lmanton
Posts posted by lmanton
Apologies, yes, I should have added that info in the OP.
Thanks to all for the replies, it does seem I have a major fault and an unusual on at that!
For sure it sounds expensive and difficult
Like Allan, I can't see how engine oil could end up in the gearbox.
Generally gearbox oil looks virtually like brand new oil, but engine oil loos contaminated and black.
If it were somehow possible that the increase in your gearbox was from engine oil, (and I still can't see how!), you might expect the oil in there to now bo looking less than pristine. Does it still lok like it did before these problems ?
Thank you both for your replies.
It was definitely from the engine as I had to drain about 750ml of black engine oil from the gearbox as it was nearly full to the top of the gearbox. It was still steady black consistency without water mixed in.
It was also weeping out of small 1/2" diameter hole in flywheel housing just above the gearbox.
I am looking for some experienced advice please?
I experienced a loss of power when cruising at steady pace, with BMC 1.5 reconditioned engine with an older PRM Gearbox.
Before setting off I had checked oil level in engine and gearbox and all was correct. When lost the power I stopped and check the levels. I was amazed to find the engine oil level had reduced and the Gearbox had excess oil level.
Any ideas please? Thank you.
I used to have the same problem.Ended up spending £120.00 on a decent crimper. Its money well spent and makes cable work a pleasure not a chore. My mates think so to lol.
Please could you post a reference to the model you bought and where? There seems to be a lt of websites selling them, with a vast range of prices. It is good to have a recommendation on a pair. Thanks.
I recently did ours.
For (4) I did Vactan followed by Danboline. Looks great
Tony
I need to do the same, thanks for the advice.
Did you use a red oxide primer on top of the Vactan or just paint on top of the Vactan with the grey?
Leigh
Hi Everyone on the forum,
My name is Leigh and I have been fortunate enough to purchase a 48ft Cruiser Narrowboat on the Regents Canal in Little Venice, London with a mooring.
The boat is very tired and in need of some TLC and renovation. I am looking forward to bringing it back to life with a refit.
The forums are proving invaluable for advice and information as I am new to boating.
Look forward to meeting some of you maybe in the future.
Thanks
Leigh
Engine Oil in Gearbox??
in BMC
Not sure what an oil shear is...but engine still starts fine and runs ok, there is just little power on the driveshaft. When you empty he oil from gearbox back to dipstick level the power is better until the oil returns to gearbox. The housing may well be half full of oil as I had to put some more back in the engine to keep te levels up on dipstick. At least 2-3 litres i would guess.. Thanks for the replies.
Forgt to say engine sounds ok, with no unusual noises. Thanks
