Jennifer McM
Rudely woken by the CO Alarm
10 minutes ago, BWM said:
CO being heavier than air will move downhill and begin to collect at the lowest point.
Well the density of air at sea level is given as 1.225kg/m3 and Carbon Monoxide is 1.14 kg/m3
Share this post
Have i got that the wrong way round? I know one suggestion is to mount them at head height (sleeping), and perhaps wrongly assumed that it collected at low levels..
Most happy to be corrected.
Share this post
It could take some shifting if its set like solid cement. An ordinary bristle brush won't do much  If its a straight fluepipe you could like I had to do last January was to flatten the end of a length of 3/4'' steel water barrel pipe and drill through it from the top by turning it with Stilsons, once it broke through it mostly all broke away in big chunks into the stove.
Once its broken through bend the flattened end of the pipe a little and keep running it up and down the fluepipe to clear the rest. Keep the stove door closed whilst doing it.
Edited by bizzard
Share this post
It is CO2 that is heavier than air. CO and CO2 get confused a lot, by me too sometimes. As @ditchcrawler says CO is lighter than air and will pool close to the ceiling, which is why the alarm destruction manuals say to put it near there.
Jen
Edited by Jen-in-Wellies
Share this post
21 minutes ago, bizzard said:
Looks like you've been bunging on wet or damp coal-smokeless fuel. The moisture mixes with the binding material and turns into a cementhard like stuff instead of just loose soot. If you keep  the stove burning bright and hot it wouldn't matter, but I daresay, like most folk it just ticks over gently most of the time especially at night which can cause it.  When smokeless fuel is perfectly dry it is a sort of dark grey colour.  If it looks jet black its wet or damp.
Exactly that. Nearly all the bags (kept in the cratch, under a cratch cover) when first opened the top layers of coal are sodden wet, I thought it was condensation. We burn a coal scuttle full of coal a day, scuttle is filled in the morning, and kept by the fire. The coal nuts become dryer, but still not fully dry.
Share this post
I watched a chap sweeping his chimney while the fire was alight. He stood on the roof, dipped the brush in the water and rammed it down the chimney, he did have the boat door open at the time. That way he could do it every week.
Share this post
Yes I think it did, there was big bottle brush, a hook to scratch the stuff, and a chain that beat the inner sides of the flue involved. That's a good idea about the water barrel, I'll pass that on to 'him that does'.
Share this post
Probably bagged wet. Merchants store it in bulk, loose in open to the weather staithes.
Share this post
Interesting idea, but not sure how he'd get the stuff off the baffle top without putting the fire out. Maybe we've got a different type?
I took this picture before the inside of the fire was dismantled. We've had problems in the past figuring out which way the baffle fits. 🙄😄
Share this post
It helps if the fuel is not perfectly dry when fed onto the fire is to twice a week get the stove roaring really tremendousely hot for half an hour which should burn off most of the gunge and soot in the flue.  I believe Morso recomend this performance.
Edited by bizzard
Share this post
This could explain why I only get 2-3mm of deposit in a year.
My modus operandi twice a day is to burn the fire up, empty the ash, rake out the stove leaving only red embers, fill to the max and burn up again, C says to much, then shut it down for 12hours. Its worked for me for years on a few different types of stoves both in the boat and the cottage. I never put fuel on without giving it a good burn.
Share this post
Agree with all this. Running these stoves hard, with dry fuel is the way to keep the flue free of clag. I've just used an old bit of scaffold pole to knock out the concrete like stuff that has formed with the weather being so mild and the stove ticking over 24/7.
Jen
Share this post
I do mine when the fires low after I get back from work, use a welders glove to lift the baffle plate up to shake clean, quick and easy done about once a month
Share this post
Welder's gloves now on the shopping list! 👍
Edited by Jennifer McM
Share this post
You will look very stylish, the talk of all your friends. Do you want a welding mask too?
Share this post
On 08/01/2019 at 11:17, Boater Sam said:
"H" top stops downdraughts but looks daft.
Spinning pigeon on top stops spinning after a while then its worse than nothing.
I've posted praise for H cowl before, no ingress of rain, not effected by down draught and unaffected by wind causing fire to overdrawn
H cowl very common on fishing vessels and they have plenty of wind to cope with
Phil
Share this post
Oh they're not for me 😂
Share this post
