lol.
Lee.
I was merely offering a suggestion on the over-fueling, the stalling could be a myriad of causes. Most likely a diaphragm or actuator in the injector pump although diaphragms don't tend to tick lol
Lee.
As a mainly car mechanic my opinion, as is yours, that the black smoke is either over-fueling or under-fueling (weaker mixture). The ticking is often the sign of a sticking injector which, if stuck or sticking open, can cause the over fueling issue.
Lee.
Thanks everyone, 5 minutes in the workshop and done! A long reach broken torx bit, a deep 1/4" socket and an old bit driver later and I have...
A nice easy 'bodge' until I can sort my big tool box out where I think my genuine anti-vandal key is. At least I stand a chance of getting up the Delph 9 and the bottom lock at Brewers Green now
Thanks again folks
Lee.
Thanks again Alan.
Thanks Robbo, that confirms the 1/4" or 6.35mm theory of Alans, I'll go have a play in the workshop then
Lee.
Thanks Alan, I've had some very tight attempts with mine, luckily I'll be on the Dudley No.2 and these are fairly forgiving. Problem is I've got move a boat for someone this afternoon, he doesn't have one and I can't find mine so I was going to make me a spare one lol. Any idea on a rough dimension for the square itself?
Lee.
Just a quick question, can anyone measure the size of the square hole in the end of the key for me please? Thanks in advance.
Lee.
Such a pity, I have a real soft spot for the H&W town class boats.
Lee.
Thanks Lee.
Even more than what's in the system already?
Rob....
Yes, you'll only need a couple of psi, 5 at the most, to show up any leaks.
Lee.
In my years mechanicing (is that a word??) I've often found the easiest way of checking for cooling system leaks is a cold pressure test. A spare expansion tank cap drilled out with a standard tyre valve fitted, apply a tiny amount of pressure (I use 2 pumps on a bicycle hand pump) and any leaks will become very obvious. HTH.
Lee.
shower straight to bildge
in General Boating
lol
Lee.
