blackrose
Cav/Delphi 296
This is what my BSS examiner has said in a text: "Hi Mike. Glass bowls are not allowed under the BSS as they are not classed as fire resistant. Hope this helps."
Share this post
Thanks for the update :)
So now we know for sure.
Share this post
7 minutes ago, blackrose said:
Well that's his interpretation of the regs anyway.
But like Alan’s experience, his is the only opinion that matters...
Share this post
Assuming I have the same examiner next time. I've had 4 different BSS examiners since I've been on this boat and another one on a previous boat.
Share this post
3 minutes ago, WotEver said:
I think he’s unlikely to get involved. He didn’t over Alan’s RCD fiasco.
Reply from Rob :
The other ways of providing 2.5 minutes fire protection for filters in an engine space include:
Some manufacturers offer clear bowls that are intrinsically fire resistant for 2.5 minutes,they may be marked as meeting ISO 10088, or provide documents stating the same.
Some manufacturers offer OEM steel 'dog bowl' flame shields that attach underneath the filter. The makers have had these independently tested to certify that they meet ISO 10088 standards.
HTH
Rob
So a non-metallic filter bowl can be used if the manufacturers documents claim BSS compliant,  'fire protection for 2 minutes' or the filter is marked as ISO 10088 compliant.
Share this post
Unhelpfully the one that I linked to on Bay states “ISO/TS Certified” but doesn’t mention ‘which’ ISO.
Share this post
Could be approved by the Independent Sausage Organisation ?
Share this post
And Tango Shorts...
Share this post
From the BSS notes to examiners :
A number of boat owners have contacted the BSS Office asking if the Fuel Guard water separator and fuel filter Type FGD conforms to the requirements of the BSS if installed in the engine bay of either a diesel or petrol fuelled engine.
Description / scenario
The BSS Office has been in contact with the UK suppliers of this device who has provided a copy off a Declaration of Conformity. This declaration indicates that the filter meets the relevant requirements of standards ISO 7840-2004 and ISO 10088-2009.
The BSS Office has reviewed this declaration and it indicates that the Fuel - Guard products listed below meet the requirements of BSS Check 2.12.2 [2013] and C2.16 [2002] Are all fuel filters inside engine spaces fire resistant?
The declaration reviewed covers the following devices,
Fuel filters / water separators
Type: DCI Certificate number: CE-RCD- ı395
Model types:
FUEL-GUARD FGDI00,
FUEL-GUARD FGD230,
FUEL-GUARD FGD560
FUEL-GUARD FGD1120,
FUEL-GUARD FGD 1680,
FUEL-GUARD FGD2240
Implications for BSS examinations
Examiners finding such devices installed within the engine space should establish that the label on the top of the device has model numbers as listed above and apply the appropriate checks as normal.
NP14-02 Fuel-Guard fuel filters
Share this post
Some manufacturers offer clear bowls that are intrinsically fire resistant for 2.5 minutes, they may be marked as meeting ISO 10088, or provide documents stating the same.
Fuel filter with a "Dog Bowl Fire Shield"
Image result for fuel filter flame guards
Edited by Alan de Enfield
Share this post
The 296 complete filter units are mostly available without a glass bowl. These are on a great many boats and some older vehicles still.
Share this post
Ok I won't get a Cav/Delphi with a glass bowl and that Fuel Guard unit is silly money (£170 😮), so I'll just get a CAV/Delphi with a steel bowl.
Thanks all
Share this post
Thanks all
Makes sense :)
Share this post
9 minutes ago, WotEver said:
Makes sense :)
Can't get rid of that emoji?
Anyway, possibly my BSS examiner hasn't seen those Fuel Guard filters or doesn't realise they're compliant.
Edited by blackrose
Share this post
Does anybody know how easily the fuel flows through the 296 filter? The lift pump of the engine sucks it through with no problems, but gravity alone doesn't seem to be enough because after I've changed the filter during a service I can't get the fuel to flow and fill the filter except by starting the engine. This of course makes it impossible to bleed the air out which makes it hard to get the engine running properly again. Is this normal or should I be looking for a blockage? Once it's all clear of air I have no problems. The surface of the fuel will typically be 1ft to 2ft above the filter.
Share this post
Never experienced lack of flow by gravity through 296, I would suspect that it is an air lock that is preventing flow.
It will bleed by loosening the outlet union or the bleed nipple on the top if so fitted and pumping fuel either by hand if there is a hand lever on the pump or by running/cranking the engine.
Share this post
I presume you have a dip tube in the tank, up which the fuel would has to first syphon, it then doesn't have the head weight of the fuel in the tank behind it for a strong flow down to the filter, unlike direct gravity flow from a take off at the bottom of the tank.
Edited by bizzard
Share this post
No, the filter is before the pump; opening the bleed nipple has no effect (after half an hour it is still dry) but starting the engine or hand-priming would simply draw in air through the bleed hole. Loosening the outlet union would have the same effect.
Share this post
Indeed. It is entirely inside the tank, so it emerges from the bottom after it has risen up and come down again. There is of course a tap at that point, which I turn off during the servicing, maybe next time I need to see what happens if I turn it back on without the filter element in place - apart from diesel probably spraying all over me that is. One problem is that all the pipe unions were sealed with a sealant/adhesive a few years ago so I can't loosen them.
Share this post
