sjc
Posts posted by sjc
Did anything on the smart charger you installed touch the hull ? ( earth connection, case, mounting screws etc ).
The fact the previous owner never left it connected to the shoreline may be answer, maybe EOG moorers should be wary of this and use an IT.
Whether it was the soar array or just a floating earth, we may never know unless your insurers look into it further.
I hope that isn't the end of your canal boating, the other issue is none of us know how our insurers will respond until it is too late - typical...
Sorry to hear this, a very sad story, it is your worst nightmare as a boat owner.
Is it possible the corrosion was already underway when you bought the boat but you were not warned about it ?
Failing that something must have changed since you took ownership ? Any new equipment on the boat, any new electrical work done, and changes in neighbouring boats / equipment, did the previous owners keep it constantly connected to the shoreline, have you kept the same mooring, and shoreline supply. Although the GI was working, did it have an LED indicating when it was conducting, and if so did you ever check it randomly to see if it was on.
If it spent more time on shoreline than cruising, it is a fair assumption to assume this is where the corrosion took place. The only other possibility is perhaps a faulty supply, with a DC voltage on your earth perhaps ( possibly as indicated on the solar farm document referenced in an earlier post ). ( hence the GI LED question ). I believe marina's must comply with strict safety standards for electrical supply, maybe EOG moorings are unregulated ?
Having read this and the other recent thread on corrosion our boat is out of the ware, ha all electrics removed, and is completely encased in fibre glass...
Just did a quick test on my panels : 3 x 100W in series. Blanking out a single cell, then multiple cells on the same panel had a very different effect to that in the video. As I would expect you only lose half a panel for a single cell, or a complete panel for multiple cells. But we don't have the benefit of a clear blue sky so the clamp meter was forever changing. It looked like the MPPT took a few seconds to re-adjust then things continued as normal. So I have no idea what went wrong on the video, they had the perfect opportunity to carry out a scientific test but left unanswered questions instead !
Your description is correct which is why they have bypass diodes, to prevent this happening. Maybe their panels did not have bypass diodes ?
If I have remembered correctly, the series connection dropped from about 15A to about 1A when just s single cell was in shade. I am struggling to understand how this can be true, anyone care to explain ?
This is where the CE markings come into their own. The standard would state the current and duration before a relay could claim to be rated at that value. BUT, how the general public knows which CE numbers to look for is a mystery, apart from Google of course !
Not wishing to get political, but the British Standard kite mark may be making a come back and replacing the CE mark !
I would suggest he following :-
1) Protect it from direct sunlight as this may affect the outer casing.
2) I agree with Tony about the wicking, it is usual to seal the ends with pvc tape or similar to prevent moisture ingress.
I am assuming the Adverc replaces the alternator regulator ? In which case it certainly looks like an Adverc fault. Sadly I am not familiar with the cable colours on your chart, could you add signal names so we can see what each one is doing ( eg : main output, regulator feed, ignition lamp etc etc ). The values you say are varying, are they at the 0.5Hz frequency as well ?
We have the same inverter, and the same problem. It runs for months without the fan coming on, then it will run constantly for days on end. I also wondered if it was more frequent at night, but I don't think it is. At one time I turned the inverter off for a few minutes then back on again and it seemed to "reset" the problem. It had absolutely NOTHING to do with ambient temperature or current drain. I exchanged many emails with the Victron technical contact but they were of no help, eventually telling me to return it for them to examine. I never did as this isn't convenient, at the moment things are quiet ! I wondered if it was a software fault switching the fan on accidentally, but the previous post about connectors is a thought.
Fair enough Dave, each to their own. The shunt method is more common and what people would think of first and foremost. But any solution will involve a compromise, whether people realize or not. I haven't re-checked the specs recently but seem to remember linearity <1%, and the electrical isolation appeals to me.
Also, with a shunt ( say 200A == 50mV ) you will need to use an op-amp that will run off a single supply ( 0 -12v ) AND operate right up to its' voltage rail ( not all, especially the cheaper ones do this ). Otherwise a dual rail device ( +/- 12v ) could be used. As for accuracy, to detect 50mV on a noisy electrical system is quite an achievement, as for your 1A error, that involves a 0.25mV drop across your shunt, you do not have a hope in hell's chance. People think because the display shows 3 or 4 decimal places it is accurate, often those digits are a work of fiction ! ( unless you spend a fortune on expensive circuitry ). Even 10A requires detection of 2.5mV, if you put a scope on the signal and checked out the voltage spikes you would appreciate the challenge. You will always have a value, and a figure on display, but it is not much more than a guess ! There are clever filtering techniques but you would need a Paul Daniels filter for that ! Good luck and please post back the outcome !
This subject has come up before so if you search the forum you might find it. I would dis-regard the shunt method altogether and get a hall effect current sensor ( see link below for examples from Farnell ). I doubt they are more expensive than the shunt ( with extra electronics required ), are more accurate, more linear, provide electrical isolation, and give a simple analogue voltage output proportional to the current. ( probably 0 - 5v or similar which could be reduced with a simple divider ).
Yep, I completely missed the 24v point, in which case should be fine ! Never the less something for the 12 volters to consider !
At 300W you are already beyond the max ( 20A ) output of the Tracer, 400W exceeds both options ! I suggest it is better to have spare capacity in the MPPT ( ie : get a 50A ) as it would allow for system expansion should you decide to do so, more importantly it will mean the MPPT runs cooler on a hot sunny day when the ambient temp in the electrical cupboard is high.
If the motor was completely locked I would have expected a fuse / circuit breaker to activate - hmmm
Alan is spot on, I would add the following :-
1) Do a sanity check on the wiring to ensure the diagrams are correct.
2) Check for a Galvanic Isolator or Isolation transformer
3) Carry out a power audit.
4) Check for leakage currents etc to catch any problems early.
5) Check fuses / mcb's operate as they should.
6) Try to assess the condition of the batteries.
7) Do you have a dedicated alternator for the starter battery or a split charge system ?
All the above have been covered elsewhere on this forum.
Otherwise, you seem to have the basis for a good system.
From the age and description it could be the motor not starting because the brushes are worn. This happened to us and we swapped out the motor ( luckily a warranty issue for us ! ). You may be able to tap or wiggle it ( gently ) into life intermittently, which would confirm the diagnosis. This assumes you have done nothing to it, or near it recently, that may have affected the wiring, first thing would be to check fuses, wiring, and a voltage on the motor terminals when it should be flushing.
Divide by 10. That allows for inefficiencies. It's also erring on the safe side.
500W @ 230V is still 500W @ 12.V, it's only the current that's 10 times as large on 12V (taking inefficiencies into account).
Tony
This is somewhat misleading, the current at 12v is 20 times that at 240v.
Example to estimate average continuous drain :-
Rating : 365KWh per year ( often given for white good etc )
Where : 24 * 364 = 8760 hours per year
And : 365Kw = 365000W
Divide rating in Watts by Nbr hours per year :-
Power : 365000W / 8760hours = 41.7W
Now divide by appropriate voltage to get current drain :-
@12v : 41.7 / 12v = 3.5A
@240v : 41.7 / 240v = 0.174A
Notice the current at 12v is 20 times that at 240v.
when OC71 / 2s were about the best you could buy (I still have an OC72 I purchased that cost 17/6 and came with 2" leads packed in an individual cardboard box) I used to lust after silicon NPN transistors but couldn't afford them for a long time. I can assure you that Wireless World / Practical Wireless
were full of circuits drawn in this fashion. I certainly had a couple of textbooks on electronics using this method.
Someone told me if you scrape the coating off an OC71 you then had an optical sensor / switch. I never tried it but if you have any left perhaps you could, then let me know if it is true !
Consider the following ideas :-
1) An immediate start of the alternator with a heavy load already attached could force the regulator to overshoot ?
2) A step input to the batteries ( do they present a capacitive load ? ) will force a short sharp current pulse ?
Provided he can check regularly that the dehumidifier is working, it is adequately rated, that it drains into the sink, rather than a closed container, and that any openings are closed (to stop the dehumidifer from trying to dry the world) then that should be the best solution. The boat will be kept dry and heat from the dehumidifier will help prevent freezing in the winter.
If he cannot guarantee that the dehumidifier will keep working, then plenty of ventilation and either moving the mattress away from the sides and/or using drymat is the next best solution.
I used to go for the ventilation method, but still got some condensation when a wet spell was followed by a cold spell. Since using the dehumidifier (a Meaco DD8L Junior) I have had zero condensation.
I agree, we have the same dehumidifier and wouldn't be without it. I also think you need warmth, so keep the fire going, don't let it get cold. As already mentioned ensure there are air gaps everywhere : cupboards, wardrobes, around the matress etc.
The problem with most Hall Effect sensors is that they're not terribly accurate.
Tony
Just looking at a typical supplier, accuracy ( within 5% ) isn't an issue, although cost might be :-
You can get hall effect current sensors that fit over the cable like a sleeve. Admittedly a pain to fit but you have no problems with safety as they are completely isolated from the high current cables. If I ever get around to it that's what I intend to use, not sure if any commercial ammeters use them though ?
Smartgauge enhancement ?
For the record I think it is fine for what it is, personally it would be great if you could also be told the total capacity, or at least that remaining. It has been compared to a car fuel gauge, they now give an indication of miles to go, perhaps the smartgauge could give an indication of "burn time" at current rate of use ? It already has the information it needs to calculate this, and it may not require a hardware change, just a software upgrade. Like the car fuel gauge it won't be 100% accurate, but will help the non technical ( the target market for the device ), also, it may get more accurate as it "learns" your use profile ?
That way if someone is running their 4Mw hair dryer and see they only have 30 secs of battery left, they may switch it off ! Alarm levels could also be set.
You need to avoid making a lot more work for "the management" which never gets used ! There is already soooo much information within the site and it just keeps growing - does it get archived off eventually ? Also, there is already a FAQ section but human nature means it is easier for people to post a new item than trawl through pages and pages maybe never finding the answer they require. A common complaint is a lack of detail on posts, maybe some guidance on asking technical ( or just electrical ? ) questions could be provided with a simple checklist :-
Battery bank size and type
Inverter size and type
MPPT type
solar panel size and type
etc etc
This could save time.
Solar Panels, the understanding thereof.
in Boat Equipment
Why didn't it halve the current ?
Probably because the covered panel was draining some of it, assuming your panels do not have blocking diodes ? The working panel was probably producing half your measured current, some of which went to your controller, the remainder was back-fed through your covered panel. To measure one panel disconnect the other first.
As for % of max, we have had upto 90% on the right day, panels clean, properly tilted, batteries on bulk etc
