blackrose Posted December 2, 2018 Author Report Share Posted December 2, 2018 Ok here are some more pictures. It's a VDO unit. 14 minutes ago, Flyboy said: Some VDO Tachos have the adjustment hole in the side of the case. Nothing in the side of the case Link to comment Share on other sites More sharing options...
blackrose Posted December 2, 2018 Author Report Share Posted December 2, 2018 (edited) The only thing it could possibly be perhaps is the hole at the top (bottom) marked 3 with the yellow thing inside. The previous pictures show it better. But I don't think there's anything in there that turns, unless it's something you push as Tony suggested? Edited December 2, 2018 by blackrose Link to comment Share on other sites More sharing options...
croftie Posted December 2, 2018 Report Share Posted December 2, 2018 Could this be the one https://www.vdo-instruments.com/media/instructions/0 515 012 020 -- Tachometer without Engine Hour Meter.pdf Link to comment Share on other sites More sharing options...
Tom and Bex Posted December 2, 2018 Report Share Posted December 2, 2018 Some VDO tacos have to be calibrated with a cable and dedicated software. Possibly plugs into socket marked 123? Link to comment Share on other sites More sharing options...
blackrose Posted December 2, 2018 Author Report Share Posted December 2, 2018 (edited) Thanks for the instructions - mine has an hourmeter. But that gives me a starting point. Edited December 2, 2018 by blackrose Link to comment Share on other sites More sharing options...
Flyboy Posted December 2, 2018 Report Share Posted December 2, 2018 5 minutes ago, blackrose said: Could be, thanks for that. I think I need to read the instructions! In croftie's diagram it looks like hole 3 is a good bet. Link to comment Share on other sites More sharing options...
alan_fincher Posted December 2, 2018 Report Share Posted December 2, 2018 10 minutes ago, Tom and Bex said: Some VDO tacos have to be calibrated with a cable and dedicated software. Possibly plugs into socket marked 123? Ah - well done! This may be a bit of information I was unaware of. As there seems to be somewhere a cable could plug in, I'm tempted to think it may be the case here. (Seems to be overkill though, if all that is really needed is a twiddly potentiometer!) Link to comment Share on other sites More sharing options...
blackrose Posted December 2, 2018 Author Report Share Posted December 2, 2018 (edited) 3 minutes ago, Flyboy said: In croftie's diagram it looks like hole 3 is a good bet. Yes, I'm going to have to check to see if the dip switches are all set correctly first and then work out how to adjust the Potentiometer! Is it just stick a screwdriver in a twist? I'm not sure how mine is wired - should I assume it's as per Diagram D because I have an alternator? Edited December 2, 2018 by blackrose Link to comment Share on other sites More sharing options...
Alan de Enfield Posted December 2, 2018 Report Share Posted December 2, 2018 I still think its the 'ON' hole with the 1,2,3 beneath it. Looking up the hole it looks like a USB connector for programming. Link to comment Share on other sites More sharing options...
blackrose Posted December 2, 2018 Author Report Share Posted December 2, 2018 2 minutes ago, Alan de Enfield said: I still think its the 'ON' hole with the 1,2,3 beneath it. Looking up the hole it looks like a USB connector for programming. Ok, I'm pretty sure it's not a USB but anyway, what would I connect to it? Link to comment Share on other sites More sharing options...
Alan de Enfield Posted December 2, 2018 Report Share Posted December 2, 2018 1 minute ago, blackrose said: Ok, I'm pretty sure it's not a USB but anyway, what would I connect to it? Programming cable. Link to comment Share on other sites More sharing options...
blackrose Posted December 2, 2018 Author Report Share Posted December 2, 2018 (edited) 9 minutes ago, Alan de Enfield said: Programming cable. And what would I connect the programming cable to please? (Please don't say "Programmer" unless you're going to show me what it is!) The VDO instructions make more sense to me than trying to connect an external device to programme the revcounter. Edited December 2, 2018 by blackrose Link to comment Share on other sites More sharing options...
Alan de Enfield Posted December 2, 2018 Report Share Posted December 2, 2018 8 minutes ago, blackrose said: And what would I connect the programming cable to please? (Please don't say "Programmer" unless you're going to show me what it is!) The VDO instructions make more sense to me than trying to connect an external device to programme the revcounter. Dunno if this is any help ? He is talking about dip-switches, not USB type programming. Link to comment Share on other sites More sharing options...
croftie Posted December 2, 2018 Report Share Posted December 2, 2018 1 hour ago, blackrose said: Thanks for the instructions - mine has an hourmeter. But that gives me a starting point. https://j109.org/docs/vdo_programmable_tach_with_hourmeter.pdf Link to comment Share on other sites More sharing options...
blackrose Posted December 2, 2018 Author Report Share Posted December 2, 2018 Thanks, for that. I'll print those instructions out at work and manually calibrate it when I can although I haven't seen a tacho button on mine? Anyway it's not quite as simple to adjust/calibrate as some were suggesting earlier in the thread. Link to comment Share on other sites More sharing options...
Flyboy Posted December 2, 2018 Report Share Posted December 2, 2018 (edited) 2 hours ago, Alan de Enfield said: I still think its the 'ON' hole with the 1,2,3 beneath it. Looking up the hole it looks like a USB connector for programming. That's where the dip switches are on some units. I'm not sure if this unit has them, it doesn't look like it. On = the "on"position of the switches if it does. Edited December 2, 2018 by Flyboy Link to comment Share on other sites More sharing options...
WotEver Posted December 2, 2018 Report Share Posted December 2, 2018 Could you take a shot straight down 3 with the little silver cover removed as in your first shot? It looks to me like that might be a little yellow pot at the bottom of the hole but I can’t be sure at the angle of the photo. Link to comment Share on other sites More sharing options...
alan_fincher Posted December 2, 2018 Report Share Posted December 2, 2018 4 minutes ago, WotEver said: Could you take a shot straight down 3 with the little silver cover removed as in your first shot? It looks to me like that might be a little yellow pot at the bottom of the hole but I can’t be sure at the angle of the photo. Yes, this still seems possible to me, but I guess f Mike can't see anything on the yellow bit to get a small screwdriver into, it may be something else? As a complete aside, but to my mind, even if it is illuminated, there are more wires to the back of the unit than I might have expected, particularly as many of them are doubled up s must be connected to multiple places. Link to comment Share on other sites More sharing options...
Chewbacka Posted December 2, 2018 Report Share Posted December 2, 2018 (edited) 13 minutes ago, WotEver said: Could you take a shot straight down 3 with the little silver cover removed as in your first shot? It looks to me like that might be a little yellow pot at the bottom of the hole but I can’t be sure at the angle of the photo. It very well could be a little yellow trim pot down hole 3, and that would match up with the diagram from post #78 Edited December 2, 2018 by Chewbacka Link to comment Share on other sites More sharing options...
alan_fincher Posted December 2, 2018 Report Share Posted December 2, 2018 10 minutes ago, Chewbacka said: It very well could be a little yellow trim pot down hole 3, and that would match up with the diagram from post #78 Yes I agree entirely - I had not looked properly at that diagram until now. In fact a perfect match, I would say. If so, it would also seem to suggest that what is down the square hole labelled 1-2-3 is actually 3 DIP switches to do with calibration, and not as Mike thinks an electrical connector. (By the way, note that hole has clearly had something round stickered over it at some stage that has fallen off or been removed) I'd now be quite surprised if what's down that top hole were not an adjustable potentiometer. Link to comment Share on other sites More sharing options...
croftie Posted December 2, 2018 Report Share Posted December 2, 2018 22 minutes ago, alan_fincher said: If so, it would also seem to suggest that what is down the square hole labelled 1-2-3 is actually 3 DIP switches to do with calibration, and not as Mike thinks an electrical connector. (By the way, note that hole has clearly had something round stickered over it at some stage that has fallen off or been removed) Looks like the printed circuit is showing so yes possible DIP switches, perhaps for course settings, Link to comment Share on other sites More sharing options...
Flyboy Posted December 2, 2018 Report Share Posted December 2, 2018 26 minutes ago, alan_fincher said: Yes I agree entirely - I had not looked properly at that diagram until now. In fact a perfect match, I would say. If so, it would also seem to suggest that what is down the square hole labelled 1-2-3 is actually 3 DIP switches to do with calibration, and not as Mike thinks an electrical connector. (By the way, note that hole has clearly had something round stickered over it at some stage that has fallen off or been removed) I'd now be quite surprised if what's down that top hole were not an adjustable potentiometer. Or push button switch. Link to comment Share on other sites More sharing options...
Flyboy Posted December 2, 2018 Report Share Posted December 2, 2018 5 minutes ago, croftie said: Looks like the printed circuit is showing so yes possible DIP switches, perhaps for course settings, As I said in post 91, some units do not have dip switches, I can't see any in there. I think they were only fitted for the after market to cover a wide of engines. Link to comment Share on other sites More sharing options...
alan_fincher Posted December 2, 2018 Report Share Posted December 2, 2018 1 minute ago, Flyboy said: As I said in post 91, some units do not have dip switches, I can't see any in there. I think they were only fitted for the after market to cover a wide of engines. I really should be looking at all the post. I think you are right. I still back the "something down the hole at the top" theory, though! Link to comment Share on other sites More sharing options...
Flyboy Posted December 2, 2018 Report Share Posted December 2, 2018 4 minutes ago, alan_fincher said: I really should be looking at all the post. I think you are right. I still back the "something down the hole at the top" theory, though! Yes I agree, hole 3 either has a push button or a potentiometer. Link to comment Share on other sites More sharing options...
