Skip to content
Anyone got a Dynostart wiring diagram?
Featured Replies
#26
Snibble.Just discovered this forum and have signed on some days ago. I do not know a whole lot about electric etc.
I have a Bosch Dynostart plus Bosh alternator on a Bukh 10 engine.
Alternator not working. I am interested in your sketch diagram and would be greatful if you can let me know the spec of the replacement reg and perhaps explain the additional link
Best regards
Tom
Sorry, eye off the ball, didn't see this thread re-emerge.
Local auto electrical dealer or branch of Lucas service. CARGO part number 130047. Important thing is that it's an 11A reg, more and you risk burning out the dynastart. The additional link is the interconnection of the separate solenoid and reg in order to give the regulator its battery +ve connection.
#27
Snibble,
I would very much appreciate the dynostart test procedure. I'm working through electrical issues (seriously considering a before and after photo series on hacked up 40 year old wiring) where the battery does not charge properly.
thanks,
Paul
Dynastart system tests.
Remove belt.
Connect bulb or voltmeter from D+ to earth.
Disconnect DF lead.
Operate start control, motor should spin and 12V appear on voltmeter (or bulb light). Lack of reading or lamp indicates supply fault, failure to spin when supply is present indicates motor fault.
With motor spinning, earth DF terminal. Motor should abruptly slow with momentary increase of voltage or bulb brightness. Failure of either indicates motor fault.
Reconnect DF at motor and re try both tests at the regulator end. (Lamp/meter on regulator D+ terminal and disconnecting regulator DF) Failure indicates wiring fault.
Common dynastart failure is in the field coils, there should be a resistance of 4-6 ohms between D+ and DF on the unit with wiring disconnected.
#28
Thanks for that. will let you know as I progress. many thanks
Tom
Recently Browsing 0
Account
Navigation
Search
Search
Chrome (Android)
  3. Adjust your preference.
Chrome (Desktop)
  2. Select Site settings.
