Sign in to follow this
Greyladyx
EBERSPACHER D4WSC FUEL FILTER
Hi, can someone tell me if their is a fuel filter built into an Eberspacher D4WSC and if so where is it please ?
I've downloaded the manual but it did not show anything about fuel filters.
Thanks.
Share this post
Thanks.
Dont think so. Webasto is a seperate unit and iirc the eber is also.
Share this post
Owe that's why I can't find one.
Thanks
1 minute ago, matty40s said:
....and most people who know them recommend installing the buggers without a filter anyway.
Cheers Matty.
Share this post
24 minutes ago, Tonka said:
Item 63 is the filter
D5W Parts FR,EN(3).pdf
That's a D5wsc thimble filter that's what got me confused I was looking at the fuel pump regulator thinking it was in their.
Thanks for your post hopefully it will help others with a D5 model.
Share this post
My heater a D4SWC has a filter insert inside the pipe union fitting where it goes onto the fuel pump under the top cover.
Share this post
On a d4wsc or d5wsc the fuel metering pump is inside the heater unit . On other models is it external to the heater . The filter is a pain to get at ( i did mine yesterday ) . You have to loosen a 17 mm brass nut which connects the copper fuel pipe to the metering pump . Removing the tiny filter can be fiddly . It can be done without removing the heater from its mounting bracket but i find it easier to dismount it and work on a bench whilst servicing the eber .
If you search for a website " le tonkinois varnish " theres a section on ebers . Click on " hydronic " and it shows the location of the filter & how to remove it .
Hope that helps
cheers
Share this post
https://www.letonkinoisvarnish.co.uk/eberspacher_intro_1.html
Share this post
