Felshampo
Chimney length
What are the pros and cons for the length of a chimney on the stove in the boatmans cabin. I have a 28 inch one which works well on the stove in the saloon. I was thinking of buying a second one for the stove at the back. This would be used when we have visitors using the bed in the boatmans cabin and when cruising. Most boats seem to use long chimneys. What about the short ones (12") are they OK?
Share this post
We have a stove at front and back.The one at the back has a shorter flue pipe than the one at front, and a shorter chimney too.It doesn't seem to make much difference to stove performance.
We did go for a couple of years with no chimney at all, which again didn't seem to effect the stove performance, but obviously didn't aid with smoke removal as well as having a chimney.
Share this post
Do you cruise with the fire going. Does it matter having a shorter chimney with smoke and the steerer?
Share this post
Longer ones - Pros: aesthetically pleasing (IMO); smoke from fire not in your face.
                        Con: you  have to take long ones off at some low bridges
Frankly, it doesn't matter which you chose.  After all, the  main purpose of a chimney is to warm the steerer's hands 😀- therefore don't have a liner, just a baked bean tin in the top.
Edited by koukouvagia
Share this post
We generally only light the one at the back when its very cold at night, so no.
Share this post
It doesn't matter to me if you have a short chimney and spend hours inhaling all the 'smoke nasties', but it may matter to 'you and yours'
Share this post
To stop smoke curling down into one of the mushroom vents and registering on the CO alarm we replaced our short chimney with a double skinned 30" job, it cured the prob and the draw on our Villager Puffin was significantly better.
Share this post
If wishing the authentic trad look, not a beanz tin unless desperate.  It should be a National Dried Milk tin.
And in either type don't forget to remove the bottom of the tin😇
N
Share this post
Yes.  In cold weather you stand on the back cabin step and the warmth from the fire is lovely and toasty.
Share this post
N
That reminds me... when you took your cod liver oil capsule and accidentally bit it open...
Share this post
Not tried it yet but have wished I had on more than one occasion!
Share this post
N
Agreed.  I've just looked on ebay and seen that a genuine one costs a fortune.  I'll stick with the baked bean tin :)
eta: Ah, you can type faste than me - your picture shows the one I was looking at!
Share this post
N
It's possible to have them over-plated apparently!
Share this post
In the same category as "Don't forget to remove the cap on the engine room exhaust before starting the engine!
Share this post
N
You're going back a lot of years with National Dried Milk! Do you remember the Romans leaving Britain too?
Regarding chimneys,I have found the double skin better,in that the tar trickles back down.
With a single skin,tar starts running down the cabin side and as well as looking unsightly,it is difficult to clean off.
Share this post
Can you still use it as a hand warmer ?
Share this post
Yes, it still gets warm,but I can't on my tub because the stove is halfway along the boat. It would involve leaving the tiller unattended [I always sail alone,nobody is daft enough to come with me] and scuttling along the gunwale and back!
Not recommended!
Share this post
Long enough to keep the smoke out of your eyes when stood on the foot board or the regulation baby milk tin extension always used "ostamilk" brand
Share this post
Not recommended!
No!
Share this post
That's why you need a baked bean/dried milk tin.
Share this post
Different ball game they are in most cases self removing & usually end up in the cut
Edited by X Alan W
Share this post
Whilst we're on the subject, found this on the new boat in the back cabin. Being the only one, presumably it's for the premier range. It has a lid but no means of holding the lid open. Just a split pin through the hinge that I'll need to remove. Have googled but not found this.
Share this post
