Machpoint005 Posted January 2, 2019 Report Share Posted January 2, 2019 12 hours ago, howardang said: may also go some way to partly explain why a vessel - ship or boat - handles differently when going astern - a subject which is sometimes spoken about as the devils work When going astern, a boat is mainly acting according to its own momentum, and the only way of changing direction is to change its alignment ( the direction in which it is pointing). Sometimes the rotation of the propeller is enough to do this, and sometimes it isn't. Wind and bursts of sideways-directed thrust (gears ahead!) are other ways of changing this alignment. Link to comment Share on other sites More sharing options...
Jess-- Posted January 2, 2019 Report Share Posted January 2, 2019 the best advice I have come across for new boaters (or experienced boaters with an unfamiliar boat) is to get the boat onto a quiet stretch and play with it. You'll learn a lot more about how the boat reacts from that than you'll learn from books or reading on here, you simply can't beat experience. That said... how well the boat handles drops dramatically with people watching. 1 Link to comment Share on other sites More sharing options...
Scholar Gypsy Posted January 2, 2019 Report Share Posted January 2, 2019 On stability, as noted above you want the centre of gravity below the centre of buoyancy. The other quite strong effect on a narrowboat is that when it rolls the centre of buoyancy moves sideways - to the right with a right hand roll - and this also helps the boat right itself. This is very different to say a sailing yacht where the cross section in the water is (very approximately) a cylinder, and so a heavy keel is needed to provide the necessary forces/couples to stop the boat turning turtle. Link to comment Share on other sites More sharing options...
Jennifer McM Posted January 2, 2019 Report Share Posted January 2, 2019 5 hours ago, nicknorman said: Well that is where experience comes in. Knowing whether adding plenty of power is going to fix the problem or make it worse! I got through the problem with feet to spare, so I must have 'called it right'. When the wind is involved it's 'interesting'. Link to comment Share on other sites More sharing options...
bizzard Posted January 2, 2019 Report Share Posted January 2, 2019 A good dose of Gripe water is the stuff for good winding. Link to comment Share on other sites More sharing options...
Richard10002 Posted January 2, 2019 Report Share Posted January 2, 2019 8 hours ago, Machpoint005 said: When going astern, a boat is mainly acting according to its own momentum, and the only way of changing direction is to change its alignment ( the direction in which it is pointing). Sometimes the rotation of the propeller is enough to do this, and sometimes it isn't. Wind and bursts of sideways-directed thrust (gears ahead!) are other ways of changing this alignment. I find the tiller quite effective when going astern. As you say, prop walk and wash are also helpful, but I find wind is usually a hindrance, rather than a help. Link to comment Share on other sites More sharing options...
Flyboy Posted January 2, 2019 Report Share Posted January 2, 2019 10 hours ago, nicknorman said: I think the clue to the problem with that event is in “the boat gently leaves”. So many people come out of locks on tickover doing 1 mph or less, then wonder why their boat gets affected excessively by modest wind and slight currents. If in doubt, come out with plenty of power on and then you are out of the lock and can steer properly, before the wind and current have time to do anything much. It is the same when entering a lock. There seems to be a choice between creeping in sufficiently slowly that when you miss the aperture by a foot, the inevitable collision (due to lack of steering authority) isn’t too severe. You even see people hitting reverse when the 1mph they are doing feels too fast for them. Inevitably, they then bash the lock entrance. Or coming in with plenty of power on and hence plenty of steering authority, and just slide straight in. We always do the latter but it is amazing how many people think that doing the former and hitting the lock wall is normal. I totally agree, with plenty of power on the wash around the bow tends to self centre the boat, particularly in narrow locks. The same applies in tunnels where normal speed keeps the boat centred. Following a slow boat through a tunnel is interesting as they zigzag, bouncing off the sides. Link to comment Share on other sites More sharing options...
Clodi Posted January 20, 2019 Report Share Posted January 20, 2019 On 01/01/2019 at 20:08, Tonka said: If you read "Boater's Guide to Boating" by "Christopher Norton Deuchar" you will learn that the turning point of a narrow boat moves and it explains why it moves. Well worth a read for even the most experienced skipper Thank You for recommending this super little book. I've grown-up with boats all my life & can honestly say this book is one the best, easiest to understand, books on the subject I've read. Just gotto persuade my wife to read it now ? Link to comment Share on other sites More sharing options...
ditchcrawler Posted January 20, 2019 Report Share Posted January 20, 2019 1 hour ago, Clodi said: Thank You for recommending this super little book. I've grown-up with boats all my life & can honestly say this book is one the best, easiest to understand, books on the subject I've read. Just gotto persuade my wife to read it now ? It is good isn't it, I really should read it again Link to comment Share on other sites More sharing options...
Dawnrazor Posted February 10, 2019 Report Share Posted February 10, 2019 From my few months experience on a 60 x 12.6ft wide beam. Which dips at the back, part of design. It steers from the center very smoothly, you do have to factor for winds. But if you're going slowly you have time to judge you're movement and should not have much trouble. I will take it extremely slowly when I moor up on my new linear home mooring end of the Month. As Boat in front as tight space to plonk it in. I find it relaxing moving the beast about, Link to comment Share on other sites More sharing options...
Dharl Posted March 13, 2019 Report Share Posted March 13, 2019 On 01/01/2019 at 20:08, Tonka said: If you read "Boater's Guide to Boating" by "Christopher Norton Deuchar" you will learn that the turning point of a narrow boat moves and it explains why it moves. Well worth a read for even the most experienced skipper Anouther vote for this book! When I first moved from blue water to the cut I got a copy of this and it was very useful indeed, full of useful tricks of the trade as well as a good yarn. In fact just ordered a new copy as I can’t find my original version! Link to comment Share on other sites More sharing options...
ditchcrawler Posted March 13, 2019 Report Share Posted March 13, 2019 58 minutes ago, Dharl said: Anouther vote for this book! When I first moved from blue water to the cut I got a copy of this and it was very useful indeed, full of useful tricks of the trade as well as a good yarn. In fact just ordered a new copy as I can’t find my original version! A very good book for someone with more than 18 months experience of boating unlike a lot you find on the net Link to comment Share on other sites More sharing options...
