bigcol
Copper piping turned silver
As heading
smelt a gas smell like sewer gas in wheel house, couldn’t make it out.
went into engine room, and all the copper piping overnight certainly over 2 days
all copper pipes are now silver as if I sprayed them silver
any ideals please, batteries are all under 6 months old
please let us know
Share this post
Quiet possibly one cell shorting and making the gas that turns copper silver.
My advice would be to feel ll the batteries when they have been on charge for a while to see if one or part of one is getting warm. If open cells the check for gassing and loss of water. Even better do a hydrometer check if you have the kit.If that is not possible disconnect all the interlinks and measure the voltage of each bate try, all should be abut the same but the start battery is allowed to be better charged. If any are low then that is the suspect one.  Otherwise isolate one and check its voltage, leave overnight and recheck. If its dropped then it is likely to be the culprit. If not repeat n the next one.
Edited to add  =- What's the charging voltage, charging at excess voltage might cause this.
Edited by Tony Brooks
Share this post
The electrolyte in a shorting cell often goes dark or black.  You might see it with a hydrometer check.
Edited by bizzard
Share this post
Thankyou will test today,
‘I have got a video but won’t let me download
but have you heard of this before?
big engine bilge, battery’s in a proper box
pity I couldn’t email the video
thankyou for the info
col
Share this post
The problem is the batteries are 'gassing' excessively, the silver pipes will soon turn black. On a positive note, you will have no problems with spiders for a year or so.
Share this post
Thankyou bizzard, haven’t got a hydrometer tho, will have a look visually see if anything is plainly obvios
Share this post
If your smell is of rotten eggs, then it sounds like you are gassing off hydrogen sulphide from a battery which is then reacting with the copper to give copper sulphide.
Note the hydrogen sulphide is significantly toxic and will accumulate at low levels due to density. I suggest you ventilate well and consult information on this gas, e.g. the wikipedia entry. Be careful!
Share this post
I’ve checked all 4 battery’s 2 are showing black
and two are showing green
so this means 2 battery’s are knackered, or should be sent back to where I got them ??
The other 2 battery’s showing black
These are the two showing black
Edited by bigcol
Changed photos
Share this post
Okay, I know this sounds stupid, but should I now disconnect the 2 battery’s.?
i bought these from batterystore and come with 4 years warrentee.
has anyone had dealings with this company
all four bought November 2017
col
Yes. Rotten eggs you are right
Share this post
I would disconnect all the batteries so that are separate and measure the voltage on each one, looking for abnormally low readings.
Are they sealed batteries? If not look for abnormally low water levels in the cells.
Then reconnect the good batteries and check the charging voltage to make sure you do not have a duff charger (voltage too high).
Edited by jonesthenuke
More text
Share this post
col
I doubt you will have any success in 'sending them back' unless it is a manufacturing fault.
It sounds as if it is more likely to be 'overcharging' and 'boiling' the acid - how are you charging them ?
Check the charging voltage of whatever it is you are using.
I had a battery charger that decided to just 'keep-going', fortunately I noticed and switched it off at over 16 volts (12 volt system)
Share this post
Those tell tale windows on batteries mean very little.
Disconnect all the batteries and check each one in isolation with a volt meter and post the results.
Share this post
Hi their sealed, but 2 are green and 2 are black meaning faulty, so should I disconnect the dead ones ie black ?
Share this post
Don't replace them with 'sealed batteries' with the 'magic eye' (green ball) it just tells lies and makes you kill your batteries in a matter of weeks.
Edited by Alan de Enfield
Share this post
21 minutes ago, Alan de Enfield said:
If you have them - run the bilge blowers for half an hour
But if he has just disconnected all his batteries to see which ons(s) are low voltage ........................
Share this post
I had a similar problem a few years ago. Turned out that the control circuit in the alternator had failed, causing it to generate well over 16V. This was cooking the batteries.
We noticed first when our gas alarms started going off when the batteries had been charging for a fair time. I investigated & found the high voltage.
A new alternator cured it, though I was later able to get the old one fixed cheaply, and now keep it as a spare
Share this post
Okay I’ve tested  battery’s
1 black light measures 10.9 v
2 green 12.9
1 black 12.9
all was disconnected and tested
I’m running off 2 batteries now as 24v system
ive taken the 10.9 battery away
but trying to add the 3rd battery to bank, although blk it shows 12.9 volt
Share this post
Ref the green so called "magic eye" All it consists of is a cage to contain a plastic ball a charged battery has denser fluid so the ball will float high, if charge is low the ball is floating in a less dense liquid and will float lower.
Also if the fluid in the battery is depleted irrespective of the level of charge it will be insufficiently high enough to raise the ball in its cage.
So the 3rd battery at 12.9v may only need topping up.
Phil
Share this post
2 green 12.9
1 black 12.9
The 10.9 one is faulty, my guess is the other 3 are OK but the "green eye" is only a crude hydrometer and they show black because:
1. they are stuck
2. that cell is discharged
3. that cell is low on electrolyte.
A back indication does not necessarily mean the battery is faulty.
Get the 10.9 one out of circuit and put the other three back. Start charging keep and eye, hand  and nose on the black one. If it starts to smell, get hot etc, get that one out of circuit.
Oh, I am with Alan,  don't replace with sealed.
Depending upon how dry the cells are in the faulty batteries you may soon be in battery explosion territory so take care.
Share this post
Col has a 24v system.
Just now, Phil Ambrose said:
Alan you know as well as anybody , there are sealed batteries and there are sealed batteries.
Phil
Indeed, and, a 1/2" drill and half-a-dozen corks soon converts them.
Share this post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
