gibbu
Posts posted by gibbu
the toilet is a cassette toilet...
the problem is that we get variable amounts of water, and it doesn't just run back in at that time, it seems to build up overnight. maybe it is just water from using the sink in the galley and we hadn't realised yet...
hey, thanks trackman. i guessed as much with the water in the bath, but surely we don't have to put up with that!! what's the solution? is it this one way valve - are these usual to be fitted? or could the plumbing be re-configured somehow so this doesn't happen?
thanks for the info about shutting off the water supply - i will be sure to isolate the water and drain the system as you suggest, and also have a bucket handy of course!
Hiya,
We are about to attempt a bathroom refit on our narrowboat. We are stripping old the old (very) compact bath and possibly replacing with a compact corner bath to save a bit of space. The plan is to go from a bathroom off a corridor, to one the whole width of the boat but with a entry/exit door in each side (if you know what I mean). We're pretty new to narrowboats, but we plan to do it ourselves - it doesn't look that hard!! (we'll see).
Main problem: since we have had the boat, sometimes in the morning, or if we haven't been onboard for a day or so (we are in the process of moving from our house onto the boat) there is a small amount of often smelly water accumulated in the bottom of the bath. I don't really see how we could be taking in water through the outlet. Sometimes the pump takes a while to get the water out. Is anyone familiar with this problem? Is it an issue with the plumbing, or with the pump, or what??
Second problem: this is more ignorance. But as the water in the boat is not under pressure (unless the pump is on), then can I take the pipes off the bath/sink taps without water flowing out of the them? If so, then I guess I need to seal them off at the ends before I use the water pump in any other area of the boat? That's probably a ridiculous question, but whether it is or not, I would appreciate some advice!
Thanks in advance!!!
Hi. We are carrying out a partial refit of our narrowboat. At present the shell is lined with varnished and veneered 3-ply and we intend to paint the interior an off-white so that it doesn't feel like the 1970's. We're pretty new to this, although not stupid! So far we have sanded and then wood-fillered any holes and rough parts, and then re-sanded. Any areas that are a little worse for wear around windows we have sanded a bit more aggressively, covered with a wood-rot treatment, wood fillered if necessary, and then finally roughened up a bit with sandpaper so that the undercoat/primer can take hold. We have used a damp proof white emulsion undercoat (Wickes own brand), and then plan to cover that with a silk or matte finish top coat. Does this sound like a decent course of action? I'm presuming the top coat should not be water-based? Can anyone suggest a good paint type to choose from that's available in somewhere like Wickes or B&Q? We have only completed one room so far, and then it occurred to me that maybe we could have gone with a one-coat (combined primer & topcoat) wood paint, thus saving time, and possibly money. The boat (65ft 1998 narrowboat) is not damp, but a damp-proof undercoat/primer seemed like a good idea to us at the time. Any thoughts would be much appreciated!!
Bathroom refit
Thanks to everyone for your help and advice!! i'm pretty sure i know what to do now, or at least I hope i do. now that i have removed the bath and the sink it seems that the original plumbing was pretty shoddy, but it shouldn't take much to sort it out, especially with your help!
