BCN Challenge 2019
Mrs Tawny Owl
15 minutes ago, cheshire~rose said:
And off we go - so far the companion set has fallen over and the cutlery drawers opened 3 times
is that sufficient scandal?
61272143_10157093739674070_7574107829301
Is there any water in the garrison pounds?
8 minutes ago, cheshire~rose said:
Mr Chairman - please help, I can't see how or where I record the bit of canal we are on!
eek
Open up the cruise log.
You'll see a list of canal sections.
Hint you started at Salford Junction.
Find that and put in your start time in the box.
Then the time you left the section in the end time box.
Salford Junction will be mentioned more than once as it is the end point of several sections so check when you get to the other end your on the correct section.
Ask your crew for the junction names they should know.
Good luck.
Good luck.
Nope :(
I can see Salford Junction mentioned 3 times - line 51, line 61 and line 63 but none of those correspond with our journey
Rob is saying it is on his version but Alan has looked and can't see it on mine
when folks aren't working locks we will check again
