Antony Posted December 28, 2018 Report Share Posted December 28, 2018 Can someone please tell me what the speed limit is on rivers and canals,and is it the same on both ? thank you Link to comment Share on other sites More sharing options...
ditchcrawler Posted December 28, 2018 Report Share Posted December 28, 2018 6 minutes ago, Antony said: Can someone please tell me what the speed limit is on rivers and canals,and is it the same on both ? thank you Most canals are 4 MPH or a wash which ever is the slower, Rivers can all be different and you need to check local information. Link to comment Share on other sites More sharing options...
GUMPY Posted December 28, 2018 Report Share Posted December 28, 2018 No For starters from memory Canals 4mph R.Thames 8kph R.Nene 7mph R.Gt Ouse 4mph/7mph depending on where you are R.Avon 4mph upstream 6mph downstream Link to comment Share on other sites More sharing options...
Antony Posted December 28, 2018 Author Report Share Posted December 28, 2018 Thank you ditchcrawler Thanks Loddon,I will try and find out what the river Brayford is ? Link to comment Share on other sites More sharing options...
Momac Posted December 28, 2018 Report Share Posted December 28, 2018 3 hours ago, Antony said: Thank you ditchcrawler Thanks Loddon,I will try and find out what the river Brayford is ? I think you mean Brayford Pool in Lincoln - which should be slow as its is mostly occupied by moored boats - certainly not more than 4mph. The Fossdyke Navigation , Lincoln to Torksey , is a canal therefore 4mph Link to comment Share on other sites More sharing options...
Antony Posted December 28, 2018 Author Report Share Posted December 28, 2018 Thank you MartyneG. Yes it’s the Fossdyke I will be using the most. kind regards Antony Link to comment Share on other sites More sharing options...
carlt Posted December 28, 2018 Report Share Posted December 28, 2018 36 minutes ago, MartynG said: I think you mean Brayford Pool in Lincoln - which should be slow as its is mostly occupied by moored boats - certainly not more than 4mph. With one notable exception. 1 2 Link to comment Share on other sites More sharing options...
TheBiscuits Posted December 28, 2018 Report Share Posted December 28, 2018 1 hour ago, carlt said: With one notable exception. The Guy Martin pedalo world record attempt? Link to comment Share on other sites More sharing options...
David Mack Posted December 29, 2018 Report Share Posted December 29, 2018 10 minutes ago, TheBiscuits said: The Guy Martin pedalo world record attempt? Closer to home... 2 Link to comment Share on other sites More sharing options...
aracer Posted December 29, 2018 Report Share Posted December 29, 2018 On 28/12/2018 at 18:06, Loddon said: No For starters from memory Canals 4mph R.Thames 8kph R.Nene 7mph R.Gt Ouse 4mph/7mph depending on where you are R.Avon 4mph upstream 6mph downstream Interesting - so does the Severn have the highest speed limits (6mph upstream, 8mph downstream)? Link to comment Share on other sites More sharing options...
Liam Posted December 29, 2018 Report Share Posted December 29, 2018 20 hours ago, carlt said: With one notable exception. You have just jogged my memory enough for the old grey matter to catch up. I remember now Link to comment Share on other sites More sharing options...
Antony Posted December 29, 2018 Author Report Share Posted December 29, 2018 I have just tried to find it on YouTube but can’t find it ? Link to comment Share on other sites More sharing options...
Alan de Enfield Posted December 29, 2018 Report Share Posted December 29, 2018 17 minutes ago, aracer said: Interesting - so does the Severn have the highest speed limits (6mph upstream, 8mph downstream)? The same as the Trent 1 Link to comment Share on other sites More sharing options...
ditchcrawler Posted December 29, 2018 Report Share Posted December 29, 2018 The Mont is only 2MPH Link to comment Share on other sites More sharing options...
Jennifer McM Posted December 29, 2018 Report Share Posted December 29, 2018 On 28/12/2018 at 17:57, Antony said: Can someone please tell me what the speed limit is on rivers and canals,and is it the same on both ? thank you Sorry for being stuffy, but shouldn't the speed be more about the wash you're leaving behind, so your boat doesn't disturb habitats and the bank 1 Link to comment Share on other sites More sharing options...
Antony Posted December 29, 2018 Author Report Share Posted December 29, 2018 26 minutes ago, Jennifer McM said: Sorry for being stuffy, but shouldn't the speed be more about the wash you're leaving behind, so your boat doesn't disturb habitats and the bank There should be no chance of anything like that from my boat as I only have a small electric motor and a pair of oars ? Link to comment Share on other sites More sharing options...
Detling Posted December 29, 2018 Report Share Posted December 29, 2018 interestingly the Thames speed limit is speed over the ground not through the water so tickover downstream can be mighty close to speeding and flat out upstream you can be well under the speed limit. Link to comment Share on other sites More sharing options...
Phil Ambrose Posted December 29, 2018 Report Share Posted December 29, 2018 11 minutes ago, Detling said: interestingly the Thames speed limit is speed over the ground not through the water so tickover downstream can be mighty close to speeding and flat out upstream you can be well under the speed limit. Speed over ground is almost universal, not sure how you would measure speed through water. ( I know how it's done) For boaters convenience the Broads Authority have 1/4 mile posts to time yourself, likewise on the River Great Ouse. Phil Link to comment Share on other sites More sharing options...
furnessvale Posted December 29, 2018 Report Share Posted December 29, 2018 1 hour ago, Jennifer McM said: Sorry for being stuffy, but shouldn't the speed be more about the wash you're leaving behind, so your boat doesn't disturb habitats and the bank Exactly! 4mph is too fast for many situations and unnecessarily restrictive in others. Given I don't even have a speedo fitted, I pay attention to my wash relative to the condition of the canal, moored boats etc not some imaginary speed limit. George 2 Link to comment Share on other sites More sharing options...
aracer Posted December 29, 2018 Report Share Posted December 29, 2018 1 hour ago, Jennifer McM said: Sorry for being stuffy, but shouldn't the speed be more about the wash you're leaving behind, so your boat doesn't disturb habitats and the bank Maybe - and that determines my maximum speed on canals, which is nowhere near 4mph, but on the Severn it would be easy to break the speed limit without producing a huge wash (depending on the boat - I break the speed limit all the time in a kayak*, but don't produce any significant wash - some big boats however are already producing lots of wash at those speeds, hence they're not necessarily nominal). * before anybody complains the speed limits only apply to powered boats Link to comment Share on other sites More sharing options...
Jennifer McM Posted December 29, 2018 Report Share Posted December 29, 2018 10 minutes ago, aracer said: Maybe - and that determines my maximum speed on canals, which is nowhere near 4mph, but on the Severn it would be easy to break the speed limit without producing a huge wash (depending on the boat - I break the speed limit all the time in a kayak*, but don't produce any significant wash - some big boats however are already producing lots of wash at those speeds, hence they're not necessarily nominal). * before anybody complains the speed limits only apply to powered boats Yes, in the summer when we were on the Nene, there were times in deep water where we felt we were travelling fast, but the reeds hardly moved. Link to comment Share on other sites More sharing options...
Chewbacka Posted December 29, 2018 Report Share Posted December 29, 2018 33 minutes ago, aracer said: Maybe - and that determines my maximum speed on canals, which is nowhere near 4mph, but on the Severn it would be easy to break the speed limit without producing a huge wash (depending on the boat - I break the speed limit all the time in a kayak*, but don't produce any significant wash - some big boats however are already producing lots of wash at those speeds, hence they're not necessarily nominal). * before anybody complains the speed limits only apply to powered boats Upstream against normal flow I can only dream of achieving the speed limit in our narrowboat. Link to comment Share on other sites More sharing options...
Naughty Cal Posted December 30, 2018 Report Share Posted December 30, 2018 (edited) On 28/12/2018 at 21:17, MartynG said: I think you mean Brayford Pool in Lincoln - which should be slow as its is mostly occupied by moored boats - certainly not more than 4mph. The Fossdyke Navigation , Lincoln to Torksey , is a canal therefore 4mph Through Lincoln it is 3mph. ETA: on the Witham the limit is 6mph. Many of the boats on the Fossditch can't even do 3mph in tick over. Ours can just. Some are looking at at least 4mph in tick over so be prepared that not all boats will be travelling as slowly as you would expect. Edited December 30, 2018 by Naughty Cal Link to comment Share on other sites More sharing options...
frangar Posted December 30, 2018 Report Share Posted December 30, 2018 37 minutes ago, Naughty Cal said: Through Lincoln it is 3mph. ETA: on the Witham the limit is 6mph. Many of the boats on the Fossditch can't even do 3mph in tick over. Ours can just. Some are looking at at least 4mph in tick over so be prepared that not all boats will be travelling as slowly as you would expect. And Brayford Pool? Maybe your boat isn’t suitable for the waterway then..... Link to comment Share on other sites More sharing options...
Naughty Cal Posted December 30, 2018 Report Share Posted December 30, 2018 1 hour ago, frangar said: And Brayford Pool? Maybe your boat isn’t suitable for the waterway then..... 3mph. It is suitable for the waterway. It can do the speed limit, just. Perhaps your boat isn't suitable for the rivers as it can't do the speed limit? Link to comment Share on other sites More sharing options...
