Sign in to follow this
Bread
How to disconnect this light!!!
Hi guys,
Id like to disconnect this light, but when I disconnect it then all the lights on the boat don’t work. Granted I realise that it’s connected to the same circuit all the way around, but how do I disconnect it without disturbing the circuit?
Any ideas?
A simple solution without having to take feelings down etc would be appreciated.
I meant ceilings not feelings...not really concerned about my feelings at this point
Share this post
Are you having a laugh or is this a serious problem?
If disconnecting this one puts all the lights out, then your lights are wired in series not parallel,  Massively unlikely, they would all be very dim, or is it you?
Share this post
Sneak up on it in your slippers?
(this is a very suspicious query!)
Share this post
Its got to be a wind up surely?
Or do we have a MD asking silly questions?
Troll warning? There is no virus warning on the message that I can find.
Share this post
In some respects it's an interesting question.......looking at the whole picture it all looks a 'bodge up', doubtful fit out, wires in polystyrene, male and female connectors the wrong way round, don't disconnect it just rewire the whole lot. Would love to see some more pictures of the boat though.
Share this post
Oh no, it looks too frightening to get involved with. Haven't we had enough " battery"  "alternator"   " Fan belt"  " wiring"  agro recently?  Shed wiring?  It could be a caravan!
I went and opened the gates of Hades mentioning my DC plugs,
Don't mention the war, I did once but I think I got away with it.
Share this post
Is the boat 24v by any chance?
Is there just one other light that goes out when you disconnect this one?
My suspicion is that its 2x 12v bulbs in series on 24v circuit.
Share this post
Unfortunately this isn’t a wind up. I really am that dim. Thanks for the few guys that replied though. It isn’t a 24v set up. When I disconnect the wires from that lightbulb then the fuse goes and non of the lights work. Just wondered how to disconnect it safely and to ensure the fuse stops shutting off.
Thanks in advance
Share this post
Is this on a boat? Looking at the photo in your OP, those look like bricks in the bottom left corner.
Assuming that it is a boat, what voltage are the batteries? And if you take that light fitting apart, what voltage is the bulb inside, and does it glow brightly or dimly?
Share this post
Disconnect both wires. Insulate the ends of the wires with insulating tape. Do not connect the wires together, keep them separate.
Share this post
Yea this is on my boat. I'm assuming they're 12v, but then again, they are huge batteries so they might be 24V. I've only recently bought the boat, so naturally assumed they were 12V. I'll check when I get in mate. Would that make a huge difference in terms of the fuse popping out each time I disconnect them from the lightbulb?
Hi mate, I tried that and the fuse still pops out and no other lights work. Someone suggested putting the wires together but I can;t see that working out to brightly
Share this post
Mate? Mate!?   it is a wind up, sure now.  So, not the lights going out but the supply shutting down.
He's got conductive insulating tape. And a fuse that keeps going outside for a fag. Fuses don't "pop out" they blow, melt, FUSE!
Perchance its a circuit breaker? And you have to reset it?
You have to be shorting the wires out to something, like the steel hull.
Are there any bare patches on the wires where they disappear into the insulation and you are getting sparking- shorting to the steel?
Share this post
Or do we have an " ex MOD" asking silly questions?
I corrected your slip of the fat fingers Sam, as you know I've yet to find a buyer for my flat, one is coming to have a look this week, fingers crossed. If this were my boat I'd be stripping out and starting again. No I would'nt ever think I had a 24 volt system, maybe a photo of the batteries might help to educate me. :)
I only know enough about this boat's electrics to say, Cripes!
OP: buy this book, and read it. then read it again. :)
 https://www.amazon.co.uk/Boatowners-Mechanical-Electrical-Manual-4/dp/0071790330
Pat Manley wrote book on electrics only, Its cheaper, but I suggest you look t the kindle samples before committing.
There is a 12 volts fb page and 12v videos on you tube
Edited by LadyG
Share this post
Could be, anyone in particular?
Do you have any insider knowledge or form.?
Bread, joking apart you are worrying. How about the 12v Bible, free to read on the internet?
Share this post
I paid someone to sort my boat electrics, but then they had been done professionally in 1974, and never messed about with.
I had the 12volt bible, and it helped with technical choices, but not hands on stuff at my level.
the 12 volt website has all the proper kit for boats and offer advice, I can't recall the name of the company
UPDATE
https://www.12voltplanet.co.uk/electrical-circuit-basics.html
Edited by LadyG
Share this post
Looks to me as if there is an on/off switch at the bottom of the light unit. If so there is NO difference between switching off the light and disconnecting the wires.
Share this post
Can someone please explain how taking something out of a circuit and leaving the connections to it insulated (from one another or anything else) can blow the supply fuse, because I've a got a hat that needs eating...
Share this post
These were my suggestions, but I still think its a wind up. A short to the hull on the wiring when disturbed is the only sane answer. I bet it never comes back now "Matey" has had his fun.
Share this post
So with the light connected all the other lights work and the lighting fuse / trip holds in.
if you disconnect the wires the fuse / trip blows. ( which kills the lights)
if its in series disconnecting it should kill everything but not the fuse
if its in parallel then removing it shouldnt stop anything else working, nor blow the fuse
logical deduction  suggests that disconnecting the light is overloading the fuse.
is the wiring  to that light by passing the fuse box and therefore creating a ‘big fuse’
i remember a similar situation where a friend wired in a cb radio straight to the battery terminals on the positive and to a handy negative bus bar. The day he tried to start thr engine having forgotton to turn on the battery master switch was memorable as he had also omitted  a fuse. Luckily there was a fire extinguisher handy.
Share this post
Roland, that sounds plausible. I think disconnecting the light is overloading the fuse. Will I simply have to disconnect that wiring from the fuse box then?
Share this post
If the current wiring is supporting the load on the rest of the system, and you remove it, then the fuse will continue to blow.
1) is it a fuse or a trip
2) if a fuse whats it rated at, and whats the  total load on the lighting system
3 what happens if you take the bulb out leaving the wiring intact, and does the light work.
i ask this because taking bulb out = breaking circuit.
if the hypothesis has any veracity at all
It means you have a major wiring issue.
And the light case may be making the circuit
Share this post
